Question about White Sewing Superlock 2000 ATS Mechanical Sewing Machine
White Serger 1934D not stitching
After replacing a broken needle, my serger only makes the holes of the stitches, but nothing else. I tried cleaning, rethreading, and replacing both needles. Is there anything I can do short of taking it in for repair?
No, Sounds like the loopers are not passing properly to pick up the thread, from off the needles.
Posted on Jan 12, 2009
I am new st this but my serger will stitch but the left needle thread will not join the others why ?
It could be that the serger has an independent left needle. Some older sergers were. Built like this so that a single stitching line with an overcasting stitch beside it. This is so that you can stitch a garment with a single stitching line and an overcast edge beside it instead of having to do two operations.
Oct 10, 2014 | Sewing Machines
I have re-threaded, changed needles, adjusted the differential and cutting width but cannot sew a single seam without the stitches skipping, sometimes several in a row and sometimes only one.
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
5. are the needles the correct ones for the serger
6. Possible timing problem--need to be checked at a sewing machine shop
Sep 18, 2013 | White Sewing Speedylock 1600 Mechanical...
Singer Stylist 11 Serger problems with right need skipping stitches how can I solve the problem
Jan 04, 2013 | Sewing Machines
My needle broke on my serger and i replaced it and now wont make stitch. please help
some times when you break a needle in a sewing machine or
serger it can cause the machine to jump time, it would be a good
idea to have the machine checked for a timing problem or to see
if when the needle broke it caused a problem with another part in
the serger.
Nov 12, 2012 | Sewing Machines
My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
Sep 02, 2012 | Juki MO-655 Mechanical Sewing Machine
Jukie serger skipping stitches
have you tried changing the needles?
if you have changed the needles & it's still skipping stitches the serger needs to be serviced
Apr 16, 2012 | Sewing Machines
Serger won't chain off a stitch. Stitches won't chain and hold to fabric. Added new needle, rethreaded whole machine. Stitches won't connect to fabric or make a chain.
is it possible that the needles are in backwards?
it's very possible that the machine is out of time & would have to be taken to a sewing machine repair shop to be retimed
Apr 02, 2012 | Sewing Machines
My Evolve serger is skipping stitches while using the 4 thread safety stitch which is a chain stitch with a two thread overlock. Sews fine for a few stitches and then skips a loop which unravels. I checked...
First, change the needles making sure to use the el705 needle system. Second, make sure the subsidiary looper is engaged properly (plugging up the upper looper hole). Also make sure the needles are all the way up in the machine. This should do it or it may need to be adjusted but the Evolve is a very, very reliable machine. Hope this helps...
Nov 20, 2009 | Baby Lock Evolve
Coverstitching on White Speedylock serger
Your machine cannot do a cover stitch. Check the Brother website, they make a cover stitch only machine, it works much better than any of the serger/cover stitch combination machines, and it is a lot less money.
Nov 19, 2007 | White Sewing Speedylock 1600 Mechanical...
White Sewing Superlock 2000 ATS Mechanical Sewing Machine Logo
516 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
