Question about HP Compaq FS7600 17" CRT Monitor
Philips 105 S7 crt monitor vga cable colour code
Hp monitor vga cable wiring solution
Hi,Sir/ i have lcd monitor Hp-L1502 its on position wen i start lcd without vga cable to frount lokation is red+green+blue colours step by step fliker&i can fix new vga cable.whats sulution?
Nov 10, 2011 | LG Studioworks 700S 17" CRT Monitor
I have colour issue with my Samsung CRT 55V monitor. The main colour look green and also the Red and blue works It seems to be an issue with the RGB cables soldered to the wrong pins. Please guide..
I think this problem might be VGA cable or colour IC of the monitor,so please if you can change these two things ,so very well, other wise you will go to the service center.
JAIN_IT {INDIA}
Sep 26, 2010 | SAMTRON 55V 15" CRT Monitor
My philips 104E 15" monitor is not displaying red colour at all.other two colours are perfectly OK.What could be the cause? is the red gun gone?
Yes, or the RED driver circuits is bad, check soldering joints on the CRT PCB. Simple thing to do is to check the VGA cable connection first, check the video card (reseating the card).
Apr 21, 2010 | Philips 107E61 17" CRT Monitor
VGA PIN
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Jul 17, 2009 | LG Studioworks 700S 17" CRT Monitor
Vga
psl show me colour codes of monitor vga cable
Apr 13, 2009 | SAMTRON 55V 15" CRT Monitor
Cable color codes for samsung syncmaster 753s
I want to fix new vga connnector on my smsung syncmaster 753s monitor and i am confused with colour coding please help me
Mar 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Phillips VGA Cable colour chart
you can use any vga monitor with the same color output and resolution setting just goto craigs list in your town and look for someone throwing one out detach old cable and reapply to your screen by either soder or splicing the wires independently together this is tricky
http://www.lammertbies.nl/comm/cable/VGA-monitor.html
Pin Name Function 1 RED Red video 2 GREEN Green video 3 BLUE Blue video 4 n/c not connected 5 GND Signal ground 6 RED_RTN Red ground 7 GREEN_RTN Green ground 8 BLUE_RTN Blue ground 9 VDC 5 VDC supply (fused) 10 GND Signal ground 11 n/c not connected 12 SDA DDC / I2C data 13 HSYNC Horizontal sync 14 VSYNC Vertical sync 15 SLC DDC / I2C clock
Jun 02, 2008 | Philips 107E66 17" CRT Monitor
Replacing vga cable
A VGA cable is a D-Sub 15 pin cable.
Connector information:
http://en.wikipedia.org/wiki/VGA_connector
Pinning information about midway down the page:
http://myhometheater.homestead.com/vgacable.html
Is that what you were looking for?
Mar 27, 2008 | SAMTRON 55V 15" CRT Monitor
HP Compaq FS7600 17" CRT Monitor Logo
106 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
