Question about Microwave Ovens
Dim display can i repair this board or get a new one?
    Top Expert:
  • Microwave Ovens Master
  • 14,553 Answers
The display may be available but can be very tricky to replace----the issue could also be the voltage source to the display is down or low and the display itself is ok.
Lastly I have seen two units where there was in the menu a setting for how bright the display is.......
To try to locate the part Google the model number with "parts" or "display" etc.
Posted on Dec 04, 2012
Dim display panel
Hi. The service manual is here - perhaps your solution is here too:
GE JVM1790SK Service Manual
Jul 13, 2016 | GE JVM1790 Convection / Microwave Oven
Display on control panel is dim and hard to read.
If it's an LCD or LED display, it' may not be getting an adequate voltage from its driver I. C.. If fluorescent, it could be failing itself, or not be driven properly as well.
Based on other posts on this site,
The going rate for repair of these circuit boards seems to be about $39.
Apr 27, 2016 | GE Profile Spacemaker XL 1800 36"...
The display is too dim to read. what can I do?
Depends if it was dim when new then not a lot you can do
if it has gone dim , you have 2 options
1 unplug it and put plug in front of oven door,then remove all cabinet screws.locate the display control printed circuit (under display)take photo of wiring with phone to aid reassembly ,unplug and remove printed circuit board screws and board,clean display screen and window ,if was clear then either obtain replacement panel or take panel into radio or electronic repair shop and have them check and replace any poor electrolytic capacitors, this usually cures older ovens ,but if 6 0r 7 years old displays themselves dim and need replacing.ps if good at soldering just note these capacitor values uf and voltage and obtain at maplin and replace all observing polarity when fitting
Jan 11, 2015 | Microwave Ovens
Display very dim
Unplug the oven for five minutes and plug it back in, if the display is still dim you most likely have a bad smart board.
Apr 07, 2014 | GE Microwave Ovens
Are you able to get a VFD separately for Maytag MMV4205BAW to repair dim display panel without doing the entire panel?
The VFD (vacuum fluorescent display) tube is not available as a separate part for this model, so you would have to order a new control circuit board.
For model MMV4205BAW, the board's Amana part number W10127098 and it runs a hefty $232.30.
BUT -
if you order the board by the original Samsung part number, you can probably get it a for a lot less.
Here is a photo of a similar board which is marked to show you where to find the full part number.
You can find links to helpful exploded view diagrams and part ordering help here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Once the controller is out, you disconnect the keypad, then take out your old board and put in the new one.
Some connectors may have a lock.
Oct 17, 2012 | Jenn-Air JMC7000 Microwave Oven
Just replaced ite control board on my microwave and got all my buttons to work, but now the clock display is dim in the middle only.
please follow the troubleshooting chart attached and proceed with common sense: God bless you
Jul 19, 2012 | Microwave Ovens
The Display is Dim. Hard to read the numbers.
I have the same model and problem. The time display is totally unreadable. Looking for a solution as well. I suspect given the cost (I believe around $60), it's time for a new one. Anyone have any suggestions or easy repair ideas?
Mar 12, 2009 | Sharp R-314FS Microwave Oven
LCD display is working but very dim and hard to see
This is a common failure of the control panel assemblies of these and similar microwaves. We repair these control panbel assemblies nationwide for only $32.50. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 18, 2007 | Sharp R-326FS 1100 Watts Microwave Oven
Digital display lighting
The solution depends first on the type of display your microwave has. Please refer to the picture. The left side shows a partially defective LCD type display. If you have this type of display, we regularly repair them for $32.50 nationwide. The right side is a VFD type display which is weak due to age. On some brands and models, we are able to get a replacement display tube and repair it to a like-new brightness. Feel free to e-mail me at _ if you have other questions.
Sep 17, 2006 | Frigidaire FMT144G1 Microwave Oven
Microwave Ovens Logo
274 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
