Question about Rossignol ALIAS 74 CARBON Skis With Bindings, 176cm, 2012
I want bought this sci
2014 punishments
A god punishment is to hit yourself with a hammer several times. For your children, I suggest taking away their gym shoes and make them wear their "Sunday" shoes to school for a while.
Sep 16, 2014 | Armada Scott Punisher Skis With Rossignol...
I recently bought Drake F50 womens bindings and it came with nothing to attach to the snowboard.
Head back to the store. All bindings come with the circular plates you mention plus screws. Without them plates bindings are useless...
Dec 05, 2012 | Drake F50 Snowboard Bindings Wms Sz M
One of my bindings broke after just four days out. How do I get it fixed or replaced?
Hopefully you kept the receipt for the shop where you bought the bindings. Most places are pretty reasonable and seeing as you only had them for four days, would be willing to exchange them. However, if you happen to get the one shop who won't work with you, I'd contact the manufacturer of the bindings directly to see if they would be willing to make it right. Good Luck
Aug 15, 2010 | Lamar Winter Sports
Refinish the top side of K2 skis?
If there is major damage that could affect the structure of the ski there is really no one who can fix it and i wouldn't continue skiing on them. If you are just trying to make the skis look nice on top try any oil based cleaner if that doesn't work give them a thin coat of epoxy. why does the condition of the tops of the skis matter anyway?
Mar 21, 2010 | Sport & Outdoor - Others
Atomic 4tix 310 binding toe adjustment.
Did you ever figure out how to adjust the toe piece? I am having the same problem
Mar 08, 2010 | Sport & Outdoor - Others
HOW TO ADJUST tyrolia SL 100 ski bindings
With click bindings on ski's or snowboards it's best to take to authorized service because if you adjust the release to work with to much or to little pressure your gonna end up dropping into a powder run and instantly losing your skis or getting hurt when they don't release under lot's of pressure plus it's based on factor's such as your weight. But you might be able to hit up the service tech to show you how to adjust them yourself so you don't have to pay, and you could probably find a manual on-line but I'm recommending to go to the tech.
Jan 30, 2010 | Sport & Outdoor - Others
I recently bought Mantra 184. I am going to use Dynafit bindings. Do you think I should respect the factory binding mark or should I fix it back a little ?
How did you end up mounting the Dynafits on the Mantra? How do you like the set up? Thinking of doing the same?
please let me know, mmm245@nau.edu
Nov 28, 2009 | Volkl Mantra Skis
Vertical adjustment on front binding. Salomon S810 Ti
If you can adjust vertical pressure then you should adjust it as follows.
Put a piece of normal paper (like A4 printer paper) on the toe bit (and heel for that matter) and clip in the boot so that the paper sits between the boot sole and the binding base surface. You should be able to pull the paper out from between the boot and binding without ripping the paper, but obviously without there being a noticeable gap.
If in doubt take it to a ski tech, a bit of cash might save you a broken leg! They might even be able to help you or advise free of charge.
Nov 07, 2009 | Rossignol Used Freeride X 05 Skis with...
SOLTEK SL-5200XD
dear !
Just click on the link below and download drivers. Don't forget to vote me. Thanks
http://www.soltek.com.tw/soltek/download_file/Manual/vga/GeforceFXSeries1.3.zip
Mar 30, 2008 | Soltek (SL-5200-PD) Graphic Card
Gears of War for Vista and Logitech Rumblepad 2 directional issues (fwd/rev)....
There is a way to fix it: go into your control panel under Game controllers, select your logitech cordless rumblepad 2 and hit
properties -> settings -> Enable Swap Mode -> close -> ok
Now start Gears of War and go into the options menu under controls for the controller.
Invert Axis = yes
Joystick Mode = Left-handed
This fixes the problem with the joysticks, but there is still a button fix that needs to happen. operations for buttons 2&3 are swapped, same thing with buttons 1&4, 5&7 and 6&8. I don't how to fix this problem yet.
Dec 30, 2007 | Logitech Rumblepad 2 Vibration Feedback...
Rossignol ALIAS 74 CARBON Skis With Bindings, 176cm, 2012 Logo
251 people viewed this question
Top Rossignol Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Rossignol Winter Sport Expert? Answer questions, earn points and help others
