Question about Toshiba (MK3252GSX) 320 GB SATA Hard Drive
How do i know if it is a 2.5 in or not and will any sata external case work with it?
  • Toshiba Master
  • 32,281 Answers
The Toshiba (MK3252GSX) hard drive is a 2.5 in SATA drive and it will fit into any 2.5 in USB hard drive case.
Posted on Dec 05, 2012
LG dvd external drive not recognized by computer
ERROR 43? Check your SATA connection.
HERE'S HOW I FIXED MINE.
(IE. Computer tries to install driver for BD burner, but ultimately fails, and gives the message. "Unsuccessful" and/or "Microsoft Windows stopped device. Error 43") The SATA CONNECTION on my BD burner's EXTERNAL CASE had gone bad.
TO TEST IT. I used a SATA/IDE to USB Adapter Cable I bought for about $10 on amazon.
  • I unscrewed the external case to get at the internal drive, and plugged the SATA adapter cable directly into the internal BD burner drive (bypassing the case assembly), and plugged the other end into my computer USB port.
    • PS My BD burner POWER was working OK, so I left the big white 4pin power adapter connected to the original external case.
VOILA! Both my laptop and my desktop PC recognized the LG BD burner again and assigned it a drive letter (like it used to do).
  • Now I either need to (1) Buy a NEW EXTERNAL case ($10 - $30), (2) install it as an internal drive (could get problematic if "ANYDVD" is installed) or (3) just leave it connected via the cheap adapter cable.
It's super EASY (& inexpensive) to TEST this before spending $$$$ on a new equipment.
Hope this helps someone. It had me miffed for a while there.
Jan 02, 2014 | LG GSA-2166D DVD RW Dual Layer Burner
I have plugged my lap top power into 'my book' and yes I have cooked a component on the PSB card, is the car repairable or can it be replaced?
It would be better to remove the harddrive inside the WD My Book, and install it into an economical external enclosure.
Suggest you forget trying to repair the interface circuit board inside.
If I am all wrong, and have misread your problem, please state in a Comment.
If I am correct so far, and if memory serves, the harddrive inside is a SATA model.
I don't know however if it is a laptop sized harddrive, or a desktop sized harddrive.
A laptop sized harddrive is 2-1/2 inches across in width. (2.5 inches)
A desktop harddrive is 3-1/2 inches across in width. (3.5 inches)
Once you open the case you will know.
By using an economical external enclosure you will have a external harddrive again.
This is one example of an economical 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
This is one example of an economical 3.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
This is information that may help in opening the WD's case, and extracting the harddrive,
http://www.youtube.com/watch?v=6FlySnyJ0CQ
http://www.youtube.com/watch?v=-_2oMyoTBno&feature=related
{TIP: DO NOT work directly on a carpet floor! It is a high area of Static electricity. Work on a table}
There are other videos related to this on the right side under the Suggestions heading.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 04, 2011 | Western Digital My Book Essential Edition...
I'm trying to install a Western Digital Serial ATA Hard Drive into the external hard drive enclosure. There are no instructions as to what cables need to be attached and to where
USB external hard drive cases are supplied with SATA and power connectors attached to the circuit board in the case. If you canot connect it to the SATA hard drive then you may have the wrong drive case, your case may be a IDE or SCSI type.
Jul 07, 2011 | NexxTech 1 Bay USB 2.0 External Drive...
I need to locate a mother board for a firelite model #USBFLB40-C any suggestion? Or where can I get a new USB power data plug soldered on the old board? Thank you.
Yes I would take the Harddrive out of the SmartDisk FireLite external harddrive, and install it into an economical external enclosure.
Looking up reviews just now I know that it's a laptop sized harddrive that's inside.
(The Harddrive inside is 2.5 inches across in width. 2-1/2 inches)
I don't know however if it is an IDE or SATA unit.
But you will know once you get the case open, and view the Harddrive inside.
