Question about Motorola Mobility HK100 Bluetooth Headset
My hk100 will not come on and when i charge it the red light jus blicksa nd will not charge
I have it on the charger for a couple of hours and the red light jus blick and when i take it off it still dont comes on
5 Suggested Answers
  • 18 Answers
SOURCE: headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Posted on Sep 04, 2009
  • 274 Answers
SOURCE: Bluetooth is plugged into charger
It is charging when the red light flashes.
After it's full, the light will not flash.
electronics wholesale
Posted on Nov 16, 2011
vqcb43
  • 1623 Answers
Mobile Phones and Acessories
    Verified Fixya Pro
    SOURCE: I have a H680 ear piece newly removed from box.iam unable to charge it although the red light comes on when placed on charger it fades away within seconds have left unit on charger for at least 3 hour
    James
    Sorry you are having an issue. Have you tried another charger? If so and it still doesn't work. CONTACT US . If you have proof of purchase that it was purchased new less than year ago then we'll replace it.
    Mark
    Motorola Support
    Posted on Dec 24, 2014
    vqcb43
    • 1623 Answers
      Verified Fixya Pro
      SOURCE: Why can't I charge my headset
      James
      Mark
      Motorola Support
      What can cause this issue
      if the battery is older than 1 year replace the battery with a new one , also I know its difficult but try to not charge a battery till its dead , short cycle charging of battery's kills em fast if battery is less than 1yr contact Milwaukee its still under warranty
      May 27, 2016 | Dewalt Drills
      When the walkie on full charge the charge light is not going to off ?
      If your battery is flat or close to, then a complete charge is ussually 23 hours. or thereabout, so this is why the light on your charger is still on. The light for a flat battery is red and when the battery is fuuly charges light is green.
      8 hours of charging a flat battery, isn't enough, hence the light staying on RED, if I'm not wrong and I doubt that I am.
      I hope this has answered your query.
      Best regards,
      Peter
      Oct 09, 2012 | Kenwood KSC-15 - 8 Hour Charger
      Though my Worx WG781 cordless 36V, 19 inch lawn mower came with what appeared to be a fully charged battery according to the battery LED lights , it is suggested that it be put on the charger "over...
      Could be.Those batteries leak charge even when not in use.I would let it go for 24-48 hours just to be sure.Unless the batteries or charger becomes very hot.
      May 20, 2011 | Worx WG788 19Inch 36 Volt Cordless 3In1...
      Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
      Completely wrong. Quoting from the user's manual:
      "The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
      After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
      If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
      Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
      So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
      Apr 23, 2011 | Garden
      Drill not working, not sure if baterry is shot or charger is bad .Baterry on charger for couple hours and no charge, red light on charger not lit
      If he light on the charger is off, then your problem is almost certainly the charger. If you can get a working battery from a friend or someone, try that and if the light stays off you've confirmed the charger is bad.
      Apr 21, 2011 | Milwaukee Drills
      What does the flashing red light mean?!?
      The flashing red probably means that the charger is working correctly and is indeed charging the batteries. The light should turn green when charging is complete after anything from 1 to 16 hours depending on how this charger works.
      Do the following test: Fit the charger with your batteries and connect it to the mains. After 1 hour check if there is a detectable temperature rise in the batteries. You can do this without interrupting the charge cycle by touching the cells with the back of your fingers. If the temperature is still low, let it continue for another 15 hours or so, checking every now & then for any temperature increase. Should the temperature rise more than a few degrees, then stop the charging by removing the charger from the mains. Should the red lamp remain flashing after 16 hours, then I suspect you to have a defective charger.
      Dec 27, 2010 | Duracell AAA NiMH Battery Charger with 4...
      Brand new motorazr V3s. draing batteries. only 3 hours of use
      HEY THOSE CHINESE CHARGER ARE NOT GOOD.. THEY SUM HOW NEVER CHARGE THE BATTERY PROPERLY ND THE BACKUP IS LESS. CHARGE USING UR MOTOROLA CHARGER ND IF U STILL EXPERIENCE PROBLEM THEN U BETTER GO TO MOTOROLA
      Aug 16, 2009 | Motorola Mobility RAZR V3
      Headset not charging
      Aug 14, 2009 | Motorola Mobility H500 Wireless Headset
      Mx 3000 universal lcd remote
      There are 4 reasons why your unit is behaving this way:
      1. Charger is the problem.
      2. The docking station is the broken.
      3. The battery is broken or not accepting charge.
      4. The actual unit is the problem.
      It is very hard to tell which one is causing this to happen.
      Let us do some troubleshooting first:
      1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
      2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
      3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
      4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
      5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
      12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
      Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
      Motorola Mobility HK100 Bluetooth Headset Logo
      91 people viewed this question
      Top Motorola Mobility Radio Communications Experts
      Coss
      Dennis
      Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
