Question about Swintec Office Equipment & Supplies
How do I clear margins on swintec 2600
I cannot clear the right margin on the typewriter. It is in the wrong place
SOURCE: Swintec 7000 typewriter
Lo and behold, some light oil on the stainless bars solved the problem.
Posted on Apr 08, 2008
  • 329 Answers
SOURCE: Swintec 2600 Electric Typewriter
MARGINS: Left margin space or tab to where you want margin set and depress the mar L key. Sometimes the key has to be depressed as you hit the code key. If you want to move carrige to the left, go to margin hit margin release and bk space to where you want. Same with the right margin only use th R margin key. Code key usually keys have second message are in green, yellow or red. Use code key with the small print on the key to activate that function.... Good luck
Posted on Aug 01, 2008
Geno111
  • 183 Answers
SOURCE: electric typewriter set the margin
if you still have problem, repost with make and model typewriter, different methods are used with different machines
Posted on Nov 01, 2008
pluerick
  • 4 Answers
SOURCE: SWINTEC 8014 S TYPEWRITER
Press "MAR RELEASE", one key right of "MAR LEFT" in the upper left hand corner.
Press back space in the upper right corner until it's where you want it and press "MAR LEFT" to set it.
Tab over to where you want the right margin and press "MAR RIGHT"
Posted on Dec 01, 2008
  • 125 Answers
SOURCE: Left and right margins of typewriter on Brother ML 500 Memory
Hi:
First find the margin release key and press it once. Then use the spacebar to move the carrier forward and reset the right margin. Or again use the margin release key by pressing it once and then press and hold the backspace key to move through where the left margin was and reset it at the point where you want it.
Andrew
Posted on Mar 19, 2009
How do I increase the margins on the typewriter
To set a margin beyond the left or right margin, move the carrier (or cursor) to that margin, press the Margin Release key, then proceed to move the carrier (or cursor) to the desired position. Then, press the Left or Right margin key to set the new margin. A beep will sound indicating the new margin has been set. When you set a new left or right margin, the previous margin is automatically cleared.
Alternatively, you can type beyond the right margin by pressing the Margin Release key and then continue typing when the carrier (or cursor) stops at the right margin. To type beyond the left margin, press the Margin Release key and then the Backspace key to move the carrier (or cursor) to the position where you want to start typing.
Remember to always use genuine Swintec ribbons and lift-off tapes for your Swintec 7040, which can be found at Swintec Typewriter Supplies .
Aug 19, 2014 | Swintec 7040 Typewriter
How do you clear the right margin
Go to the R. margin, press but don't hold the MAR REL key, space to desired location press R. margin key.
DickyO
Aug 05, 2014 | Swintec 2600 Electric Typewriter
How do you release right margin
Push the Mar Rel key, then you should be able to space or type through the right margin.
How to clear tabs on Swintec 2600 typewriter
To clear all the tabs tab allthe way to the right, hold tab clear and press return. If you are trying to clear margins go to the margin, press but don't hold the mar rel key, space or backspace to desired location, press L. or R. mar key.
DickyO
Mar 28, 2012 | Swintec Office Equipment & Supplies
How do I unlock right margin on a Swintec 7040 typewrite?
move your carriage to right margin by using "tab" or "space bar". then press "margin release" and using "space bar" locate carriage where you want right margin to be, then press "right margin".
razors
Nov 03, 2011 | Swintec 7040 Typewriter
I have a swintec 2600 i cannot get it to clear out the tabs and i need to type beyound were the tab is
You must mean the margins. To move the right margin further to the right. Move the carriage to the right margin then depress the mar release key then space over further to the right to a new position and depress the right margin key. You should here a beep. If you just want to type further to the right of the margin, when it stops typing, simply depress the mar release key and continue typing.
Jul 21, 2009 | Office Equipment & Supplies
Margin release
Turn the typewriter on press the return key. If you want the margin to the left of were it is set press the MAR. key ( margin relace) press the back space key to the desired spot. press the L margin key. Your left hand margin is now set. Space to the right to where you need your Right hand margin to bo. If stops before you want it to press the MAR. key press the space bar till the drsierd place press the R MAR key.
Jan 29, 2009 | Swintec 7040 Typewriter
Working with automatic centering feature
set both the left and right margins where you want them and starting withe the carrier at the left margin turn on the auto center then type, when you then hit the return button it will type centred between margins
Dec 07, 2008 | Swintec Office Equipment & Supplies
Aug 01, 2008 | Swintec 7040 Typewriter
Margin locked
check that there is nothing dropped into the typewriter that may be blocking the carrier try turning the machine off and moving the carrier by hand to the right side,if it moves ok then turn it back on space the place it stops , touch the MR (margin release button) then try spacing further to the right nad reset the right margin.
Jan 28, 2008 | Swintec 7040 Typewriter
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
