Question about Dryers
Hunter alignment machine
I have a Hunter alignment machine, not that old but the monitor stopped working. The power light comes on but the screen wont appear. do i have to call hunter to fix this? or can i just replace the monitor?
Crossedwires
  • 44 Answers
SOURCE: how to wire hunter 44155
Go to the hunter web site. They will have the proper wiring diagrams on the site. If you cannot do that pick up a basic wiring book at your local electric parts supplier. the place you got the thermostat would be a good start. I do know that menards has some books in the electric area that would be a great help to you. You also will need to be sure that the thermostat is able to handle both air and heat. many only do heat. If this does not help let me know and I will try and get more information to you
Posted on Feb 09, 2008
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
milten1
  • 1304 Answers
SOURCE: Hunter 44260 Thermostat Problem
make sure you have the jumper in place
if you dont have a secondary heat source red should be on r with a jumper to rh
Posted on Oct 17, 2009
  • 3 Answers
SOURCE: Hunter Fan has stopped accepting remote control signals
I'll guess and say that the fan quit working properly shortly after either a power surge in your house of after a light burnt out after turning them on. It has happened several times to the two Hunter fans we have here, both with the wireless remote control. After having both replaced under warranty, and then paying for a replacement, I finally took the receiver apart and found the root cause. There is a power regulator (looks like a power transistor) that uses the aluminum portion on the housing as a heat sink. The part is easy to replace for those of you who are handy with a soldering pencil. For those of you who are not, I'm sure you know of someone who is. Now for the good and bad news. The good news? The replacement part is about a dollar from an electronics supply house called Mouser. I tried Radio Shack, but they have really cut back on electronic components. The bad news? I can't remember the part number. I have a spare one, but I can't find it right now. I will look for it and if need be, I'll open up the receiver and get the number off of it and post back to this thread. After replacing the part in both a little over six months ago, we have had no problems with the receivers. Voltage spikes no longer take out the regulator.
Posted on Jan 04, 2010
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
Hunter wheel alighment rack RM. What does it mean when the green light flashes?
Hunter Wheel Alignment Lift Repair Manual - Vckystxx.com
vckystxx.com/taggedby/hunter-wheel-alignment-lift-repair-manual/
Hunter Alignment Lift Rack Manual Pdfsdocumentscom, Hugh Dixon Hunter AlignmentLift Rack Manual.pdf ... For Hunter Wheel Alignment Lift Racks. ... Repair ...
Jul 28, 2015 | Cars & Trucks
Power to television but wont light screen
Hi Anon,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 14, 2015 | Televison & Video
How to fix an arcade screen on a big buck hunter safari machine?
If the screen appears discolored in the area where it does not shoot then it is possible that you have a degaussing problem( which should be fixed with turning off the machine for a half hour and then back on) or a loose shadow mask in the monitor( which you can do nothing about). Assuming that is not the case then try turning up the brightness and contrast beyond normal and see if it registers. The easiest way to do that is in the tracking screen. If turning up the controls works then you most likely have a bad capacitor in the monitor or on the circuit board. Another possibility would be background light bouncing off the screen. Turn out the lights in the room and try again. Good luck
Apr 27, 2014 | Video Game Consoles & Games
Has anyone had problems with their Hunter alignment rack
Yea mine has the green light starts blinking then the rack wont do anything
Feb 13, 2013 | Hunter Dsp600 Alignment Rack/lift
Hard drive light flashes 10 time, but screen does not power on
man jst remove ur ram nd use a eraser rub the ram then insert the ram properly nd also check ur cmos battery.......ur work is done....
Aug 30, 2009 | E-Machines eMachines Desktop PC
Monitor boots ok, then "Analog" appears/monitor shuts off
Does it have a digital port being used? If you are using the DVI port, it is probably digital. Try using the menu to selct the port. If it doesn't work, not sure from here. What is the model number?
Aug 01, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
Hunter Douglas Ceiling Fan Does Not Work
have hunter douglas fan glass globe broke cant find repalcemants i have all the serial no do you no wher i can go to find 91/2 globe
Oct 30, 2008 | Dryers
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Dryers Logo
75 people viewed this question
Top Dryers Experts