One example of a 2.5 IDE external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1086960&CatId=2782
One example of a 2.5 SATA external enclosure,
One example of an external enclosure that will support IDE or SATA harddrives that are 2.5,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7041055&CatId=2783
Regards,
joecoolvette
Jul 04, 2011 | SmartDisk FireLite 40 GB Hard Drive
My lacie drive fell off desktop and is not recognized as readable by my Mac. What chance do I have of recovering the data?
Inside that LaCie external harddrive's enclosure is a regular SATA harddrive.
The kind that fits in a desktop computer (3.5 inches in width), or laptop. (2.5 inches across in width)
Open the external enclosure (Case) of the LaCie, remove the harddrive, and install it into a suitable external enclosure.
(Laptop size, or desktop size)
The external enclosure has a USB cable also. Just plug it into any available USB port on your desktop computer.
Do I know for a fact that the harddrive is okay, and this will fix the problem?
No sir/maam I do not.
But IMHO this is the first diagnostic method to use.
IF the harddrive is a desktop sized harddrive, it could be installed in your desktop computer as a Slave drive.
However the above method is so much easier, and it allows your harddrive to be an external harddrive once more.
Inside the external enclosure of the LaCie external harddrive, is a small circuit board that the Harddrive plugs into.
It is this small circuit board that receives the damage in most cases.
If the problem is the Harddrive itself, a professional data recovery shop will;
A) Try a new, or good used harddrive circuit board.
Check to see if the harddrive's circuit board received the damage.
B) If the circuit board proves to be good then the next step is to remove the Platters inside.
The room used is a Clean Room.
A room that is 99.9 percent dust free. (In most cases)
The Platters are installed into the case of a compatible harddrive, that has the Platters removed.
Then as much information as possible is copied off.
There are other methods data recovery specialists use also.
[A Harddrive is built in a Clean Room. 99.9 percent dust free. The technicians wear a Clean Suit, that resembles what a doctor would wear in an operating room.
They enter the work area after going through a corridor, fitted with air jets at various levels.
If a harddrive is opened up in a room that is not a Clean Room, the harddrive's 'life expectency' drops to a day, or a few hours. The dust 'kills' them ]
http://computer.howstuffworks.com/hard-disk.htm
http://www.youtube.com/watch?v=gpY8c7lT_7k&feature=related
http://www.youtube.com/watch?v=ax390l2A-AY
Observe the other videos also.
Examples of both a SATA 2.5 external enclosure, and a SATA 3.5 SATA enclosure,
(The Harddrive's width is measured in inches. (2-1/2 inches for a laptop drive, 3-1/2 inches for a desktop drive)
SATA 3.5 external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4421576&CatId=2780
Regards,
joecoolvette
Jul 02, 2011 | LaCie Hard Disk design by Neil Poulton...
Its worked great for months on my laptop on vista, today my friend borrowed it to watch a movie on her laptop, using windows 7, she watched 2 movies, unplugged it, and ever since then its not being...
you have to "stop" external drives under "safely remove hardware" or they can possibly be damaged. if the data is very important, it *may" ber possible to take the hard drive out of the case, and install it in a new hard drive case. this might work, depending upon the type of hard drive. they doi sell external hard drive kitxs in stores, but you have to know if it is a PATA or SATA hard drive. SATA is the newest, and likely any external drive from the past 2 years will be SATA.
Mar 08, 2011 | Computers & Internet
I have several computers at home, and none og them can recognize this portable device. Hitachi 250 GB Mod: SDM/250RW
1) Power:
It may be the problem that occurs with a lot of USB powered devices jrherrer. Not enough power provided.
