Question about Hotpoint NLL113EYWO Electric Dryer
The dryer will not stay running.
I have to hold the switch in the on position until it shuts down. You have to do this at least 8 times before the dryer will stay running.
  • 1,543 Answers
When you hold the start switch you are energizing the start winding of the motor. If the motor does not take off and run, the most likely cause is the centrifugal switch inside the dryer's motor is not being switched. It is switched by a spring loaded collar on the motor shaft which moves when the motor starts to run, and again back when it stops. Often times this collar begins to stick on older dryers. Sometimes you can free it up by cleaning the dryer motor with an air compressor and hitting the collar with some spray lube. This only works some times. The only sure fix is to replace the motor, which unfortunately is rather expensive and a fair amount of work. Please don't bother rating this, as anything but a Fix-Ya lowers my score.
Posted on Jan 12, 2009
Dryer won't stay running without holding down the start button
It may be the centrifugal switch on the motor. The push button starts the motor and as the motor spins up to speed the centrifugal switch closes to keep the motor running. Hope this helps.
Jan 02, 2014 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
When you push the start button, the dryer turns on, but shuts off when you let go of the button. Dryer does not stay on, When you continuously hold the button in the "on " position, the dryer operates...
There is a switch on the motor that is active when the motor gets to speed. Either the switch is bad or the motor is not getting up to proper speed.
Eric
Aug 21, 2010 | Kenmore 74602 Gas Dryer
Dryer won't stay on
The motor centrifugal switch is not switching from the start winding to the run winding. The switch should stay in the run winding when the motor picks up speed unless power to the motor is interrupted or cut off. The switch is replaceable on most dryer models but sometimes it is an integral or built-in part of the dryer motor and failure of the switch requires the replacement of the motor. Indicate the exact model number of the dryer for more accurate troubleshooting and repair advice.
May 24, 2010 | Kenmore 63932 Electric Dryer
Hello, My GE Dryer, Model M460-G timer won't shut off
Sounds like you have a faulty timer switch, check with your local supply house and get the same type of switch.
When you go to replace the timer switch, unplug the dryer, then remove one wire at a time. This will prevent wiring mix-ups.
Good luck,
I hope this helps
Oct 11, 2009 | GE Dryers
Clothes dryer is overheating and then shuts off
Your vent pipe is probably clogged with lint. Clean out, and blow out, if possible, If the vent is clogged, the air cannot properly escape and all that heat stays in the dryer, which probably sets off some kind of themal protection switch, preventing the dryer from running until it cools down.
Oct 10, 2009 | Kenmore 73932 Gas Dryer
Dryer won't stay on when button is pushed the button has to be held down for the dryer to run
A centrifugal switch has failed within the dryer. The centrifugal switch maintains electrical flow to the motor after the start button has been released (this is a safety measure) When you press the start button you put power directly to the motor; once started the centrifugal switch then puts power to the motor until the time then shuts it down.
I hope this may have helped you,
Tom
Oct 03, 2009 | Dryers
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
Dryer shuts off when releasing start button. Will run while pressing down start button, but no heat is generated. Sears repair man wanted to replace Even Heat Control Board for $350. I bought the part...
replace the motor, as you are holding in the start button you are making the dryer run in the start winding of the motor, it is designed to only stay in this winding untill the centrifigual switch on the motor automaticaily switches it to the run winding, when the motor switch knows that it is using the run winding it closes the motor switch contact for the heater to come on, replace the motor
Apr 12, 2008 | Kenmore 63942 Dryer
Auto feature
Faulty selector switch or control card. There is the possibility of a faulty moisture sensor. Can you operate the machine in manual mode ?
Jan 26, 2008 | Whirlpool GEW9250 Electric Dryer
Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
Hotpoint NLL113EYWO Electric Dryer Logo
381 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
