Question about Nordic Track NordicTrack A2550 PRO Treadmill
Won't fit through door to move to another room
Need to move this massive machine to another room. No matter what angle I turn it at, it won't fit through door. Whats the best way to go about taking it apart in perhaps two pieces that will allow it to be moved?
3 Suggested Answers
Coachphil
  • 347 Answers
SOURCE: cant fit it through the door to move to another
Only 3 choices:
1 - leave it in place
2 - Take it partially apart so it will fit through the door
3 - Widen the door frame.
Since the treadmill got into the room, it should be able to get out. Most likely #2 is the option for you.
Posted on Dec 07, 2010
ercupa190
  • 12223 Answers
SOURCE: I just purchased this treadmill.
Please in the section open connections network give to repair, and the system will repair.
If the problem persist reboot the Modem-wireless router again, and see if the signal is coming more Strong.
Reset the Modem in the small hole, with some pencil introduce the pen and reset it
Retigh the wires coming from your Modem Wireless router. And finally Test again if is working. sincerely.
Posted on Dec 01, 2011
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
Door won't lock / cycle won't start
Check if the lock is binding or the door switch is not being operated.
May 19, 2013 | Asko W6221 Front Load Washer
The door on my Hotpoint Washing Machine WT741 won't open even though the programme has ended. We've tried running the programme again and pumping out but still the door won't open.
The door latch may have broken. You can sometimes open the door from the inside. You will know the door latch is broken if the door handle is floppy. If the door handle is not floppy - then the issue is probably with the door interlock. This is the electronic part that prevents the door from being opened during and after the wash has finished.
Either way - you'll need to get the door open.
To do this, unplug the washing machine from the mains and then move it out from where it is. Tip the washing machine to a 45 degree angle. Don't tip it over 45 degrees as you may break internal parts.
You need two people to do this - one person hold the machine at 45 degrees angle, whilst the other person puts their hand up into the machine - you should be able to feel the door catch mechanism and depending on the model, open the door that way. Sometimes the manufacturer has helpfully put a manual release inside - and sometimes they don't.
If you aren't able to open the door using that method. Get a length of strong string and poke the middle section of the string into the gap between the washer door and the machine body - to the right of the door handle. Use a flat headed screw drive to push the string into the gap, all the way around the door, so that you end up with the two ends of the string on the left hand side of the door. Now have someone put the ends of the string whilst the other person pulls the door handle. If the string is pushed in far enough it will release the door latch and the door will open. It takes a bit of persistence to get it right.
Once you have the door opened you can usually replace either the interlock mechanism or the door latch itself. Parts are easily available online from sites like espares and yourspares.
Mar 29, 2013 | Washing Machines
My Singer 5050 sewing machine won't let me
sounds like a part is damaged or jamed, the machine needs to be checked
to see what's wrong with it
Apr 14, 2012 | Singer Sewing Machines
My washing machine won't turn on, I moved it last night a couple inches and now it won't turn on.
check washing machine wire plug. turn it open and check the wires.
are they fix accordingly.
Dec 12, 2011 | Kenmore 44102 Front Load Washer
The drivers-side back door of my 1998 jeep cherokee won't close. The latch has turned too far and won't go back to it's open position so, unless there is some trick you can recommend, it will...
since the door is open,, hold the handle in the open position and try and move the little hook looking latch , it may have just moved into the closed position , if you can move it to the open position, then your home free
Jul 04, 2011 | 1998 Jeep Cherokee
Door light turns on when you start the machine but turns off a couple of seconds after that and the washer won't do anything. It's a frigidaire aft7000eg0. Any ideas.
check the door interlock sensor. Somewhere there is a tab or button that lets the washer know when the door is closed. If this switch isn't being triggered it could be that the machine thinks the door is open and won't function.
Jun 01, 2011 | Washing Machines
Nordic Track NordicTrack A2550 PRO Treadmill Logo
46 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
