Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Washer stopped working - dryer ok
After lifting lid during delicate cycle, the machine refused to start working again when lid was lowered. It now won't start filling under any cycle at all.
  • 1 more comment
  • kenny_h34 Jan 29, 2009
    Washer will not start / Dryer works. Where do I start looking for the problem?
  • MelBr Jan 31, 2009
    Washer won't work after lid was open and then lowered down.
  • Marco Endara Feb 03, 2009
    Washer stopped working. The only thing it does is fills it with water. The motor would not start.
  • 3 Answers
I checked the electrical schematic and the only thing that made sense was the lid check switch. Opened the top of the washer, checked the switch and it was not working. It is the switch shown below. The red button was not up therefore it is broken.
Just to make sure I bypaased the switch with a jumper and made the washer work.
You can order the lid switch online at partselect.com, the part number is PS60679 and it costs $10.38 plus shipping.
Here is someone else's experience with the same switch.
Washer was dead and would not turn on Overall Rating:
Helpful
Rated By:
6 Customers
Posted By:
Suleman From Canoga Park CA
Posted:
05-21-08
Appliance Repaired: Maytag Washer
Model: onceuponatime...
Age Of Appliance: 1 - 4 years
Well the washer died and would not turn on in the middle of a wash cycle. Absolutely dead. I disconnected it from power and opened up the front panel on which all the control switches and knobs are mounted. This is removed by unscrewing 4 screws at the top of the washer.
Checked the fuse, and found blown. Replaced the fuse, closed the panel and plugged it in. Still not working. Checked the Check switches and found the Check Switch really limp. Checked with Digital Multimeter and found no continuity at either position. Unscrewed the check switch. Removal and re inspection with DMM of the check switch confirmed it was bad. Opened up the check switch and found contacts were blown.
Installed a new check switch making sure all the connecting wires go in the right places. The wiring diagram in the washer was very helpful in doing so since u dont want these wires reversed. Adjusted the plunger which operates the check switches when the lid is opened to make sure it is not over or under operating the switches. This is done by loosening the bolt holding down the check switch assembly and slidint the whole assembly forwards or backwards till the plunger has just enough push on the switches. This is done to avoid the plunger from exerting excessive pressure on the check switch and the safety switch in lid open or lid closed position. (both switches are operated by the same plunger according to the lid position)
Closed panel cover and plugged the washer in. There u go, it was alive again!
Parts Used: Lid Check Switch Level of difficulty: Easy Time to do repair: 15 - 30 mins Tools: Wrench set , Screw drivers
Posted on Feb 08, 2009
    Problem Solver:
  • 5 Answers
Call people that you got your washer from and they will tell you more than i can
Posted on Jan 13, 2009
Hi, The washing machine that I have has stopped working during a washing cycle and refuses to come back on. This was during a large wash cycle.
first place we start is checking the lid switch to make sure its working slowly lift tub lid lower slow and you should here a click if not its snapped if yes have it checked to see if blown. appart from that it would be an internal fault the capacitors in these machines dont last too long
Nov 08, 2010 | Speed Queen AWS44NW Top Load Washer
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool washer spin cycle works off and on
no the slowing down maybe caused by a sticking clutch and as before the lid switch may also be broken if when you depress it the reason i'll give is if you bump it it sometimes starts up replace the lid switch and once done the circiut will close properly then the delicate cyc should work
Aug 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
Machine just won't start
you have probably a bad lid switch
Dec 28, 2008 | Maytag LSE7806A Top Load Stacked...
Kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Aug 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
MAYTAG PREFORMA 2 SPEED 10 CYCLES 2004 TOP LOADER
Check your lid switch, some machines stay running when you add clothes when it agitates, but will shut off if you lift the lid in rinse and spin, lid switch may be broken.
Jul 15, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Wsm2480dww laundry center(combo)
The washer drains the water durring the neutral drain. (water drains out but the basket does not spin). Then the timer will hit a "pause" (basically removes the power momentraily so the gear case can change gears). So if you are not getting the pause durring the cycle, lifting the lid does the exact same thing. I would agree with you from your last comments that you do have a timer issue. They can be ordered on line from the manufacture or more readily a local appliance parts store.
Jul 10, 2008 | GE WSM2480DWW Large Capacity Washer & Gas...
Washer Stuck in Cycle
The timer is bad / shorted. Mine used to try to spin with the water in it... that was a sight to see!
Jan 11, 2008 | Whirlpool LSN1000LW Top Load Washer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
198 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
