This particular error is caused by corrupted data easiest way around this will be to install the update via a usb flash stick.
you can download the update here http://uk.playstation.com/ps3/support/system-software/detail/item541668/Update-features-%28ver-4-31%29/
this link will explain how to update via a Usb stick http://www.ps3news.com/forums/ps3-guides-tutorials/how-install-ps3-firmware-memory-stick-99095.html
Please only use the first to download the firmware only ever trust official sources.
PlayStation
Sep 8, 2013 - 10 posts
Re: Error 80710723 PS3 won't update any of my games. ... Then I tried and thinking it would stop( and it was a long download time) I decided to leave ... that is what exactly is happening to me i own a regular ps3 slim, after i ...
GameSpotMy games won't update (Burnout to 1.1 and Warhawk to 1.2)... I am signed in to ... If anyone knows it'd be nice to tell me whats going on. .... My ps3 every time i try to play a game online it asks me to update the game as it found new software.
Have you tried to install the update via USB thumb drive? I recommend installing the update from the "safe mode" menu. I will post a link to get you started. Good luck! ^^ How to Update PS3 with USB Safe Mode
The error code your getting is saying that your PS3 is failing to update. You can disconnect your system from the internet, turn off automatice updates and try it manually or you can try loading the update through the PS3's safe mode. This link will show you how to get your PS3 into safe mode. https://support.us.playstation.com/app/answers/detail/a_id/1488/kw/Safe
that happens to me on every update but what you have to do is be patient and try it a few times untill it does it all and i would recommend doing it during the night when your sleeping can get very boring during the day
Generally what happens is that progress will stall whilst you are trying to update the firmware or software/games on your PS3, causing it to be corrupted. Your console is then unable to function properly, and you are left trying to "pick up the pieces" as it were. The PS3 error 80710723 is one of these system update errors, and is often experienced by gamers who use wireless connections to update their firmware or games.
So how can you fix PS3 system update error? Here are a few steps you can take to try and fix the 80710723 error code yourself.
In your System Options/Network Settings you need to go and disable a setting called "media server". Doing this has been reported to fix the PS3 system update error in a number of different cases.
If you are using a wireless network connection then switch to a wired connection and attempt to update your console. Wireless connections can have interference, or fail from time to time. Therefore it is better to use a wired Internet connection where possible.
As a last ditch resort you can actually download the update from the Sony website onto your PC, then load that update onto a USB stick and plug it into your PS3 and carry out the update process from there. However, it is best to actually try and fix your connection problems first.
you need to give us the error, nobody can guess the issue my friend please give more details or just put ps3 error code (fill in the blank with your code here) into google and search for what it is very simple :P
load the software from ps3.com and make sure what ps3 you have then make PS3 folder and insaid put UPDATE folder then put the file you loade from the websit PS3UPDAT.PUP then put it in flash memory go to update in your machin thin chois update from devic that's it I am sorry my english wraiting not will
that is a update error. try going to the official ps3 site and download the latest update onto the stick then update the ps3 via storage media. it may take a few attempts but it should eventually work
could be corrupted file, try to download again..copy to a pendrive correctly formated..put the update file and try to update again..good luck..try with another pendrive...
