Question about Microsoft Office Professional 2007 Full Version for PC
Word & Excel won't open files when doubleclicked in Windows Explorer
When I look up a .xls or .doc file in Windows Explorer and double click the file, the Excel or Word programs open, but the file itself does not open. Obviously, the file association is correct, because the correct program opens. The file opens correctlyif I start Excel or Word first, then use the File:Open commandfrom the menu or by keyboard shortcut Ctrl+O.
This problem does not effect any other file type in Windows Explorer. All other programs, including Publisher, start correctly and open the file as well. Does anyone know why these two programs do not open files with a doubleclick, and how to fix it? Ever since I installed Office 2007 under Windows Vista, my double-clicks on any Office file correctly opens the application, which promptly says it cannot find the file. If I then go to the file Open, I can successfully open that file by browsing. This applies to Word, Excel, Powerpoint equally. What gives? The association is correct by the way. same problem with word 2007, but not with excel
    Problem Solver:
  • 13 Answers
Try to uninstall and re-install the MS office 2007. Hope this can resolve the problem
Posted on Jan 12, 2009
How do I open an .xls file in 64-bit version of excel without it being in protected view?
I was like that when the problem exists when double-clicking in Windows Explorer. Then I get the message that the program isn't responding and have the option to close or wait. After a few moments Excel does eventually open and I can work on the file. I do not have the problem when I open the file directly form Excel.
Read here, perhaps this article will help you - Excel Restore Toolbox http://www.excel.restoretools.com/
Apr 25, 2015 | Microsoft Excel for PC
Excel file problem
Two possibilities:
  1. You accidentally save it as an HTM or HTML file. It will still open in Excel if so. Open the file in Excel and do a Save As back to an XLS (Excel 97-2003 version file) or XLSX (Excel 2007 - 2013 version file).
  2. You associated XLS or XLSX files to be opened with CometBird. If so, right click on the file and choose "Open With," then go to the bottom of the choices and left-click on "Choose default program..." Then choose Excel and you should be all set. Windows will reassociate all your files to automatically open with Excel instead of CometBird.
Apr 18, 2014 | CometBird
How i recover my demages excell files
Close down Excel, re-open it and try to open the file again.
If this doesn't work, restart the computer, open up Excel and try to open the file again.
If this doesn't work, delete the contents of your c:windows emp directory then reboot. Try again
If this doesn't work, open Excel in Safe Mode. This will disable VBA and Add-ins.
  • Click on Start then Run then enter (including the quotes and the /s extension): "C:Program FilesMicrosoft OfficeOfficeexcel.exe" /s ["C:Program FilesMicrosoft OfficeOffice10excel.exe" /s (for Excel 2002, Office XP, click cancel if the MS Office Installer starts, Excel in safe mode will still start)].
  • Try to open the file.
If this doesn't work, be sure to scan the file for viruses. If you don't find a virus, find the file in Explorer, right click on it and rename it, replacing the .xls extension with the .doc extension. Try to open it as Word document.
If this doesn't work, try to determine if the file is unrecoverable on the disk. Open the file in Explorer and try to copy it to another location.
  • If you can copy the file to another location, skip to step 9. If not, the actual sectors on the disk may be corrupted.
  • If the data is valuable enough to you, seek professional services as a damaged hard disk file recovery is not for the faint at heart.
If the recovered file won't open or you could copy the file to another location, try to open the file in a more recent version of Excel. As the version numbers increase, their ability to recover corrupt files increases. If this doesn't work or such a version of Excel is not available, see if some other spreadsheet application is and try to open the file in that program.
If Microsoft can't help you (see the tips section) and you've exhausted all the free methods above for damaged disk recovered or copyable files there are a number of excellent commercial applications which will recover your files almost immediately.
http://www.repairmyexcel.com/
Dec 10, 2010 | Computers & Internet
Can a PDF be created from an Excel document? And
yes it can.. just download xls to pdf file converter.. it can convert xls, doc files to pdf file. Or you can simply convert it using the internet. just type to any search engine this keyword "xls to pdf convert"
Oct 23, 2009 | Checkmark MultiLedger for Mac/Windows...
A 2 MB xlsx file is taking long time to open and save - consuming 50% of CPU - making Excel screen go white - using 55 MB RAM - auto calculation off - any ideas to resolve this
Solution 1.) If you have installed PDF maker, which can get installed when you install scanner software, the Excel add-on can potentially cause Excel to open slowly. This is more common in Office 2007.
* Close Excel and any other window you have open
* Open "My Computer" and browse to C:\Program Files\Microsoft Office\Office12\XLSTART
* When you open Excel, check to see if the time it takes to open the xls/xlsx is shortened.
Solution 2.) This can be fixed by reinstalling Office but there is a faster way to fix this .
* Go to your Control Panel, (click on Start then Click on Control Panel)
* Click on Folder Options, then File Types,
* scroll down to and select (DOC for Word files) or XLS (for Excel files),
* click Advanced and select Open entry,
* click the edit Button.
* deselect "Use DDE"
* append "%1" (include the quote marks) to the end of the application command line,
* Remove /dde if it is at the end of the command line
* Then click on OK three times.
If the issue was being caused by DDE, then when you now open a Word doc file or Excel els; they will now open faster, without a long pause.
Aug 14, 2009 | Microsoft Office Excel 2007
Sir help me: im not able to open my excel files directly,i need to open of one sheet of excel before i open the files,please help me in my case... thanks and more power!!
There might be a problem with you file association for '.xls'.
You can check this from Windows Explorer, on the menu bar choose Tools >> Folder Options... >> then select the 'File Types' tab.
Look to see if Excel is the default program to open the '.xls' file. At the bottom portion of the window, it shows 'Details for...' and 'Opens with'. Just associate it with Excel.
**Note: This may not be possible if you are NOT the administrator of your PC system.
Hope this helps.
Jul 03, 2009 | Computers & Internet
In Microsoft Excel 97, on the Tools menu, click Options. Click the General tab. Clear the Ignore Other Applications checkbox, and click OK.
In Excel 2007, Click Office Button, Excel Options, Advanced.
Look for General.
Clear the Ignore Other Applications checkbox.
Now, as to why this was checked in the first place, ewan ko na!
Dec 19, 2008 | Microsoft Office Professional 2007 Full...
Excel may have "Ignore other applications" selected. See THIS Microsoft Knowledgebase Article.
Try going to Excel Options; Advanced tab; and under the 'General' heading: uncheck the box that says: Ignore other Applications that use Dynamic Data Exchange (DDE).
Dec 02, 2008 | Microsoft Office Home and Student 2007...
reinstall - there must be administrator issues on your computer.
Oct 29, 2008 | Microsoft Office 2003 Basic Edition...
WINDOWS OFFICE FILE RENAME PROB.
When you rename a word file you need to keep the .doc file extension for it to open again in word. .xls for excel etc.
You may not have the file options visible in windows explorer. Go to tools > folder options > view and untick "hide file extensions for known file types.
If you mess it up you can open via windows explorer. Right click the file and choose openwith and select the appropriate program.
Feb 28, 2008 | Microsoft Windows XP Professional for PC
Microsoft Office Professional 2007 Full Version for PC Logo
277 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
