Question about Sharp Aquos LC-22SV2U 22 in. LCD Television
My tv dvd 37"neon combi comes back on when the green power off button is used. it goes back onto standby and then the telly comes back on. any ideas?
It has also got shading and some lines on the screen do you think my tv is dying?
    Top Expert:
  • Sharp Master
  • 14,553 Answers
It sounds like the main board which controls everything may be bad--not a do it yourself repair---please consider having a tech or a shop look at the set and give you an estimate.
Posted on Dec 04, 2012
techman
  • 3130 Answers
SOURCE: TV will lose picture then go into standby!
Yes it is a temp problem as you found out for your self Great call on that BUD.. the best thing to do is contact sharp to see if they have had simular problems and if there are any recalls on this model . If not they will instruct you where to send the monitor into to be fixed.
Posted on Apr 02, 2006
SOURCE: Sharp tv standby button wont switch on
have the same problem .please help.
Posted on Aug 31, 2008
circuitworld
  • 335 Answers
SOURCE: sharp aqous lc 37 in tv power no picture,sound
Your control board seem's defective or the inverter board (associated circuits) are bad. This is common in most TFT-LCD Tv's.......
Posted on Dec 01, 2008
ginko
  • 19396 Answers
SOURCE: Phillips 51in tv rear projection power button blinking green
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
  • 8457 Answers
SOURCE: power light is flashing green. i hold the power
Sharp tv are famous for this problems.Take ur tv aparts,where the a/c power cord go into it.That ur tv power supply board,check for all those dead leakage capacitors parts that bulges up on it top or puff up on it top.Than it ur power supply board,replaced those dead leakages capicitors or replaced the whole power supply board.No leakage capcitors on the power supply board.Than it 100% the Tuner board it dead,this board is where the coalax broacast tv signal cable go into it.This board can't not be repair only replaced,because it alway some ICS it the problems it dead on this Tuner board.Tries websties like Shopjimmy.com,Ebay.com to buy either or both refurbishes the power supply board or the Tuner board.
Posted on May 26, 2010
Alba portable tv/dvd combi
Main board fault. Contact any service technician.
Mar 26, 2014 | Televison & Video
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Mirai tv no remote and all buttons on tv when
This is a main board issue and will need service.
Some LCD TVs have a 2 year warranty.
Jan 19, 2010 | LG 37LC7D 37 in. LCD HDTV
TV repeatedly goes into standby mode and then comes back on
Resolder Horizontal section & SMPS Power Supply with Soldering Iron
Jan 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
HDMI conneection wont override tv picture
I am a sky engineer (not a subby)
the reason this does not come on straight away is because a Scart lead send power upto your telly when it is turned on. Telling the telly that this is what you want.
Unfortunately HDMI does not send power upto the telly. There are ways around this. ON Samsung, Panasonic and Lg tellys you can go into a secret menu and apply something called HOTEL MODE this allows you to change the av input so it would automatically come on your hdmi 1,2,3, etc
In your case follow my instructions below
go to the hdmi you are using for your Hd
on the sky remote
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice. what this mean is when you press your Sky button, tv guide, services or interactive button to turn the sky on this will automatically change your av/source on your telly to the sky HD for you
You owe me a pint
Have a good one
Little Dish Fitter
Jul 19, 2009 | Microsoft Xbox 360 Console
LG LCD 37'' standby problem
if you want i will buy the tv from you
Nov 17, 2008 | LG 37LC7D 37 in. LCD HDTV
TV not turning on.
Mine was doing that and I ordered a replacement power supply board for it and now it work. It's fairly easy to replace.
http://www.partstore.com/GetModel.aspx?MfgName=Royal+Philips+Electronics&BrandName=Philips&ModelNumber=37PF7320A37&page=16
Mar 14, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tv wont work
The signal processor has failed and needs replacement.
Feb 21, 2008 | Televison & Video
Sharp Aquos LC-22SV2U 22 in. LCD Television Logo
46 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
