Question about Makita Tools & Hardware - Others
Makita 5010 will not work in random orbital mode
I have a Makita 5010 5'' random orbital sander that has been working fine until this morning. It now rotates at a high speed only but will not go into a random orbit mode as before. Any help would be appreciated. Thanks.
Rick Cabot
  • rmcabot Jan 13, 2009
    Thanks for your help. The sander is working just fine again.
    Regards Rick Cabot
  • Anonymous Mar 13, 2014
    DeWalt Variable Speed Random Orbit Sander Model DW423 service manual
  • 2,176 Answers
It sounds like the bearing in thee bottom plate is seizing. If you turn the pad by hand does the motor turn. It should be smooth. I would look at that. The bearing number for Makita is 211236-8 or if you can get a generic bearing it is 6002DDW. Let me know
Posted on Jan 12, 2009
Makita orbital sander does not orbit with new pad
there is bit more to the pad than just attachment surface, please have look at this page: http://www.ereplacementparts.com/makita-bo5041-random-orbit-sander-parts-c-97_103_119063.html
your description suggest that there is no connection between pad and clutch, i would recommend to study the drawing, dismantle machine again and put it together again. where appropriate, use grease (i would suggest use of ptfe (teflon) dry spray grease on all moving surfaces and bearings), after service, use lowest possible settings, (disconnect filter! it is useless - use external vacuum if possible, connect to the pipe where filter was attached.) increase settings every minute or so till you have maximum.
lower the settings to your operational requirement and use as usual.
hope this will help you solve thsi little problem, if you find this answer helpful - do not forget to say so...
Dec 21, 2014 | Makita Bo5041k 5" Inch Random Orbit Sander...
I have been using a Makita random orbit sander model BO5010 for years without problems until I replaced the pad with a Porter Cable 13910, sold as compatible. Now the sander takes off, ie: increases speed...
HI, i have a feeling the pad could be the issue there. The genuine Makita one is designed for the motor, so unless the the replacement is exactly the same thickness, diameter, and weight then you will have problems. Imagine putting a small wheel designed for a car on a truck, that kind of issue. Best thing to do is to try putting the old Makita pad back onto the machine and see if that make any difference. (that is if you still have it) At work we have had similar problems where we have used non-genuine circular saw blades onto our Makita saws, and its has burnt the motor out.
Jan 13, 2011 | Makita BO5010 5" Random Orbit Sander
Hi, my BO5010 spins like a grinder if it is not held tightly to the workpiece, can it be fixed? Thanks, Ope.
Just under the sandpaper pad is a bearing that allows the pad to work as an orbital, that is it can turn freely, independently of the armature. If enough sawdust builds up around or inside this bearing the pad will spin like you describe and this is a fairly common problem with orbital sanders. You need Makita part number 211236-8 or a bearing #6002LL. It's fairly easy to replace; remove the screw in the center of the pad and remove it. Depending on which is tighter, the bearing will either be in the back of the pad or it will stay on the armature. Pry it off/out of the sander. Reassemble everything with the new bearing and you'll be back in business.
Dec 30, 2010 | Makita BO5010 5" Random Orbit Sander
Disc won't adhear to pad
I have had this happen twice (I use the sander quitder e a bit.) The sander pad needs to be replaced. Dixieline (Probuilders) stocks them or you can or order it on line at http://www.ereplacementparts.com/makita-bo5010-sander-parts-c-97_103_112.html .
Nov 28, 2010 | Makita BO5010K Random Orbit Sander, 2 Amp,...
I need a new pad ours is worn out. makita 0125mm B05010 120 volts 532117A 8 wholes.
Buy from one of the many on-line parts sellers. Or do a Google search and you'll find hundreds.
Aug 06, 2010 | Makita BO5010 5" Random Orbit Sander
Orbital sander doesnt orbit!
Never start the Sander without first placing it against the surface to be sanded. In free air the Sander will not osolate.
Jun 12, 2009 | Makita BO5010 5" Random Orbit Sander
Makita 5" Random Orbit Sander
The armature windings have an overlay problem in the wiring causing this and there is no soluation except to replace the armature which is not cost efective unless you are still under Warrantee and get a free replacement, it will burn up at some point. If you bought it within the last month take it back and get a new one, over one month, pack it back up in the original box and send it to address in the owners manual for repair or replacement service addresses.
Feb 19, 2009 | Makita 5" Random Orbit Sander
Makita random orbit 5". The pad flew apart. Is it replaceable ?
Usually there are 3 screws holding the plate to the eccentric assembly. The pad is formed to a metal plate and is sold as an assembly. You can go to Makitausa.com with the model number and get a replacement pad.
Feb 07, 2009 | Makita 5" Random Orbit Sander
Tools & Hardware - Others Logo
419 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
