Question about Gestetner Office Equipment & Supplies
Solutions for "error code sc 547" problems
Error code sc 547" problems
drichards
  • 87 Answers
SOURCE: code SC 547 00
SC 547 is a fuser problem. Press clear modes, 1, 0, 7, and press and hold clear/stop/ Enter copy sp. Select 5 for mode. exit all of the way out, and recycle the power. If something in the fuser is bad, it will do it again. If it comes to ready, then the thermister is probably dirty. As for the door, make sure all are closed tight, including the lower right door.
Posted on Mar 28, 2008
SOURCE: sc 547-00 error code
Call a tech. Fuser error, can only be reset in service mode after the problem is fixed
Posted on Mar 31, 2009
ricohmaster
  • 10 Answers
SOURCE: sc code 547 power supply failure
you can go to tech mode by pressing clear(yellow button) 1 ->0 ->7 then press and hold clear/stop button(red) then go to copier then select data logs the look for the reset sc/jam counter the shortcut is 7-807. select execute and restart the machine, if you dont find it look for in the copier then modes then look for sc code reset, the shortcut is 5-810, maybe it would be better if you solve first the noise issue, probably the assembly on the fuser unit is not properly done.
Posted on Jun 11, 2009
M2Tech1
  • 313 Answers
SOURCE: Error code, SC 547 on a Ricoh Aficio 1075
have you tried sc reset through the service mode and then turn off .. you can get to this by pressing yellow clear button then 107 then hold down the cancel stop button..wait for the screen to change then go to mode 5 and you need to arrow down to sp 5 810 sc reset execute turn off the copier and try turning on to see if it clears.. if not the ac board maybe defective caused by a power surge or static down the line..
Posted on Aug 05, 2009
  • 990 Answers
SOURCE: I have lanier 5218 which
Hello sir; Let's do a reset procedure; press "clear mode" enter 107 then press "clear/stop" key for 3 second, then select copy sp, enter 5810 to reset.
Posted on Aug 29, 2009
Help with error code SC547-01
sc 547 mean fixing unit error ,you can reset by simply getting into simulation mode and then switch off an the machine ,getting into the simulation mode is simply by pressing 107 and press and hold c ,
Jun 19, 2013 | Ricoh Aficio 450 Copier
How can I reset a SC 547 error on a Ricoh Aficio SPC 811 DN? I've already replaced the fixing unit.
Hi
Error code sc 547 means "Zero cross signal malfunction". This error appears due to a faulty power supply. This error code may also appear if the input board is defective or the BIC Unit is defective. Turn off the printer and unplug the printer for 30-40 minutes and check if the error still appears. If you see he error still appearing then try and rest it using the following reset method--
To reset the SC code by entering SP5810 and select 1.
Now hold down the photo mode key and the # key at the same time for at least 3 second.
Then turn the machine off and on again.
If the same issue still appears, you'll need to check and replace the Power supply or the Input (IOCC) boardt.
Hope it helps...
Oct 11, 2010 | Ricoh Aficio 150 Copier
I HAVE A PROBLEM WITH MY COPIER,NASHUATEC D435.
Enter in the service mode(SPmode),open the front cover and turn OFF the copier.Unpluged the machine,wait 10sec.amd pluged ON.Before clean the thermistors and thermofuses in the image fusing unit.Close the front door and turn ON the copiers.
Feb 08, 2010 | Ricoh Aficio 450 Copier
Error code facsimile error red wrench sc547 ricoh aficio 180
there may be a problem with your electric supply(wall outlet) , wrong voltage or power supply bad
Jan 07, 2010 | Ricoh Office Equipment & Supplies
I have a nashuatec D445 and it is indicating an error code CS 547-00 what can i do to solve this problem?Please help.
Press 'Function Clear', 1, 0, 7, then press and hold 'Clear/Stop' button for 3 secands. Machine displays SP Mode. Now turn MAIN power switch off for 5 seconds. Turn MAIN power switch back on. This should reset SC 547 code. (Main power switch is located on the left side of the copier)
Dec 15, 2009 | Ricoh Aficio 450 Copier
I have lanier 5218 which has been down, showing error code sc 547 (we have a brownout prior to this happening) is there a reset code
Aug 29, 2009 | Office Equipment & Supplies
Aug 05, 2009 | Office Equipment & Supplies
Sc 547-00 error code
Mar 28, 2009 | Gestetner Office Equipment & Supplies
Code SC 547 00
Mar 28, 2008 | Ricoh Aficio 450 Copier
46 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
