Question about Garden
Where is the hydrolic filter on my kubota kx36 2a
    Top Expert:
  • Garden Master
  • 42,218 Answers
If it not a canister filter between the reservoir tank and the pump then it is most likely in the reservoir tank and will be a pleated type.. If it is in the tank it will be under the return hose line cover.
Posted on Oct 07, 2013
I just replace hydr. pump on a bx2200 Kubota tractor but it keeps blowing the filters apart . can you help me ?
connected the pipes to the pump incorrectly
filters go on the return lines or suction lines not the high pressure side of the pump
they are only good for a pressure of 30psi not 2000psi
Sep 02, 2017 | Kubota Garden
Ii have a 6640 branson tractor hydrolic fluid has beed changed all filters including internal filter . bailed two bails of hay lost all hydrolic presure again1 any sugestions
Did you fill the new filters with hydraulic oil before you put them back on. If not you will get air in the system which will cause the hydraulics to fail.
Aug 15, 2016 | Garden
I need parts list for Kubota excavator rx501
As you may well be aware, Kubota USA does not offer any support for your tractor. This is because that model is a "gray market" item (that has been banned for importation in 1997). Kubota initiated this legal action because the unauthorized importation, distribution and sale of Kubota "gray market" tractors by individuals or companies independent of Kubota adversely affected Kubota's reputation in the United States and with the United States consumer. Following an extensive evidentiary hearing in the Fall of 1996, the United States International Trade Commission affirmed a finding by the Administrative Law Judge that the importation, distribution and sale of these "gray market" tractors infringed upon Kubota's registered trademark, issued a General Exclusion Order prohibiting further importation, and issued various Cease and Desist Orders against the respondents. The Court of Appeals affirmed the Commission decision. Such "gray market" items typically are of inferior quality and/or workmanship.
However, you ca find what you need at 3rd party suppliers. Try this one: http://www.kenkidepotneo.com/cgi-bin/heavy_equipment_parts.cgi?category_type=&category=FILTERS&equipment_type=&equipment=&maker=KUBOTA&model=RX501&part_no=&page=
Apr 05, 2016 | Cars & Trucks
Where is the drain plug for the block drain on a Kubota engine V1902-B?
[PDF]KUBOTA DIESEL ENGINE - Waterax
waterax.com/app/uploads/2015/09/ENGINE-MANUAL-D902.pdf
engine maintenance. it is KUBOTA's policy to utilize as quickly as possible .... Be sure to close the coolant drain valve, secure the pressure cap. and fasten the .... Oil drain plug. (18) Oil ... around the machine. it may catch on moving (B) "OFF".
Kubota V2203 Block Water Drain? - Diesel Bombers
www.dieselbombers.com > ... > Diesel Engine Conversions
Nov 21, 2013 - On my Kubota V2203 DI above the Oil filter is a long bolt of which the only thing ... I did not even know that Block Water Drain was there till last night I ...Also, the pipe plugs in the engine are a Japanese style, but we've ... Kubota v2203 vsv1902, ziegler, Diesel Engine Conversions, 4, 01-10-2015 06:27 PM.
Kubota Engine Service Tips
johnsoncitykubota.com/Kubota%20Engine%20Service%20Tips.htm
If the reading is 11 volts or more while you are trying to crank the engine see the ...Other causes include defective glow plugs or low cranking speeds from a weak battery.... We have not seen it "ruin" anyone's tractor yet, so drain the tank, refill with ....passages between the cylinder head and the block became 90% blocked.
Kubota L2550 needs block heater! - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tractors
Jan 25, 2011 - 25 posts - ‎14 authors
Oldmax, I could swear I was looking at a closeup of my engine, except for the colour.... V1702, V1703, V1902, V1903, V2003, V2003T, V2203 (4 cylinder) Part No. ... BSeries (Except 2 cylinder) Part No. Watt Volt Diameter Type .... Paul, does the tractor have a block drain plug, and a thermostat bypass ...
Jan 06, 2016 | Cars & Trucks
Kubota troubleshooting
could it be low on hydrolic fluid
Aug 16, 2014 | Garden
Kubota m59 hyd system not strong
Check your hydrolic fluid. If low, be sure there are no leaks. If your fluid is topped off and there are no leaks then your pump may be going bad.
Sep 16, 2013 | Cover My Tractor Tractor Cab-Enclosure for...
I have a small kubota tractor -L1800DT -deisel motor. It starts but stops a rter a fer seconds running, . When it does go, it slowly fades in power and stops. I have replaced the fuel filter which was...
Andy, a couple of ideas for you: first, check to see if there are two fuel filters. Some Kubotas have one filter in the engine compartment, but another one under the chassis. If you only changed one, you could have another one still plugged up. The other problem that would cause the engine to lose power shortly after starting would be a dirty air filter, so check that too. Good luck! Please rate my solution if helpful, thanks.
Aug 09, 2010 | Woods Kubota Bx 24 Bx 23 Bt610 Bh75 And...
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
