Question about GE JKS05 Electric Single Oven
A F8 is showing on our control pad...Help - GE JKS05 Electric Single Oven
    Top Expert:
  • GE Master
  • 9,472 Answers
Component failure within Electronic Range Control (ERC) effecting temp processing circuits. Replace the ERC. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Posted on Dec 04, 2012
My oven pad show out F2:E1
For Whirlpool (and associated brands), the F2 E1 error indicates a communication problem between the touch pad and the electronic control board. The oven's control thinks that the touch pad wiring is unplugged. This could be due to damaged wires, a loose wiring harness or a problem with the touch pad. First check that the wires aren't loose. Press Cancel to see if the signal is sent to the control board and clears the error. Wait 60 seconds for a response.
If the error persists, you need to replace the touch pad. On some models, you'll have to replace the touch pad and control board since they are sold as a single unit. For the units where the touch pad is a separate unit, you may still need to replace the control board. If the F2 E1 error persists after replacing the touch pad, then the control board is also faulty.
If you post a comment with the oven's make and model number, I may be able to give you the appropriate replacement part numbers. If your oven is still under warranty, contact the manufacturer for the repairs.
I hope this helps.
Jun 28, 2016 | Ovens
Frigidaire Gallery series model GLEB30T8CBA key pad not working
Hello Dana, thank you for your post!
From my understanding your Frigidaire oven is displaying an error code of "F8" and your keypad is not working properly. An "F8" error stands for runaway temperature (overheating). I would recommend performing a reset on your oven and you can do that by disconnecting the power cord for at least ten minutes.
If that does not help correct your issue then you could have a problem with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would suggest having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful. -Matt
Jan 10, 2016 | Frigidaire 30 in. Electric Gallery Series...
Cant clear code or use oven after small power surge - stove top still works. GE web site does not have a F81 code they have an F8 and F1 which both say problem with keypad and electronic control needs to...
You didn't post model, but with a surge you probably looking at replacing the ERC. Does the manual say to unplug to reset, or check again on reset the control.
Some have this for reset, can't hurt to try.
  • Press the BAKEand BROIL HI/LO pads at the same time for 3-5 seconds until the display shows SF.
  • Press the COOKTIME and BROIL HI/LO button (on some models press Broil only, refer to your use and care manual). The display should show C. Press the button again until F shows in the display.
  • Press START to complete the change.
  • If this clears control, do it again to reset to Fahrenheit.
    This way actually resets for a error also besides temp.
    You can check the price of a control here,
    http://www.repairclinic.com/
    And you can google search for more places to shop prices.
    Mar 30, 2013 | Ovens
    F8 error and bottom door locked
    Here is Frigidaire's suggestion to your problem:
    Oven Control Beeps
    and Displays an "F"
    Error Code
    Electronic control has detected a fault condition. Push CANCEL pad to clear the display
    and stop the display from beeping. Reprogram the oven. If a fault reoccurs, record the fault
    number, push the CANCEL pad and contact an authorized servicer.
    Jul 26, 2011 | Frigidaire 30 in. Electric Gallery Series...
    Frigidaire double oven beeping and showing f8 code
    there is a problem with the lock for one of the doors do they both close all the way or does one hit the latch. could be bent linkage or bad switch on lock or the control board has a bad relay on it.i need a model # to help any ferther
    Dec 31, 2009 | Frigidaire 27 in. Electric Double...
    FO shows on led board for both ovens
    HI. This is a basic communication issue that will concern, either the control board, or touch/Key pad assembly. Normally, this will produce a stuck key, which will cause one of the power relays to become suspended.
    Determine if The problem is with the Key Panel or Control by:
    1. Pushing CLEAR/OFF pad.
    2. Disconnecting the key pad Ribbon Cable from control(main), and waiting at least 32 seconds to see if Code recurs
    If code recurs, problem is in the control. Replace control.
    If code does not recur, problem is with the Key Panel.
    NOTE_ Some models incorporate the touch/Key pad into the EOC as a single assembly(Whole device), in which case this test is not necessary. Simply replace the EOC (Clock).
    Nov 06, 2009 | GE Profile JT952 Electric Double Oven
    The oven controls are not working. then FO shows
    If your appliance is newer than 1996 F0 error code is a stuck key pad .
    To verify turn off power and access the control panel and remove the ribbon connector that goes from key pad to control board .
    Now restore power.
    If the F0 code goes away you'll have to replace the key pad .
    If it stays it means the control board is bad.
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    Jun 11, 2009 | GE 30" Built-In Single Electric Convection...
    GE lower oven displaying code F8. Clear off does not clear code
    Your ERC(clock) has failed. Replace the electronic oven control.
    May 26, 2009 | GE JRP15 Electric Single Oven
    Oven not working Message E0-F2- showing
    F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
    Select the 'cancel' function and wait 60 seconds.
    If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&
    Apr 20, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Beeping sound and f8 displayed
    F8 means to replace the elctronice range control board. Evidently the power failure caused damage to the board.
    May 24, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    GE JKS05 Electric Single Oven Logo
    43 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
