Question about HP Officejet 4315 All-in-One Printer
Try HP support again (if this is still a problem)
They are replacing my 'all in one' that has the same problem
    Novelist:
  • 180 Answers
Isn't it nice when warranties are actually used!?
Posted on Jan 17, 2009
We have an 8500 HP printer. My husband bought replacement ink cartridges from cartridge world. The printer says the yellow is out of ink (only one replaced). I can't get the printer to recognize the...
Hi there!
One reason why it will not give you a full yellow bar in the Ink Levels is that the replacement cartridge used was a non HP cartridge. To resolve this issue all you have to do is to purchase an original HP cartridge from HP.
You can call HP's customer service which is 18004746836 and order the cartridges from them or go to HP's website which is hp.com.
HP currently offers Free next business day delivery for their cartridges and paper.
If you are using an HP cartridge and it's still not giving you a full bar on the Ink Levels don't hesitate to contact their customer service and if your printer is within warranty they will surely address your concern immediately.
Hope this helps
May 25, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My hp compaq nc4400 does not detect its hdd
Hi
you could try this it sometimes work
turn off laptop and unplug power cord
turn laptop upside down
find the panel underneath that holds the hard drive usually 2 screws
remove panel and remove the hard drive
If you are not sure how to remove the hard drive ( not difficult )
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01884372&printver=true
turn laptop up correct way and try to restart laptop
it wont start up because you have removed the hard drive
now switch off again
turn upside down again
replace the hard drive
replace the panel
turn up correct way
and try to restart the laptop again
if this dont work
now turn off and on again pressing the F8 tab a few times to see if it takes you into repair options
and try the back to last known good configurations
or try some of the other repair options
hope you get it sorted
many thanks
Mar 22, 2011 | HP Compaq nc4400 Notebook
My HP LC3772N TV shuts off and then restarts again playing for 2-5 mins before it does it again. Any helpful ideas? Trying to decide between repair and replace. Thanks in advance
The power supply board is defective.That the board where the a/c power cord plug into it.Take ur tv aparts,replaced the power supply board should solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 29, 2010 | HP LC3772N 37 in. LCD Television
Hp f1903 flat pc monitor goes black after 5
I was given a faulty f1703 by someone as it was out of warranty, had no help from HP and bought another brand replacement.
Same problem everyone else seems to be having. Press the on button, came on for a second or so and then went blank. Press button again, turn on again and the same happened.
I managed through trying time and again after pressing on to quickly press menu, then go down to Factory settings, press select, go down to Yes and press select again. This reset to the Factory settings and it seems to be working okay. Been like this now for about a week. I don't know how long it will last - if it goes again will try re-soldering. Guess I won't be buying HP products as this was a part of a very expensive system.
Apr 29, 2010 | HP W2007 LCD Monitor
Can't scan
please disconnect the power cable from the wall outlay and press and hold the power bottoum for 20-30 sec then restart .
try and make a copy from the printer
again try to print a test page from the printer and see how it prints if it prints fine then it should scan
if it does not print the test page fine then there is a problem with the printer itself
click on the URL to print the test page
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01607730&cc=us&lc=en&dlc=en&product=3441026
follow the above mentioned steps
still if does not work try this
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01124259&cc=us&lc=en&dlc=en&product=3441026
again try the first step
and after that contact HP let them know what have you tried so far and they would probably replace the printer for you idf the issue is not resolved
HP TOLLFREE NUMBER -1800-474-6836
if the printer is in warranty they should replace
Thanks
Regards
Hamid.
Feb 23, 2010 | HP J3680 Officejet All In One Printer
HP Deskjet 722c appears to print but the page is blank. New toner cartridges have been installed
If the clean test page shows streaked or broken colors, the printer or cartridges are not functioning properly. Note that HP cannot guarantee the quality of refilled or remanufactured cartridges. Follow the steps below to solve the problem:
  1. Remove and reseat the cartridges. Try printing again.
  2. Check ink levels, and if a cartridge is low on ink or out of ink, replace it and try printing again.
  3. Clean the cartridges. Depending on what printer you have, you can either print another clean test page or run a cleaning utility. Check your User's Guide for instructions. Try printing again.
  4. Clean the contacts, then try printing again. Click here to see how .
  5. Align or calibrate your cartridges (depending on what printer you have). Check your User's Guide for instructions.
  6. If none of the steps above have helped, clean the nozzle plate manually. Click here to see how .
  7. If the problem still has not been solved, replace the cartridges or service the printer. Click here to see how to decide which to do .
Feb 13, 2010 | HP DeskJet 722c InkJet Printer
Hp Besiness inkjet 1100 fault codes cayan maginta ink and paper lights come on dead
HP Business Inkjet 1100 stops everytime after the first line stars to print. The power is one, the ink drop light is lit, the "yellow" indicator light also on, and the paper light all on. None of them blinking. We replaced the yellow cartridge with a brand new HP 11 yellow cartridge. Turned the printer off and on to reset. Printer comes on everything looks good till you try to print anything, even a on line word doc? Then it happens again, so we replaced the yellow again...same thing. We ever cleaned print heads, Any assistance would be welcomed?
Jan 12, 2010 | HP Business Inkjet 1100dtn Printer
Have a new HP Pavilion entertainment pc with Windows 7.
I also have a HP Pavillion dv9260 , had the same problem, HP help live said the video board, which is an intergral part of the mother board is bad....burnt out...needed to replace the motherboard and they won't stand behind them...I was out of luck $400.00 to repair and stories are that it won't last long even if you do...so here it sit's basically $2400.00 dollars worth of scrap parts........
Dec 27, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Hp psc 1317 unable to use hp director scanning
Uninstall "HP Director" and replace with "HP Solution Center" New Updates (especially IE 7) make this application incompatible. Ed
Aug 06, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP Deskjet 1220C cartridge recognition problem
This happens when the connections on the cartridge get old. Especially when you refill or buy non HP Cartridges, try buying brand new hp cartridges and you might be able to get a couple refill out of them before this happens again.
Feb 09, 2007 | HP DeskJet 1220c InkJet Printer
18 people viewed this question
Ben Johnson
