Question about Refrigerators
Freezer FFU17M8GW ices up and then defrosts
Replaced the door gasket but still have the problem
  • Karen Dec 06, 2012
    The freezer is not a self defrost model. It is a manual defrost. It is jjust a freezer no refrigerator. I have defrosted it only to find in less than a week it totally ices up again and then starts to defrost on its on and lose all my frozen food.
3 Suggested Answers
bobicehouse
  • 1524 Answers
SOURCE: Ice Maker stopped working
You need to defrost the freezer. By the door being ajar, there was excessive ice build up on the coil that was not removed during a system defrost resulting in a blocked coil. This caused the temperature to rise in the freezer above twelve degrees that is why the ice maker stopped.
Posted on May 19, 2009
Maytag317
  • 1136 Answers
SOURCE: Ice buildup around freezer door seal.
Hi, Check and see if the gasket is leaking any where. Also check and see if the door to you ice dispenser is closing. Ice/frost only builds up around the door hen there is an air leak.
I hope this helps you. Please let me know if I can assist you further,
Thanks
Vic
Posted on May 23, 2009
I had just submitted a question in regards to my Amana Freezer not keeping the food frozen and the coils freezing up to the point that we have had to defrost the freezer twice in the past 3 months.
Non defrosting units are a thing of the past, almost all fridges made in the last 20 years are self-defrosting. If the coils are freezing up, what kind of ice is it? Clear ice near the bottom indicates your defrost drain is clogged. Snowy, fluffy ice indicates the defrost system is the problem. Make sure the fan in the freezer is blowing freely. Then check the continuity of the defrost heating element. If its OK, the limit switch is bad. If its not replace the defrost heater. Also don't overlook the possibility the door gasket is leaking, allowing warm moist air in that condenses on the coils! To check a gasket, insert a dollar bill between the door and the gasket, close door on bill, pull bill out, if good resistance gasket is good, if little or no resistance gasket is bad or needs adjusting.Do this teas all the way around each door.
Aug 10, 2014 | Amana Refrigerators
GE GSS25WGMC freezer ices up at top. Fan motor makes loud noise as it ices up between defrost cycles. Door gasket (screw in type) was replaced and problem a little better but not cured. I'm told...
Try replacing your defrost timer it may not be working proper also if it has the coiled heaters behind the insulation make sure they are coming on as well they do burn out.Check heaters voltage and continuity first then defrost timer. If no heated defrost its defrost timer
Apr 05, 2012 | GE Refrigerators
We have a frigidaire upright (ffu17m7hwd) which formed a lot of ice and we are in the midst of defrosting and don't want to experience this again. Can you assist please? Had to throw food out due to...
Freezer burn to food is caused by air & moisture in contact with it.
There should be a tight seal by the rubber gasket along all the inside edges of the freezer door. This gasket prevents unwanted hot moisture and hot air from entering the freezer compartment and causing ice build up. You can test the integrity of the rubber gasket seal by seeing how the freezer door will pinch a slip of paper in various spots around the freezer door. If the slip of paper pulls out easily, there is not a good seal at that spot. If that's the case (which I believe it is), the door gasket needs to be replaced. By the way, ice will build up over time because you need to access the food in the freezer, hence you will introduce moist air each time you open the freezer door.
Aug 28, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Top left corner of door is pushed back by ice. gasket looks OK. Cleaned ice but problem reoccured
hello,
is your freezer one you have to defrost manually or it is a automatic defrost style, if it's manual defrost ,the frost i suspect has built up and pushing the door out ,by defrosting it their will be clearance between door and shelf. If it is auto defrost either one or both door hinges should be replaced
Aug 05, 2011 | Kenmore Freezers
The refrigerator section does not get cold. The freezer works. Had the defrost timer replaced twice
It seems obvious that the defrost timer was not the problem. Could be a bad defrost heater, bad defrost termination thermostat, or possibly just a bad air leak, caused by a bad door gasket (check the bottom of the fresh foods door gasket) or a non-sealing ice dispenser door.
Jul 31, 2011 | Maytag MSD2456G Side by Side Refrigerator
MY FREZER HAS FROST AROUND THE DOOR AND MOLD IS GROWING AROUND IT
You need to replace the door gasket. It's leaking air causing the frost.
May 04, 2011 | Whirlpool Freezers
My frost free freezer is icing up on the bottom of the freezer. Occasionally find water on floor No
If the ice is clear and frozen on the floor of the freezer the defrost drain line may be plugged causing the water to over flow the
drain trough and leak into the bottom frezer compartment.
This will require a service tech. to remove the rear panel inside the freezer and find the reason for the blockage of the drain line.
ie....
Mold or slime in drain line
Debirs covering the drain inlet hole
Out of spec defrost heater.
If the ice is fluffly like snow then the freezer door may not be sealing properaly.
With the freezer door closed check the door gasket all the way around the freezer door.
If a gap is seen on one side the freezer door may be misaligned.
To realign freezer door remove all ice with a hair dryer.
Soak up all moisture on the metal rails and inside the freezer.
Pull freezer door all the way out unitll it stops serveral times.
This may realign the freezer door.
If not the door slide rails,Track or Roller gears may need to be replaced.
Jan 15, 2010 | LG Refrigerators
Freezer is icing over. I cleaned it out and am now having problems shutting door completely. how can I get door to shut so won't freeze over?
Check to make sure there are no debris on the gaskets on your freezer door or the base of the freezer, or any foreign objects that might prevent the door from properly closing. otherwise you have bad gaskets that need to be replaced. If you have a frost free model you should not have an iced up freezer - you might want to have it serviced and check the defrost timer assembly and check the hinges/cam assembly on your freezer door.
Aug 17, 2009 | GE Refrigerators
Ice and frost
Excess frost especially near the door is caused by door gaskets being bad. The gasket should hold a dollar bill snug.
Another possibility is auto defrost failure. - Remove the cover on the rear inside the freezer to see if the coils are heavily iced.
Aug 13, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Refrigerator
If the ice build up is only on the back panel of the freezer then you have a defrost problem. Most likely a defrost thermostat or control board/timer. If frost build up is around the walls of the freezer then warm air is getting into the freezer. Most likely cause of this would be gaps in or torn door gasket or door alignment. In some cases the door was left cracked open. If gasket and door alignment is ok remove the frost and see if it comes back.
Oct 05, 2007 | Jenn-Air JBR2088HES Stainless Steel Bottom...
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
