Question about Pierre Cardin Tablet PC PC7001-BK iMAP210 256MB RAM 4GB Came
How do you charge battery on new pc 7001 (plugged adaptor into mains no lights showing
Just bought new tablet plugged into mains manual says red light will show then when battery charged will turn green. silly question but where is light supposed to be as no lights showing at all
Why does my tablet just show a red battery when I turn it on?
If it's a newer tablet it should be rechargeable. And a red battery light indicates the need for it to be charged. On one of the side edges of the tablet there should be a micro USB or other port for a charging chord to plug into.
Oct 14, 2016 | Visual Land Connect 9 with WiFi 9"...
When I plug in my device and try to turn it on the battery light glows red and a red light instead of a blue one will light up and I know I have charged the battery
at least you think you charged the battery . I would take it to a computer repair shop and have them check the battery
Oct 11, 2015 | Tablets & eReaders
Why does innotab charging light blink when charging and will not charge?
the charge imdicator is suppose to blink when you plug the toy to the wall adaptor. if it doesnt blink then there's something wrong with either the adaptor, the adaptor port on the toy or the rechargeable power packs. now i said that the light is suppose to blink. but the frequency of the blinks shouldnt be fast. if that's the case clean the compartments and re-insert the batteries. if you are still having problems try the ff T/S:
1)remove the power packs, plug the toy to adaptor and turn it on. if it turns on that means your adaptor is working.
2)remove the adaptor and try using just the power packs.
3)try using 4aa batteries.
if the toy turns on with only one of the power sources stated above you better call vtech hotline.
Sep 01, 2014 | Vtech InnoTab 3S The Wi-Fi Learning App...
Red x on charging
If its off the mains make sure it is at least 1000mah power output, if its from a computer usb it will only charge while off.
Feb 28, 2014 | Samsung Galaxy Tab Tablet PC
Screen has began to flash on and off and wont charge
I had a similar situation with my pipo s1. After further investigation I found that the jack the charger cord plugs into went bad. My charge light wouldn't stay on unless you held the charger plug in a particular position. The jack is hardwired into one of the circuit boards and to replace the circuit board was half the cost of the whole tablet. I junked it and bought a kindle fire. Better quality and longer lasting battery.
Dec 12, 2013 | shop-fun PiPO S1 7 inch Tablet PC Android...
Put a new battery on still does not work
Note: do not plug your laptop if not using this. this will damage to your battery this the most common cause of battery problem due to over charged without unplugged. pls remove after charge. this can also damage to your main board from power supply section. thanks romsky79@yahoo.com
Jun 06, 2009 | Gateway M275 Tablet PC
Acer Travelmate 2200 laptop
Try taking the laptop battery out. You can remove the laptop battery by turning it over, you'll usually see some sliders at the bottom, slide them to the unlock position and you should be able to wedge your battery out. The battery usually comes in a very tall and thin rectangular shape. Once the battery is out, plug the laptop in through the mains power - this may solve your problem, if it does, you'll need a new battery if you wish to use it on the move. If it does not solve your problem, it is either a faulty power adaptor, or a faulty power supply on the motherboard of your laptop. A faulty power adaptor or battery is the best case scenario, as it's the cheapest to buy a replacement (although it's still expensive - $120 worth in the UK roughly). A faulty power supply on the mainboard generally means you'll need a replacement mainboard which is totally uneconomical, especially with the labour cost to fit it professionally. If the battery and power adaptor is not faulty, you might as well scrap it and get a new laptop. Good luck Tina!
Sep 07, 2007 | Acer TravelMate 302XCi Tablet PC
Pierre Cardin Tablet PC PC7001-BK iMAP210 256MB RAM 4GB Came Logo
Top Pierre Cardin Tablets & eReaders Experts
Are you a Pierre Cardin Tablet and eReader Expert? Answer questions, earn points and help others
