Question about BUSlink MLT-8V 8 in. Portable Television
Main menu for tv - BUSlink MLT-8V 8 in. Portable Television
    Top Expert:
  • 14,553 Answers
Access should be with a menu button either on the set or on the remote.
Posted on Dec 04, 2012
Ghosting on panasonic television
How is the menu that is from the tv. If menu is ok then main board is the issue. If menu is also messed up then problem could be with t conn or main board.
Apr 20, 2014 | Samsung LN40A630 40 in. LCD TV
I can't access my main menu for my Phillips TV
The TV might have set to Hotel mode. To get it out from this mode, you have to enter its service alignment mode [SAM]. Check this link to get more details about it. It is too much to type in here, al the procedure. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 03, 2013 | Televison & Video
Main menu
Sometimes, a hard reset might help you. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset.
Jun 23, 2013 | Sanyo DP50747 50 in. Plasma TV
Puling out main menu
I took a look at my Philips universal remote and while it does have a MENU button, your Magnavox TV may not respond with that function.
Nov 28, 2012 | Philips SRP4004 Remote Control
How to adjust color for better picture
Hello there,
For the Best Picture use the HDMI Cable and here are the Settings for the color setup.
Adjusting Your HDTV Settings
Using the On-screen Display (OSD)
The remote control or the control buttons on the side of the TV can control all the function settings. The
OSD allows you to adjust contrast, brightness and other settings. The TV will save changes made to the
settings, even if the TV is turned off.
The OSD consists of several menu options. The main menu options may vary depending on your
selected input source.
Note: Some of the main menu options may have additional submenus, for example, the TV Rating
submenu for Parental Controls.
The remote control or the buttons on the side of the TV can control all the function settings. The HDTV
Settings App allows you to adjust contrast, brightness and other settings. The TV will save changes made
to the settings, even if the TV is turned off.
The HDTV Settings App consists of several menu options. The main menu options may vary depending
on your selected input source.
1. Press the VIA button.
2. Press ? or ? on the remote control to select the HDTV
Settings App, and then press OK. The Main Menu will be
shown on the screen.
3. Press ?, ?, ?, or ? on the remote control to select one of
the menu options:
? Input
? Wide
? CC
? Sleep Timer
? TV Settings
? PIP
? Network
? Bluetooth
? Help
4. Press OK to select the option or feature you want to adjust.
5. Once the menu option is displayed, press ? or ? on the
remote control to select one of the items to adjust.
6. Press OK to select it, and then press ?, ?, ?, or ? to adjust the selection.
7. Press BACK once to return to the previous screen. To return to your program once adjustments
have been completed, you can do one of the following:
a. Press EXIT on the remote control.
b. Press the RED button on the remote control.
c. Highlight and select the RED X in any menu.
i hope this was helpful don't forget to Rate
Jan 26, 2011 | Vizio M550NV 55 in LCD HDTV
The main menu setting keeps coming back on, unable to use cable 1 or turn to a different cable or channel. (Happened only after power surge) Already tried to re connect the TV, in the main menu setting we...
Hello
I have actually seen this before. The tv in my living room did it and it was a simple fix. I had to download the latest software. Put it on a usb key. Turn the tv off... Stick the key in and load the new software.
The only TRICK was that I had to hold down the VOLUME - button on the tv itself while my wife worked the remote.
So, if you can hold down your VOLUME - button and do things to your tv I would think this might work for you too. I know it sounds strange that a software upgrade can fix this, but it did for me.
Hope this helps
Nov 26, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Main Menu
power supply regulator and horizontal output transistor.
Jan 17, 2008 | JVC AV-27230 27" TV
RCA F32450 TV
Question?
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
Answer:
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
Oct 27, 2007 | RCA F32450 32" TV
Guide plus and main menu problems!
One of you control buttons may be stuck. I found this problem once.
Dec 17, 2006 | RCA F32444 32" TV
BUSlink MLT-8V 8 in. Portable Television Logo
53 people viewed this question
Top BUSlink Televison & Video Experts
Electro Med Services...
Are you a BUSlink Televison and Video Expert? Answer questions, earn points and help others
