Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
Tecumseh 8 hp problems
I have a 8hp tecumseh snow thrower, it ran fine all morning went to fire up later will run only in idle position and very rough, hit throttle and dies out, changed plug, starts easier but still runs rough
    Sniper:
  • 87 Answers
I had exactly the same problem, I tried to clean the carb several times without any luck. I gave up on the carb as it was an EPA style without adjustable mixture needles. Bought a new carb for it, installed it and the engine fired up right away. Took me 10min to let it warm up and dial the mixture, it has been fine ever since.
I recommend to buy the replecement carb old-new stock mfg pn: 632334A Tecumseh Carburetor with mixture needles
This place helped me out with one.
Posted on Jan 17, 2009
    Problem Solver:
  • 12 Answers
First off ,how old is the gas????? If it sat over the summer, meaning almost a year with gas in it. You will need to rebuild the carb or buy another. If you want to save some dough and like to tinker, rebuilding is the way to go. Just go out and buy some chem-dip at your local auto parts store and a rebuild kit for the carb at the local small engine shop or whatever place you can find. Tear the carb down, place all the metal parts including the carb in the basket "excluding the plastic and rubber parts" and let them soak for 2-3 days. Then you rinse all the parts including the carb with warm water and use high compressed air though all the orifices to dry the carb and parts off. Then re-assemble, It's really easy and it saves you money, not to mention, it's self gratifieing that you did something yourself and it works!!!!!!!!!
Posted on Oct 13, 2009
  • Bad Arrs Dec 11, 2010
    Although I agree with the previous posted comnments, It may also be that the valve under the gas tank is not fully open, the filter in the tank is clogged, or the gas cap vent hole is plugged. If gas was left in the tank all summer the filters can plug up.
    Scholar:
  • 76 Answers
You may need to clean the carb or possibly put in a rebuild kit, also how old is the fuel? Old fuel will also cause it to run bad ( old fuel meaning more than 30 days old), they say the fuel we use today has a shelf life of about 14 day's then it starts to go bad.
Posted on Jan 12, 2009
  • 1,524 Answers
Tankfilter first sludge can be on the bottom inside the tank a canister cleanup engine cleaner Tecflow or an other brand of fuel (engine) cleaner second is to clean the filter of the fuel-tap and the thirth step is the float chamber and the nozzle inside the carburetor and the last step control the gaskets and airfilter thats in most cases enough the little channels for idle speed could be clogged in the carburetor then spray it for a day or 2 with a good startcleaner or help it on the move with an engine starter spray ,but one time only if all the parts are controlled always its good to control the movement and the of the pushrods and also the oil level ,oil monitoring for ignition and also the colour of the spark of the sparkplug. thats normally the way , but in this case because it runs good and after a while there is arisen a problem i read after a good functional engine what i am thinking on possible loose of compression by mechanical compression release or gasket overheat by run out of oil the oil level control is having a protection ? its also a suggestion in that case
Posted on Dec 18, 2016
    Problem Solver:
  • 6 Answers
Check all the adjustments for the motor to drive wheel engagement from your handle. I think you will find that you are starting with the wheels engaged. You handle is not disengaged. As a test only, turn the wheel speed lever down to the very lowest setting and then start. If it does start be careful because if the wheel speed is set too high the blower will operate but the drive wheels will not disengage after you release the handle and there is no brake . You will only be able too stop it by shutting off or reducing the motor rpm. This is a dangerous situation.
Posted on Nov 23, 2014
What is sparkplug gap on 8 horse tecumseh snow blower
Clif - I have two items in my garage with Tecumseh engines on them in that HP range and they both specify .030 spark plug gap in the instruction manual.
Dec 03, 2013 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Yard machine snow blower wont move wheels locked up model 31as6fee729
check for rusted shafts and or bearings as you use this machine a few times a year in the worst possible conditions and the rest of the time it sits idle in the shed.
Jan 29, 2013 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
8 hp tecumsch engine for snow blower oil comes out the side vent tube when running
replace the oil breather filter and make shore you did not over fill the moter with oil
Jan 16, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Our HMSK 80-110 electric start snowblower starts up right away, but the idling is very rough. It runs very smoothly when it is engaged in snow throwing.
The Tecumseh snow motors are notorious for idling rough. Especially the last few years of production. Most service techs just say "live with it" But there are a couple of things you can do to help.
It is not a carb adjustment issue. It's usually a fuel, clean carb issue.
First, use a premium grade fuel without ethanol and a fuel stabilizer. This will give you the best fuel mix.
Second, Remove the carburetor shield and clean the inside and outside of the carb with carb cleaner. Even though you can't see the carb usually, they do get varnish build up and cleaning it will help some.
Third, Put the recommended amount of fuel system cleaner in the gas. I use Sea Foam brand. Over a tank full or two you will notice a difference in how the engine idles.
Fourth, Use a high quality spark plug and use a new one every year. Make sure the gap is correct.
Good Luck! Feel free to as any other questions you may have. Don't forget to rate this answer!
Jan 14, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
My snowblower Yard Machines 26" 8HP started but
Clean the carburetor and check the intake manifold to the head for air leaks/bad gaskets.
Jan 13, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Gas flows freely out the carborator pn 632351 on a tecumseh 8hp
needle and seat valve stuck open remove float bowl and find the cause
Sep 27, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Rope snapped in my recoil starter..
take off the and and turn the coiler on the inside a few turns and when it starts to get tight put a screwdrive through it so it wont spin, put the rope in the hole and bring it out and tie a knot. the turn it gently to release the screwdriver and let it coil the rope back in
Jan 13, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
5,673 people viewed this question
Top Tecumseh Tools & Hardware - Others Experts
John Trevino
J.D. Browning
J.D. Browning
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
