2003 Toyota Camry Solara Logo
Posted on Jan 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to change both serpentine belts on a 2000 toyota camry. cannot locate pivot bolt to change the power steering belt. can you help?
Anonymous
Level 2:
  • Expert 61 Answers
  • Posted on Jan 29, 2009
Anonymous
Expert
Level 2:
Answers
61
Questions
Helped
21019
Points
145
Their should be a diagram in the front of the engine compartment. Their will definitely be a diagram in the owners manual.
Power steering belt
pump.
with all belts. made.
1: pulley's not aligned.
2: the P/S pump is loose, or missing 3 points pivot mounts or bolts.
3: the pump is seized, (spin by hand ,no resistance is good) or loose bearings.
4: belt is from china. (no-name belt)
5: belt is bad, internal structural damage .
or you have grimlins,(tiny evil critters that remove things) see movie.
in twilight zone, old, scary.
I need to replace my alternator belt in my '91
you will need to loosen all bolts in order for it to move but the pivot bolt will be sitting in a metal channel on the alternator bracket
Toyota camry 1991 4 cyl auto power steering belt has come off pulley how do I get it back on?
There is either a pulley that acts like a tensioner or the pump will pivot when loosened. Look for slots on the pump and pulley brackets. Loosen bolts, install new belt, tighten belt then bolts. As an additional note, there is likely something else wrong (that is why the belt came off).
3helpful
I'm trying to change the belts for my 92 tercel but some how cant find the tension pulley. Can anyone please help me. I need to change both belts.
It appears that your car is equipped with multiple v-belts, rather than a serpentine belt so there most likely aren't tensioner pullies. Here is some general info that may help.
Alternator To adjust the tension of the alternator drive belt on older models, loosen the pivot and mounting bolts on the alternator. Using a wooden hammer handle, or a broomstick as a prying device, move the alternator one way or the other until the proper tension is achieved. Do not use a screwdriver or any other metal device such as a pry bar, as a lever. Newer models use a tension adjusting bolt. Loosen the pivot bolt and the locking bolt, then turn the tension adjusting bolt until proper tension is achieved. Tighten the bolts securely, run the engine about minute, stop the engine then recheck the belt tension. Air Conditioning Compressor A/C compressor (always use caution when working near the A/C compressor to avoid damaging the refrigerant lines) belt tension can be adjusted by turning the tension adjusting bolt which is located on the compressor tensioner bracket. Turn the bolt clockwise to tighten the belt and counterclockwise to loosen it. Air Pump To adjust the tension of the air pump drive belt, loosen the adjusting lever bolt and the pivot bolt. Move the pump in or out until the desired tension is reached. NOTE: The tension should be checked between the air pump and the crankshaft pulley on cars without air conditioning. On cars with A/C the tension should be checked between the compressor and the crankshaft pulley. Power Steering Pump Tension on the power steering belt is adjusted by means of an idler pulley (some models may use just a lower adjusting bracket setup, similar to the alternator adjustment service procedure). Loosen the lock bolt and turn the adjusting bolt on the idler pulley until the desired tension is felt, then tighten the lock bolt.
5helpful
How to change serpentine belt on 207 toyota camry
4 cylinder diagram
6 cylinder diagram
Loosen the tensioner pulley to remove the belt. It is the one that has a long bolt running through it. Once you remove the old belt, install the new one using the appropriate diagram from the above two links. Readjust the tension using the bolt you loosened to remove the old belt.
i hope this helps
matthew
1helpful
Replace serpentine belt for 6 cylinder 4wd
Loosen the power steering pump rear mounting bolts, pivot bolt and lock nut and then loosen the power steering pump adjusting bolt. Slip the belt on and tighten the adjusting bolt until you can push the belt in about one inch midway between the A/C and alternator pulleys. Then tighten the lock nut, pivot bolt and mounting bolts and that's it.
It helps to diagrams to go with the instructions. Get yourself factory service manual, promanuals.net has them for around 20$ or so.
1helpful
How do I go about changing the small belt that goes to the power steering pump on 1998 Toyota Camry with the 2.2 engine
You need to remove the AC/Alternator belt first. There is a pivot bolt on the alternator that needs to be loosened. It faces toward the driver's side under the alternator. Then on top there is a long bolt that needs to be loosened. As it loosens push the alternator down and you will get enough slack to remove the belt.
For the power steering belt, remove the front passenger-side wheel. You will see a black cover(called a fender apron)- remove it. I believe the bolts are 10mm. You can now see the power steering pump- look at the side of the pump that faces the firewall. You will see another long bolt (similar to the AC/Alternator adjustment bolt), loosen it some and push the pump to get slack in the belt.
3helpful
Power steering belt on 1991 toyota camry
Locate the idler pulley. Loosen the nut in the center of the idler pulley. Then loosen the bolt that protrudes from the back of the pulley. This will let the belt go slack.
2helpful
I dont have a diagram to run serpentine belt to a toyota camry 03
Hi
Replacing Serpentine belt on a Toyota camry 2003—
Step 1--Examine the belt placement of your Toyota Camry fan belt so that you will remember how to put it back once you have removed it. Refer to the vehicle owner's manual for further information. Locate the pivot bolt on the front passenger side of the engine. Loosen the pivot bolt with a socket wrench.
Step 2--Loosen the adjustment locking bolt that is just below the tensioner pulley with a socket wrench, and then loosen the tensioner pulley to allow the belt to move free.
Step 3--Check the belt for any signs of cracking or irregular wear, so you can fix any problems that may exist with the pulleys. Remove the fan belt from the pulleys on the engine and take it out of the engine compartment.
Step 4--Wrap the new fan belt around each of the pulleys the same way it came out. When you have the belt in place, tighten the tensioner pulley with a socket wrench.
Step 5--Tighten the adjustment locking bolt and the pivot bolt with a socket wrench, and then look over the engine to check that everything is back in place.
Step 6--Turn the vehicle engine on and watch it for a few minutes to verify that everything is operating properly, then turn the engine off.
Please refer to these links for serpentine belt diagrams—
Serpentine belt on a Toyota camry Link 1
Serpentine belt on a Toyota camry Link 2
Please do accept the solution and revert for further assistance.
Thanks
Rylee
5answers
Need to take power steering belt off
the pulley that doesn't appear to drive anything is the tensioner
Robert
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
