On off switch
Set does not come on until on switch is cycled many times. after being on, and warmed up if shut off it will turn right back on normally
    Problem Solver:
  • 10 Answers
Dude, that is a easy one. You are in a humid environment and the switch has oxidized. Once heated, the surface turns to carbon witch is conductive. Your solution (if you wish to except it) is to find a silicone lubricant to spray the contacts with.
Posted on Jan 11, 2009
Hoover bagged wind tunnel 2 vacuum turns its self off after about 10 min. of normal vacuuming I can press the power button right away and the vacuum will turn back on and vacuum for sometime as long as 5...
There is a thermal sensor in the motor which shuts power off if it gets too hot but usually it won't turn back on until it cools down. It seems you might have a defective switch
Oct 06, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
In Fan mode, fan works; but in AC mode, I can hear the normal AC sounds, except the fan never turns on. This is the fan in the lower half of the unit in the inside of the house, which blows the air...
on a call for air conditioning your therrmastat brings the indoor fan on and the out door unit at the same time. Since your fan comes on in "fan" mode, it sounds like you need a thermastat. For temp. cooling just turn your fan switch to "on" and turn system switch to cool and set desired temp. System will cycle off and on but fan will not shut off until fan control is set back to "auto". I suggest replaceing thermastat
Aug 16, 2011 | Heating & Cooling
On our Model LAT9635AAE washing machine when cycle is on cold/cold the water fills at a very slow flow. If (while water flowing on cold) the water temp switch is switched to warm and back to cold the cold...
You have a bad fill (mix) solenoid valve. The valve in the solenoid is hanging up and by switching it back and fourth between hot and cold its just working its way to the proper position..You were on the right track.....
Sep 16, 2010 | Maytag Washing Machines
Won't start until switch cycled on and off for
either the fuel is draining back into the tank after you shut it off,or the pump is not putting out enough pressure,it should be at least 50psi to fire the car
Dec 26, 2009 | 2002 Daewoo Nubira
I replaced the coil set, but that was not the problem. The ignitor will light the gas flame and it will blow for about 2 minutes, then the gas shuts off. Since replacing the coils, I have not tried the...
The gas flame will cycle on and off in response to the thermostat. Two minutes sounds about right for the dryer to warm up to temperature. The gas will shut off until the temperature cools down and then should cycle on again. Let the dryer run (either with or without clothes inside) and watch to see if the gas cycles on and off. If the gas does not come back on there may be a problem with the thermostat or auto sensor or the exhaust vent duct may be clogged.
Nov 06, 2009 | Dishwashers
Setting digital time on elgin fh205 . need manual
The FH205 isn't the same as a PQS Monika, there are 3 buttons, the one in the lower right just lights up the small digital display, then there are ones on the top left, and bottom left, and a dial on the right center.
To set the digital display time, you simply change the mode to time with the bottom left button. Press and hold the top left until the seconds start to flash.
Use the bottom right button to set the time you want, using the top left to switch from seconds, to minutes, to hours (on a 12 hour display, if you need PM, keep cycling the hours until the small PM text appears to the right of the display). After hours will be 12/24 setting, then back to normal operating mode.
You can repeat the same steps above by switching to date view, and press-and-hold the top left button again, and set the month, day, and day-of-the-week.
The analog time is a simple matter of pulling the crown out and turning to the appropriate time.
Sep 27, 2009 | Watches
My Air Conditioner does not get cold after I turned it off and turned it back on. I have now turned the themostat off about 20 mins ago
Air conditioners need a few mins to stabilize (the fluid in the lines) after they are shut off in the middle of operation. The comperssor will normally time out for several mins after it shuts off (or you shut it ofF) preventing it from coming back on within that time. So if you turn it off, and then right back on, you can expect warm air for several mins untill it times out.
Jun 17, 2009 | Honeywell Electronic Programmable...
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
The furnace is blowing warm air even if the thermostat low.
The only thing that tells the unit to come on and off is the thermostat so I would definatly say it is it. When you turn the system back on, does the a/c run normally? If it does, then it's the problem with the heating side of the tstat. Also, does the fan come on when you put it to on and then turn of when you switch it back to auto? If it does, then the system is working fine, its the t-stat. Let me know if you have any more problems.
Mar 23, 2009 | Intertherm P3RA-048K Air Conditioner
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
