Failure to maintain flame @ low temp ~-25 and below
Heater fires and operates without issue down to about -25 F. At temp lower it starts for approximately 1-2 minutes before shutting down with a blinking indicator light. Unplug and replug will correct the problem and let it start but once again, shutdown occurs with in 1-2 minutes. I suspect an issue with the photo switch and would like to put a switch on the heater to bypass the 'eye' at low temp. I live in a remote bush village in Alaska and have to have a heater that works as we frequently are at -30 to -50 for weeks at a time.
I am fully aware of the safey implications of bypassing the switch but am wondering if photocells dont work effectively at low temperatures. I have to be able to get equipment to operate that has frozen up and this is the only way available
Any help would be appreciated
Thanks
  • Heating & Co... Master
  • 3,087 Answers
Some photo cells the eye gets dirty with condensation due to the cold have found this on wood kilns when temp drops try cleaning ,or just by pass to give you some heat , you might have to clean it a few times to clear it ,
or you could remove eye at low fire when heater warms up try replacing eye , this is going on what we have to refire wood kilns when it was cold here acouple of weeks back . hope this helps you
Posted on Jan 12, 2009
I am working on a monitor 2400. heater will run normal until it reaches set temp. when it goes to mid burn the flame goes out and code 14.
E14 Flame failure: There are obstacles at circulation air inlet or outlet. Fan cage is clogged with dust. Gas pressure dropped when other gas appliances are turned on. (this may also apply to K1 fueled units if you have another K1 based heater)
Here are the rest of the fault codes I found:
Digital Display Reason of indication Trouble Point
E01 At pre-purge, flame rod is sensing flame when there should be none. Flame sensing circuit, grounded flame rod or pinched wire. E05 After power on, power supply to the microprocessor timing circuit is incorrect. Timer clock circuit bad or power cycles (hertz) to unit above or below acceptable levels.
E06 A starting of operation, the circuit to drive photo triac of solenoid pump is malfunctioning. Solenoid pump control circuit has a malfunction.
E08 Revolutions per minute of combustion blower are malfunctioning. Combustion blower or combustion blower control circuit has a malfunction.
E13 No ignition. Failure of ignitor, solenoid pump or circuit board. Incorrect wiring or flame rod touches to burner parts. Air pressure switch or overheat open.
E15 Power supply voltage too low. Voltage too low or power detector circuit has a malfunction.
E16 Load failure of combustion blower motor Flue pipe is restricting air flow.
http://www.keepuswarm.com/upload/M2400OwnersManual.pdf
http://shdashan.com/english/user%20manual%202200.pdf
Oct 29, 2015 | Heating & Cooling
Can you run your heater without a roll out switch?
The roll out switch is a safety switch. It is there for safety. The purpose of the switch is to cut the gas off if there is flame or excessive heat low in the heater as found when the heat cant exscape out the top. Many reasons for a roll out failure if you are tripping the roll out it is always a symptom of a larger problem.
Low gas pressure or lack of combustable air causes soot in the heater like that of a chimney. This will restrict the air flow through the heater. A spider web in the gas oriface or burner can cause a roll out flame to hit the roll out fuse. Indoor applications can easily be an issue with the exaust venting or fresh air supply. Outdoor applications it could be a wind down draft through the heater. Whatever the reason it is tripping the roll out fuse, by bypassing it you are allowing the gas and burn to continue in an unsafe condition which mean larger problems will arise possibly even the heater catching fire.
Jun 24, 2014 | Rheem Pool & Spa
Rheem RTG-64DVN model, brand new unit installed during the weekend. fired up but shout down automatically within about 5 seconds. showed error code 12.
contact your gas company if the error code is "12," indicating that the gas supply was interrupted.
have a good day !! In LP models, the 12 error code may also appear if the LP gas supply has gotten low. To clear the code, replace or refill the LP gas supply.
go here for a list of codes for rheem tankless water heaters-- www.ehow.com/list_7833182_error-rheem-gas-water-heater.html
May 09, 2011 | Rheem Tankless Hot Water Heater...
My mastertemp heater has a error 5 reading. Heater starts, then it shuts down after about 10-20 seconds.
This sounds like the flame rectifier (flame sensor) Below is a link to the manual to trace the part and also to get the part number.
http://pentairpool.com/pool-pro/manuals/section.php?s=28
Jan 20, 2011 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Do rinnai heaters run efficiently if turned up and down often?
Maintaining the lowest acceptable setting and leaving it at that temperature is the most economical way to run the unit. If the space is going to be unoccupied for an extended time (several hours), lower temperatures are okay. This minimizes the need to burst the heat to warm the space quicker. As I understand your unit, it minimizes electrical & gas consumption by basing the need on the temperature difference of actual space temperature and setpoint. The larger the gap, the more power and gas is consumed.
In summary, when the space is occupied, maintain a consistent temperature setting. When the space is unoccupied, maintain a lower setpoint.
Hope this helps. Good Luck. :-)
Feb 15, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
The heater is blowing cool air. The furnace blower keeps running and something ignites and then goes out immediately. any suggestions?
Clean or replace the thermo couple.
It must detect a flame a few seconds after the main gas valve opens or it shuts it down. Since you are hearing the burners fire up the ignitor is working and all the other safety circuits are working to allow the furnace to fire up.
The thermocouple is a small silver tube that protrudes into the flame of the main burners, remove it and scrub with scotchbrite pad or anything mildly abrasive. You just want to remove carbon and corrosion build up, re-install and see if it fires up.
I have two Goodman furnaces and if you are to maintain them your self you should keep on hand a thermocouple and a new ceramic ignitor. They will inevitably fail on the coldest weekend of the year and the only place to get them will be from a service company with a emergency service call ...$180.00 VS $60.00 off ebay or internet sales.
Also if your power vent fan is making ANY noise it is on its last legs and buying on in advance online will save you about $80.00 over the loca ldealers price......been there done that
Oct 24, 2009 | Goodman GMS90703BXA Heater
GE XL44 Spectra Gas Oven Range
Replace the electric ignitor, I did today... Temps are hotter than ever. $60 from an appliance suplier, easy to install.... Trust me
Jun 08, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Coleman patio heater 5040A770
These heaters are not designed to be operated below 40 degrees F. If the heater is used below 40 and if you have a gas tank containing less than 25%, the unit will not operate for long and will start going out. If the heater all of a sudden goes out without showing any flickering or pulsations, you have a bad gas valve, there is no thermocouple on this model. Fill your tank and try the heater again. If it continues, give Coleman a call at 800-835-3278.
Nov 15, 2007 | Coleman (5040B750) Patio Heater
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
