Question about Panasonic Vacuums
Hi, I have Pnasonic Vacuum cleaner MC-7650 -2000W,while working machine stops its own.I tried all the way ,all in vain
I checked all the electrical conectivity and looks like fine.
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
If it operates less than 15 minutes suspect the filter is blocked and that will cause the motor to heat triggering shut off.
l have seen this and the filter may be washable or not.
Posted on Dec 04, 2012
4 Suggested Answers
  • 389 Answers
SOURCE: Filters for panasonic vacuum cleaner MC-E468
Hi! Sometimes really hard to remember which of these models is which, so please forgive me if this is not a complete solution.  I'm pretty sure you will find there are two filters.  The first is a foam filter, and is located at the bottom of the bag compartment.  It pulls out to the front, and is washable (of course it must be completely dry before re-use).  The second (and here I'm on less secure ground) is a HEPA filter, and is located behind a removable panel on the front of the bag compartment door.  The HEPA filter is not washable, but rarely if ever needs to be changed unless the machine has been used for vacuuming a lot of extremely fine dust. I hope this helps, and I value your feedback. Please remember to rate my response.  Good luck!
Posted on Feb 24, 2009
SOURCE: Panasonic Vacuum MC-E450UK
Panasonic MC-E 450UK upright vacuum cleaner.
Just had this problem myself...........easy to get at it when you know how.
Panasonic UK wouldn't help me so I spent some time working it out..........here it is.
Remove the hose from its mounting storage at the rear (called hose clip) where the main body of the vacuum cleaner meets the base of the handle assembly. Remove the screw at the rear of the handle assembly which is behind where the hose 'was' situated and is located inside the deep recess.
Using the soft part of your clenched hand as a hammer, knock the base of the handle assembly at the front and it will slide backwards off the main body of the vacuum cleaner. Don't be scared, give it a thump and keep moving it backwards with a few more knocks.
Next remove the two screws at the front which hold the mains cable and on/off switch cover in place.
Finally looking from the rear once more, lift the plastic 'lug' at the top of the cover and which is part of the cover. This will now allow you to release the cover and pull it forward.
There you go! Told you it was easy!
Watch out for the funny little spring at the front behind the cover in the tiny plastic tube where it connects to the small rubber tubing as it could possibly try to escape.
You now have complete access in order to cut the intermittent part of the cable out and remove it from the 'choc' block.
Happy fixing!!
Jack.
Posted on Jul 22, 2010
SOURCE: panasonic vacuum cleaner MC-5030 stopped and don't work
Unplug, check if brush has cord wrapped. Check for fuse, if applicable.
Check power lead in another supply socket. Check for reset button, if applicable. Contact Panasonic technical support for suggestions before heading to service centre.
Posted on Jun 17, 2012
Panasonic vacuum cleaner just stopped running
Set the on/off switch to off, now check near the top of the "beater" portion, I think that model has a reset button, you should hear a slight "click" when depressed. Try turning the vacuum back on.
Aug 26, 2014 | Panasonic MC-V5217 Vacuum
How do I improve suction of the Panasonic mc cl310 vacuum
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try. You can check the hose and canister to make sure nothing is lodged in them. If nothing is there and it does not fix the problem, your issue could be related to your brush-roll. Check your brush-roll to make sure that nothing is interfering with it. If that does not solve the issue, the next area that should be checked is your vacuums filters. Filters should be replaced every 3 to 6 months for optimal performance.
You can purchase direct your replacement Panasonic vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 05, 2014 | Panasonic MCCL310 MC-CL310 MC CL310...
Panasonic vacuum cleaner MC-5030 stopped and don't work
Jun 17, 2012 | Vacuums
Need owner's manual for Panasonic MC-9420 canister vacuum cleaner
goto> http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Vacuum-Cleaners/Canister-Vacuums/model.MC-3920
Feb 21, 2010 | Panasonic Vacuums
I have a panasonic mc-ul975 vacuum that works great when working properly. the airflow through the canister seems to stops once the aero blast technology is done running which causes the vacuum to not...
Hi there. In Panasonic vacuums2.gif, there is a thermostat protection on the motor. It will automatically shut off the motor if there is no airflow through the motor. This is typically caused by a clogged hose. Typically, if your dust container is that full, there could be backup in the hose. Or the dust container being too full could also or otherwise be the problem. Check your hose for blockage, let the machine cool off, it should start up again
Aug 30, 2009 | Panasonic MC-UL975 Upright Vacuum
Won't come on
Sorry, but the direct answer to your question is: no, there is no reset switch on this machine. What you do next depends to some extent upon what part of the world you are in. You should check that there is power to the electrical socket you are using (plug something else in and try it). If you are in the UK you should check the fuse in the plug (if this has blown you will need to find out why). Quite often the problem is simply a break in the cable. Beyond that you will probably need professional hands-on help.
Apr 08, 2009 | Panasonic MC-V5737 Bagged Upright Vacuum
Panasonic MC-E468 vacuum cleaner loss of suction
HI If the cleaner is loosing suction make sure to check all inspection tubes and the dirt channel hoses after the spinning brush. Also check the main hose for any clogging. One of the worst faults of this model is clogging hoses. Hope that helps you.
Feb 27, 2009 | Panasonic MC-E583 Bagged Upright Vacuum
Order drive belt
Panasonic belt # MC-V2708 is the correct belt for model MC-V7395.
Dec 11, 2008 | Panasonic MC-V7395 Vacuum
Happy fixing!!
Jack.
Apr 07, 2008 | Vacuums
Vacuums Logo
267 people viewed this question
Top Panasonic Vacuums Experts
jasbo
jasbo
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
