I have a jvc th a55 receiver and when I try to listen to fm it says auto muting and no sound comes out
    Sergeant:
  • 256 Answers
There is a problem with the FM circut in it,
Posted on Dec 05, 2012
5 Suggested Answers
  • 103 Answers
SOURCE: auto muting
Sounds like something inside went south. You can try disconncting the speakers and see if it still happens. If so, then the system is in need of repair. If not, then a speaker may be shot. Try connecting one speaker at a time to see which one may be causing the auto-mute problem.
Hope this helps, and please rate my advice, good OR bad.
Posted on Feb 04, 2008
  • 118 Answers
SOURCE: Listen to DTV DVR output on TH-C3
im not familiar with this model. can i assume it is a small home theatre system with limited inputs?
in that case, the best thing to do is to feed all your devices...cable, dvr, dvd, etc....into the tv.(audio and video). then use the audio output of the tv to the input on the receiver. you may have to go into the tv menu and set the audio output to the speakers in the tv to fixed mode for a constant level out to the receiver.
good luck
Posted on Dec 08, 2009
Testimonial: "Excellent suggestion, nailed it !!"
  • 22 Answers
SOURCE: NTSC and PAL DVD's on JVC TH-A55
only ntsc if it was built in the us
Posted on Apr 25, 2010
dunnbiker
  • 8546 Answers
SOURCE: when i put the
"Auto Muting" in the context of FM means the output will be muted if the signal is so weak it would result in mostly noise anyway. Interstation radio noise can be annoying and dangerous at high volumes.
Posted on Aug 14, 2011
Have a JVC RX-9010V receiver and get no sound on FM , tv, etc.
no my antenna is a good one i tried with mp player too?? Is this a way to reset it to factory?
Nov 14, 2013 | JVC RX-9010V Receiver
How do I get my jvc fm auto muting to turn off? It only comes on when you put it on FM
Only had to conect antena and boum ! the radio came alive
Apr 07, 2013 | JVC RX-558V
Receiver comes on but have no sound tried the solution; but it still didn't work. What I am seeing is, in the upper left hand corner of the window in small writing says "mute auto" which is...
Mute Auto is for FM only. It mutes interstation hiss while tuning. Look for some other indicator that might reveal why the signal path is failing. Tape?
Have you tried the basics? Speaker test? FM only?
Sep 01, 2011 | JVC RX-554V Receiver
When i put the fm radio it display auto muting and doesnt have sound, this only happens with the radio because the dvd sounds ok
Aug 14, 2011 | JVC TH-M303 System
How to get sound to tv from JVC TH-M606 without sub woofer.Also trying to put in progressive mode without remote
  • If I understand your question correctly you want to listen your TV on your Stereo system thru your receiver,JVC TH-M606 ** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
JVC TH-M606 RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the
JVC TH-M606 Receiver..By this means whatever you watch on the TV (tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
  • If you want to listen your receiver thru your TV, sorry but it is not a preferable attempt since TV sound system is not a HI-FI quality compare to your nice Receiver..if you really want to do it,try to do the connections given above in reverse..
  • And,best of my knowledge I am afraid you can not put in progressive mode without remote
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Jun 24, 2011 | JVC TH-M606 System
I tried restoring the sound by pressing Muting on master volume. Auto Muting still appears on the display and I can't restore the sound.
"Auto Muting" is for FM reception only and means it will mute the FM audio unless the signal is strong enough to provide decent audio.
Re-evaluate your symptom and corrective actions for relevancy.
Manual / Troubleshooting Page 31:
http://www.retrevo.com/support/JVC-RX-6000VBKJ-Receivers-manual/id/315bh050/t/2/
Dec 27, 2010 | JVC RX-6000V Receiver
Auto muting on when on am/fm and no sounds come out. everything else is fine.
That's normal.
The Auto Muting mode mutes the audio output of the tuner if the station is not sufficciently strong to be accurately tuned. Otherwise you would hear all that interstation hash noise.
Press the FM Mode button to change it to Mono if you want to manually tune a hard-to-reach station. It will be in Mono.
Page 26:
AUTO MUTING
Normally select this.
When a program is broadcast in stereo, you will hear stereo sound; when in monaural, you will hear monaural sound.
This mode is also useful to suppress static noise between stations. The AUTO MUTING indicator lights up on the display.
Mar 31, 2010 | JVC RX-D205 7.1 Channels Receiver
No sound in FM radio
I had same problom and fixed by connecting an antenna to fm port
Jul 05, 2008 | JVC RX-6030V Receiver
JVC receiver Auto muting?
I had the same problem. I had bad antennae connection. I re-did the antennae conection and it fixed it. HOpe this will work for you...
Dec 03, 2006 | JVC RX-618V Receiver
43 people viewed this question
 Grubhead
Grubhead
