Kenmore washer will not drain water before or after rinse cycle
  • 15,935 Answers
If it is agitating - the timer has failed.
If it is NOT - look at the motor/pump coupling/transmission for failure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Kenmore washer - water won't drain. It stops
If the water drains between the wash and rinse cycles, your motor and pump are probably OK. If this is a machine with a dial, try a different cycle, like normal instead of heavy duty. If that works and the machine completes the entire cycle then the timer probably has a bad spot. You might try to find a replacement timer if that is the case although I didn't have any luck with my 10 year old washing machine. Best of luck
Mar 20, 2010 | Washing Machines
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer doesn't drain
This is likely a pressure switch issue.
May 27, 2009 | Kenmore Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore 22622100 Top Load Washer won't drain the water, nor rinse
HI!!! you seem to have a bad lid switch on your washer..I would also check the timer on it good lucck.
Feb 13, 2009 | Kenmore 22422 Top Load Washer
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
