Question about Jane Powertwin Jogger
Jane powertwin has stains on seats do covers come off for washing
Do the covers actually come off the seat unit altogether so i can put them in washing machine?
I normaly Scrub the seats down with some stain remover and hot water on a sunny day, or ona day when it is dry. Then leave them to dry, and they come up pretty good.They only detach from the pram as a full seat so not able to put in a washer.
Posted on Jan 14, 2009
How do I get my clothes to SMELL like clean clothes? Darn washing machine stinks them up!
Check the drain where ti empties into, smell the drain thats most likely where the odour is coming from.
Aug 18, 2014 | Maytag Centennial MTW5800TW Top Load...
Not draining
With front loading machines this is VERY common. My teenage Daughters wear underwear that are so tiny that they get past the drum lip and get wound up in the pump impeller. Same thing happens with stuff left in the pockets specifically coins.
At the bottom usually the front of the machine there is a bailing tube next to the pump. Take the plug out and put it in a shallow basin to drain the water out of the drum. Then remove the pump access cover, it usually twists out. Then remove what ever treasure is jamming up the pump. Put the cover back on, put the plug back in the drain tube and if you like add a quart of water into the front of the machine to prime the pump again. Then test the machine.
To keep this from happening they make laundry mesh bags - if you use them then nothing will clog the pumps ever again. I tell my Daughters to get underwear that actually covers their butts. For some reason my plea falls on deaf ears. Go figure.
Mar 23, 2014 | Washing Machines
Please help I've put my grey quinny buzz seat
Good Afternoon
As long as you wash it maximum temp 30 degrees on handwash or delicate cycle it should be fine.
To be safe wash it by hand with mild detergent rather than putting in the machine.
Jul 14, 2011 | Quinny Baby Gear
Hi im looking for new seats and rain cover for my jane powertwin my old ones are not in good order any help would be great full
you need to contact jane directly for the seat fabrics
also at that site for the raincover
Oct 26, 2010 | Jane Powertwin - Silver Jogger Stroller
Take cover off to clean
If you go to this site you should be able to get the instructions for your model car seat. It will be helpful if you know your model number and date of manufacture.
Thank you
Apr 30, 2010 | Evenflo Triumph 5 - Playwright Ash
Where can I get a seat belt for Jane powertwin
If you visit you can see the contact details to order this part.
Hope this helps.
Mar 27, 2010 | Jane Powertwin Jogger
How to wash Bugaboo Cameleon seat fabric? As the manual told that all the parts are able to taken apart but I still confused. Especially the seat fabric. there are the back support saw inside. I have no...
If you are talking about the base seat fabric, before you put the seat fabric in the washing machine remove the wooden and foam piece from inside the seat and then throw it in on cold with a gentle cycle. DO NOT put it in the dryer. Hang it to dry. Mine came out great like this. If you are talking about the tailed fabric that goes over the base seat fabric, then just remove the cover and put it in the washer - again NO dryer.
Mar 17, 2010 | Bugaboo Cameleon - Tailored Fabric...
Lg front loader washer error code -PE
PE error code means there is an pressure sensor error in your machine .
You need to check pressure it will be giving incorrect indication .
Pressure switch is faulty you need to change it .
Procedure for changing it is :
  • Power off the machine remove backcover and top cover.
  • The pressure switch is a round item about 3 inchesacross with several wires and a thin rubber pipe attached.
  • It generallysits just under the top cover.
Hope this helps.
Thanks for using Fixya.
Jan 20, 2010 | LG Washing Machines
Jane Powertwin Jogger Logo
385 people viewed this question
Top Jane Baby Gear Experts
Shehu Pro
Shehu Pro
john h
Are you a Jane Baby Gear Expert? Answer questions, earn points and help others