The USB cable plugged into the computer, provides signal wires for transferring information back, and forth, and also provides 5 Volts DC for power. (Two D cell flashlight batteries produce 3 Volts DC)
http://en.wikipedia.org/wiki/USB
[ Below shows the Signal pins, and the Voltage pins of the USB B Mini style connector, (Male), used to connect to the SimpleDrive Mini external harddrive,
Pin 1 is for the 5 Volts DC Positive (Wire color - Red)
Pin 2 is for the D- Signal (Wire color - White)
Pin 3 is for the D+ Signal (Wire color - Green)
Pin 4 is not connected. (Or sometimes joined to Pin 5 with a Resistor)
Pin 5 is for the Ground (Wire color - Black)
Just added info in case you wanted to know ]
From what I see the SDM/250RW has a USB port on the side, and a DC Power Jack, used for an AC adapter, also.
(Round port with a pin in the center)
http://www.hitachigst.com/tech/techlib.nsf/techdocs/0C876B7AB91B23988825773F006BEA02/$file/SD_Mini_DS_final.pdf
From what I see stated from Hitachi, and sellers on the 'net, the AC adapter may not be provided.
Many of those who provide a review state that both the USB cable, and the AC adapter is needed to provide enough power. Seems to be a power hungry external harddrive
It's a 2.5 Hitachi SATA laptop harddrive inside that external case. (The Harddrive is 2 and a half inches across in Width. Common size used for laptops)
When using an external device powered by a USB cable there are general guidelines to follow,
A) The USB cable should not be more than 2 feet in length
B) Connect the device directly to your computer, instead of through a hub, or other device, unless the USB hub has it's own power.
2) USB cable:
Could be a faulty USB cable, although I imagine you have tried different ones by now.
3) Interface Circuit Board:
The Hitachi SATA 2.5 harddrive inside the SImpleDrive Mini SDM/250RW, plugs into a small circuit board located inside that external case.
Components on the circuit board may be fried, or the Harddrive may have come loose from the interface.
Loose from the interface
To explain;
The back of the harddrive has connector pins sticking out.
The interface has socket holes which the pins insert into.
Faulty circuit board
The external case of the SimpleDrive Mini SDM/250RW can be carefully opened up, and the Hitachi SATA 2.5 harddrive extracted out.
Another inexpensive external case for a 2.5 SATA harddrive can be procured, and the Hitachi harddrive put in it.
Example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3743049&CatId=2781
Nov 22, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
I want a converter for Hitachi HTS541612J9SA00 120 GB SATA Hard Drive to usb do you know wich one I need..?
You need a 2.5" inch SATA to USB external harddrive enclosure.
since its a laptop hard drive you need a small case.
for example this one http://www.amazon.com/2-5-SATA-HDD-Enclosure-Black/dp/B0018TCB0O
Aug 07, 2010 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
I have a 320GB external usb and it is coming on but not being recignized by the computers. Blue light comes on and goes off, it maks noise as if it is running. BUT my computers detect new hardware but says...
The problem is with the controller board inside the SimpleTech drive. The solution is to remove the 2.5" form factor SATA drive from the case and install it into a new case. I have had 2 SimpleTech drives (both Pininfarina style) fail on me and in both cases it was the controller board and NOT the hard drive inside.
To remove the drive you have to remove the label on the bottom that says "Do not remove or you will void your warranty. Under that label you will see two phillips head screws. Remove them and the case can then be pulled apart. The controller board is screwed onto the bottom of the hard drive. Remove the screws and slide the board carefully off of the SATA connection and power ports and now you have a bare drive.
Go and by a 2.5" SATA form factor hard drive external case from some PC store or from eBay. I got mine on eBay for $10.00 including shipping. Install the drive in the new case plug it in and away you go. Make sure that you buy one that DOES NOT NEED AN EXTERNAL POWER SUPPLY.
It is almost NEVER the hard drive itself that fails it is almost always the controller board. Make sure that you open the case and check that your hard drive is really a SATA drive before ordering the case. If it happens to be PATA (IDE) then make sure you order an external case for that type of drive. They are NOT the same and you HAVE to get the external case that mates with your hard drive.
Good Luck,
John
Aug 17, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Toshiba (MK3252GSX) 320 GB SATA Hard Drive Logo
66 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
