Question about Maytag MAV6200 Top Load Washer
Water is driping on my wash machiene
20094547w
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Dec 04, 2012
I have sf-p120lj washing machine. When the electricity is turned off the washing process back again. So that it fills the water again.What is the reason please?
Check the outlet pipe, it sounds like water is syphoning (spelling ??) back into machiene, if possable, put outlet pipe oves sink, and HOLD IN PLACE, try that.
If ok here, it is the outlet.
May 21, 2016 | Washing Machines
Wont let water leave washing machien chequed filter its cleanhave to drain
YOUR PUMP IS BROKEN AND WILL NEED A NEW ONE OR IT CAN BE BLOCKED
Dec 27, 2013 | Washing Machines
Machien starting
Is water turned on?? If so may be water valve faulty
Jun 15, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Clothes still driping water after spin cycle
Remove pump motor and check for any obstruction internally. If clear, blow into each end of both pipes and inspect for blockages. That will be the area or the problem.
May 18, 2010 | Washing Machines
Stopped
This is a typical Anti Flood system activation. This system activates when water leaks onto the floor of the machiene due to a leak fault (pipe/hose clamp/ partly blocked pipe). The machiene automatically switches to pump out mode and stops water inlet. The anti flood system is a polystireen float / micro switch at the base of the machiene floor. Dry the floor and drectify the leak and it should work.
Jan 24, 2010 | Baumatic 23 in. BDW13 Built-in Dishwasher
There is no water going into the dishwasher even though the water supply is on.
Jan 24, 2010 | Miele 24 in. G665 Built-in Dishwasher
GE Dishwasher no water upon start, humming, blinking lights
Seems like the anti flood is activated when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water. The machiene does not work exept the outlet pump in this mode.
Jan 18, 2010 | Dishwashers
Recurring .30 fault on AEG dishwasher. Have tried pulling out machine and tilting back 45 degrees but fault clears and then comes back on next wash. Is there anything else I can do?
This is caused by the Anti-Flood device at the base of the machiene being activated. This device detects water leaks and is a polystireene float / micro switch that puts the machiene in pump out mode only. You need to determine where the leak comes from (pipe or perforated hose pin hole or pipe clamp etc.) If you tilt the washer and some water comes out from the bottom it is a clear indication that there is a small leak.
Apr 14, 2009 | AEG 24 in. Favorit 60830 Free-standing...
Washing machiene not spin dying
Most likely the coupling near the motor. go to fixitnow and search your washer problem. Tells how to fix it, I'm doing mine now.
Feb 23, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
22 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
