Question about Yamaha RX-V461 AV Receiver
I just purchased a yahama rx- v850 av reciever
& the display light bulb is burned out.can you tell me where i can buy one?it is a little bulb w/ 2 wires (red & white) & a small 2 prong plug on
the end. pschmotzer@yahoo.com . thanks:
  • kahuna7945 Dec 27, 2009
    have a yamaha rx-v850 a/v receivor...led lights off on front display..is this easy to fix...burnt led's or bulb or?...TIA ...kahuna7945@gmail.com
If you dont mind a lettle customization, just go to radioshack and set your favorite color l.e.d. and wire it in, if you can find a specs diagram for your reciever, you might look up voltage and wattage of the bulb so you can get appropriate resistors for the led, and install that. itll last forever, cost virtually nothing, and its easy to do.
Posted on Jan 24, 2009
Ezraw,
I have same problem from same rec....
thanks I will make this a project for my EE friend at Radio Shack.
am also missing bass, treble and balance knobs off same unit? Any idea where to find. Also missing remote, can any universal remote work or do i have to find original?
thanks
Posted on Feb 19, 2010
  • Scrollsaw Feb 26, 2011
    just fixed my rx-v1050. the display bulb was gone. appears if no resistance is in this circuit causes the receiver to shuts down.... went to Radio shack and picked up a miniature lamp (2721141a) 12 v 25mA and replaced old one in which filament had burnt out
Do I need to connect my older Fisher Turntable to a pre-amp before connecting to my Yamaha RX-V850?
No, you don't need a preamp if your turntable has a moving-magnet (MM) cartridge, it should work as-is! Happy vinyling =]
See page 27 of the manual:
Yamaha RX V850 User Manual Page 27
Aug 09, 2016 | Yamaha Rx-v850 Audio Video Receiver Black...
How to connect my lg lcd tv to yamaha rx-v850
Use the Component Out sockets (RCA sockets - Yellow , Green , Red yes 3 wires) on TV to Component In sockets on Receiver which is again 3 wires
Jun 14, 2015 | Yamaha Rx-v850 Audio Video Receiver Black...
Rx v850
Are they connected and turned on. First read the instructions they contain some amazing information.
May 04, 2014 | Yamaha Audio Players & Recorders
Display illumination is out
If it is Yamaha,that model is obsollete,you have small chances to fix it
Nov 24, 2009 | Yamaha Audio Players & Recorders
Yamaha RX-770 Receiver display quit
there is a bulb inside the backlight on the lcd display.it is 12 volt and alot of manufacturers run it from the +- 15 volt preamp power supply,on the plus rail.when the bulb burns out it can activate the dc speaker protect,or some other 12 or 15 volt circuit..if it is a flourescent display that is a different problem.those run on 5 12 18 and -32 volts.there is also a 6 volt ac filament voltage.you need the schematic.
Jun 14, 2009 | Yamaha RX-770
My yahama rx-463 does not reconize the sub-woofer. any help?
Typically a/v recievers have on/off settings for each sound mode. This is likely the cause.
Mar 23, 2009 | Yamaha RX-V463 Receiver
I need a display bulb for a yahama rx- v850 av reciever
The display bulb is a 14 volt bead style lamp about 0.150 inches wide with wire leads. You'll need to cut the old bulb off the two -pin cable assby and wire the new lamp into the existing wires.
partsexpress.com
mcmelectronics.com
or
studiossoundelectronics.com should have lamps for that
Jan 11, 2009 | Yamaha RX-V461 AV Receiver
Yamaha RX-V850 receiver
how can i hook a subwoofer into yamaha RX-V850
Dec 25, 2007 | Yamaha Audio Players & Recorders
Yamaha Receiver RX-V670
Parts list and exploded diagram of yamaha rx-v850 found free here:
https://www.vancebaldwin.com/shop/research_new/YAM/RXV850.pdf
Enjoy. They can get the bulbs for $1.40...
Bsmt Dweller
Sep 07, 2007 | Audio Players & Recorders
Yahama RX-V590
Sorry to have to tell you but that means there is a short in the output circuit or the power supply. I would bet that one or more of the output componets are bad. If you know solid state circuit troubleshooting, It still may be worth repairing. if you do not then most likly it is time to get a new unit.
Oct 14, 2006 | Yamaha RX-V590
Yamaha RX-V461 AV Receiver Logo
1,144 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
