Question about Alfa Network Alfa R36 USB-enabled Wi-Fi Router AWUS036H kit
My alfa r36 router is being a pain. The power and Lan stay on normally when theres no usb connected into the routers port. But when i do connect it they both shut down, and the power stays blinking.
  • 1 more comment
  • steeveb52 May 12, 2013
    I also have the same problem.... it sucks cause I wannt plug a analog telephone adapter in the lan so I can Use My voip home phone...It simply shuts down when u plug the ethernet cable....
    I have the same issue ... I would like to use the LAN port for my ata voip phone... but everything shuts down... why? no clue... The R36 with one LAN port working is all I need.
  • steeveb52 Nov 20, 2013
    In the Wan port dough its working perfectly fine and it has been even since I bough everything!;)
How fixe
We may need more information in order to assist you.
What is the device type your attempting to connect to this wifi router? If by chance a laptop computer are you able to plug a Ethernet cable into the device and into port 1 on the router and access the default start up page. Most routers will use 192.168.1.1 as the default out of the box IP address. If so you can start the configuration of the wifi there and make sure the radio is enabled and set the SSID and passwords. Write them down. Some older laptops, and iPads for instance may not pick up 5ghz wireless signals so you need to enable 2.5 ghz.
Mar 24, 2014 | Alfa Network Alfa R36 AWUS036NH &...
Im trying to connect my modam could you please help
First step is to make sure if the modem is functional. This can be done by connecting your computer to modem and check if you are able to log on to internet.
Second step is to connect the cable which previously connected to computer to Router's WAN port not LAN
Third step is to power cycle the modem and router that is power off and on both modem and router
Last step is connect router to your computer with new ethernet cable using one of the LAN ports of the router. There are usually three or four LAN ports on Router!
Good luck! Repost if you still need help!
Sep 06, 2011 | Computers & Internet
Are the lights on the router stay on or blinking ?
The power light should stay solid as long as the router is plugged in. The WAN light and LAN lights are solid when you are connected, and the connection is idle. The lights blink when traffic is present. The lights are off when there is no connection.
Mar 15, 2011 | D-Link DIR601 WirelessN 150 Home Router...
I can't get my router to connect to the phone jack
Connect ethernet lan cable to computer and router end.
In router there is LAN port connect lan cable to that port and connect other end of that cable to your computer ethenet lan card.
Then connect phone line jack to router's ADSL Port.
Let me know if you need further assistance.
Thanks for using FixYa.
May 07, 2010 | Linksys Wireless-G WRT54G Router
Network connects without router. Install router
is your router powered? make sure your router is powered properly.
are you connecting your computer to the LAN ports? (the ones with a number not the one that say WAN? connect your computer to one of the LAN numbered ports and check to see if you get a green light on the front pannel. if you don't have green light, try a different port until, if you run out of ports and still no green light try a different cable.
have you by any chance disable your lan ports? I don't know if it is possible on your router to disable some ports, if that's the case is better to start fresh and simply reset your router by pressing a reset button for a minute while your router is getting powered and retest to see if you a green light on the lan port where you are connecting your computer.
if all this fails, it's very likely that your router has died. replaced accordingly.
Apr 04, 2010 | D-Link DGL-4100 Router (DGL4100)
Driver
not sure why you will need USB drivers for your adsl2+ modem/ wireless router and 4 port LAN switch. It would help you had provided the model number.
The device uses a LAN ethernet port to connect to the computer. You will need atleast one computer to be on the LAN port for setting it up. Once setup is complete you can use wireless connection for every computer.
The user manual & drivers or the DSL-2740B which appears similar to your product description
http://www.dlink.com.au/tech/Download/download.aspx?product=DSL-2740B
Not sure if you need these. Your computers will need LAN or wireless drivers to connect to this DLINK modem/ router.
Good luck
Dec 25, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Top 2 lights are green, connections are all correct, and there is no internet connection to the computer. Is there a setting on the computer that I have wrong?
You need 1 more light, "Local Network". So you need to connect something, probably your computers LAN - Ethernet Port to one of the 4 ports that are together (LAN ports.)
If you are connecting USB, well that's always ugly, no cable support person will recommend that you connect a computer to a router via USB. But if you do, there's a driver software for that. Should be on a CD that you received in the package.
USB driver, no doubt, will create a virtual Network Adaptor. Then you'll get IP Automagically from this unit to your computer. The same thing should happen if you connected via LAN/Ethernet connection.
You normally don't have to set any settings, the default will be Automatic for IP Settings assignment. Which means you'll get it via DHCP protocol from this unit.
Nov 28, 2009 | 2wire 1800HG Router (RG1800HG00)
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
All LAN Ports are ON
Arunk, When you say the electrical characteristics of the new A/C adaptor are the same as the old one did you check to ensure the amperage and the polarity of the power plug is the same as well?
Apr 03, 2007 | NetGear WGR614 Router
Alfa Network Alfa R36 USB-enabled Wi-Fi Router AWUS036H kit Logo
310 people viewed this question
Top Alfa Network Computers & Internet Experts
David Payne
David Payne
Are you an Alfa Network Computer and Internet Expert? Answer questions, earn points and help others
