Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I push wall button and hear clicking but won't open
I have a Craftsman 1/2 HP that just stopped about1 ft from closing completely. Now when I press the wall button, all I get is a series of clicking but nothing happens. Also the light but clicks but lights won't come on. The "indicator light" (green) gives me a series of 5 flashes with a pause inbetween. I am getting power to the unit. Any help?
  • datadoc8 Jan 11, 2009
    I am having the same exact problem. Yesterday, I added a wireless keypad and last night all of my remotes, including the wall remote, were working fine. I went out this morning and opened the garage door with the wall remote and when I tried to close it with the remote in my car, It wouldn't work. Now nothing works, including the lights on the unit.
  • sedmunds Jan 12, 2009
    I tried unplugging the unit hoping to "reset" it and plugging it back in....no luck, same problem.
  • 16 Answers
Try unplugging the operator. This may reset any problems you had.
Posted on Jan 12, 2009
Push buttons on remotes won't raise/close lift master mod 81lm
Check to see if the light in the wall control is flashing. If it is press and hold the lock button for 3 seconds.
Jun 13, 2012 | Sears Craftsman LiftMaster Chamberlain...
My craftsman 1/2 hp garage dood does not close when it's cold out (with either a push on the remote or a single push from the wall). I have to hold the wall button in until it's completely down. When I do...
Make sure the brackets for the sensors are tight and the small light on the sensors is not blinking ever so slightly. You also might try shading the sensor so that the sun is not shining directly into the lens.
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: My craftsman 1/2 hp garage dood does not close whe...
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not close, moves 2 ft & returns
Make sure you put the black cup back onthe end of the motor shaft and that it is pressed all the way on.Make sure the RPM sensor is plugged in. If neither of these are theissue, then you probably did not have the motor shaft pushed all theway back when you tightened the coupler after replacing the wormgear. Loosen that coupler up and from the front of the motor(opposite end in which the coupler is on) push the shaft back as faras it will go. Hold it there while you tighten the coupler back upand then try it.
Nov 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
When I push the button it only runs for 1 sec and stops...even with the door manually removed from the track system..I have a craftsman 139.53603 opener.
my craftsman garage door open about one ft and stop when i try to push the wall button or the remote pad it completely stop working
Oct 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
IS THE UNIT JAMMED AGAINST THE STOP BOLT ON THE RAIL??
IF IT IS THE CHAIN WILL NEED TO BE RESET RECHECK YOUR INSTRUCTION SHEET.
IF NOT DOWNLOAD THE INSTRUCTION MANUAL FOR YOUR OPERATOR AND GO THROUGH THE DIAGNOSTICS.
HOPE THIS HELPS
Mar 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programming kepad for Sears Craftsman Garagedoor opener 1/2 hp
The only procedure I have ever followed is to press the learn button and then enter the code, and not do anything else. I think your last step of holding the button until the light goes out is clearing codes as fast as you enter them. Just stop after you enter your code and let the learn mode time out on its own. That should do it.
And don't put your head through the wall. It just causes more headaches.
Feb 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
121 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
