Question about Hotpoint RGB745 Gas Kitchen Range
Oven does not maintain temperature while cooking. Oven will come on and preheat as it should but then temperature drops while cooking and remains below preheat value. Every 15 minutes or so we set the temperature to 5 degrees higher and wait for the preheat just to keep it going. The self clean function and broil work OK. I have changed both the thermocouple and the control board. Thanks for your ideas.
  • 1 more comment
  • Anonymous Nov 02, 2007
    Stove makes a humming noise and will not get up to desired temperature.
  • PJohnson Nov 26, 2007
    Oven does not maintain temperature. Must keep raising temperature to keep it at needed temperature. If set at 350, it will drop to 250 until I raise it to 400 - then it will go to 450. Broiler is fine. Help!
  • Anonymous Mar 24, 2014
    oven temperature control
I eventually replaced the oven ignitor. That has solved the problem.
Posted on Aug 29, 2007
  • 63 Answers
Try changing the oven sensor its in the oven looks like a small rod coming out you need to remove 2 phillip screws the take it out
Hotpoint Gas Range does not hold temperature
We had the same problem, my husband took ours apart and noticed a loose wire off the relay board for the oven. So far it's working again, we had it at 450 for awhile and it kept the temp, then lowered it to 325 for 1/2 hour and it kept the temp, yippee! It better keep working, because he's cooking a ham on Christmas!
Dec 09, 2010 | Hotpoint RGB745 Gas Kitchen Range
Oven will come up to preheat,but will not maintain temp. the ignitor will come back on but burner will not light again.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 04, 2010 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint gas oven won't keep its temperature. I
The temperature sensor in the oven needs replacing. It is located in the back wall of the oven. About 3 inches long,metal and about the size of a thin pencil.
Nov 22, 2009 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint oven
From MNTECH, "If your oven would light sometimes, but usually not, or take a very long time to ignite, then replace the oven igniter. Even though it probably is glowing, it needs to draw a specific minimum electrical current (in amps) for the gas safety valve to open and release the gas. Also low voltage can affect how many amps the igniter draws, so that may be a factor, but not as often."
I live in Japan. I got a brand new range in june and it has had this problem for four month. The igniter glows but the gas never (or rarely) releases. Often it would preheat but not maintain the temp while baking. **augh** After reading MNTECH's solution I got a transformer and plugged my range into it to change the voltage (100 to 110) and I haven't had a problem since. THANK YOU MNTECH FOR POSTING THIS SOLUTION
Aug 18, 2008 | Hotpoint RGB745 Gas Kitchen Range
Temperature is Unstable
erratic temp in oven can also be a bad oven ignitor, usually to low of a temp and not able to stay at temp, too long to preheat.replace the bake ignitor
Mar 11, 2008 | Hotpoint RGB745 Gas Kitchen Range
Hot point RGB745 gas oven
try to relite pilot if that dont work tap on saftey valve were the flame bar connects to if that dont work replace saftey valve
Dec 07, 2007 | Hotpoint RGB745 Gas Kitchen Range
Oven does not maintain temperature while cooking. Oven will come on and preheat as it should but then temperature drops while cooking and remains below preheat value. Every 15 minutes or so we set the...
Hello Michael Smith,
You MODEL number only came through as a
PARTIAL ... (so I filled in the rest (assuming USA)):
RGB745 ... wea2ww
Please note:
Accordingly... you will have to VERIFY the part.
Part and video guidance are available here:
Third item on the page "heat sensor"
http://www.appliancepartspros.com/parts-for-ge-rgb745wea2ww.html
Hope this helps...
Carnac the Magnificent
Aug 13, 2017 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
866 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Archie Ferrarini
Archie Ferrarini
Sal De
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
