Dvd panasonic sa-ht335 defectiune f61 - Audio Players & Recorders
  • 336 Answers
SOURCE: im having a erorr saying f61
F61 is and amp error code. probably needs an output ic. could be a shorted speaker or bad cooling fan. Disconnect all speakers and turn it on. if the fans run and it still displays f61 then odds are very good an amp ic is bad.
Posted on Jan 24, 2009
  • 5 Answers
SOURCE: my panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Posted on Jun 22, 2009
heavyice
  • 374 Answers
SOURCE: panasonic surround sound system model # sa-ht95
Error code ' F61 ' on most Panasonic models indicate that the built-in diagnostics has sensed a fault at the output stage. This would normally refer to a failed output amplifier IC (?P/N RSN704D66P?). In some instances, the fault could also be triggered by:
  • strands of Speaker wires inadvertently touching each other;
  • faulty speakers;
  • failed Cooling Fan of the output IC.
Options then are:
  • consider a DIY (do-it-yourself) repair only if familiar with electronic components & circuitry, use of a DVM/VOM and a soldering iron. Access to a Service manual would be an advanatge;
  • seek the services of an authorized service center specially if the unit is still under warranty;
  • consider other options based on downtime, cost of repair, parts of availability, age of unit and prices of comparable but newer models.
Good luck
Posted on Mar 06, 2010
  • 417 Answers
SOURCE: I have a Panasonic SA-HT650 Home Theater system
A power source problem. Means there is voltage measured at the output/speaker cable connections. Indicates a failure of the amp., or faulty power supply to it.
Just re-check all of your connections, especially speakers. And that the power ac power source from the wall is wired correctly and has proper voltage and grounding.
Posted on Apr 09, 2010
  • 189 Answers
SOURCE: Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
Posted on May 12, 2010
F61 sa ht 540
electrical problem caused by
Power digital amp IC op or DC output voltage abnormal.
need servicing
Nov 04, 2013 | Panasonic DVD-F61 Multi-disc DVD Player
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
Panasonic Dvd stereo system model number SA-VK960 power supply is defective. is it possible to repair?
Your Panasonic SA-VX uses a Switch Mode Power Supply ( SMPS ). Do not ever attempt to fix it yourself unless you are well versed in electronics. ou can damage the system seriously. Seek professional help.
Mar 10, 2011 | Audio Players & Recorders
We have a panasonic sapt550 music dvd player and want to play dvds in Australia-can you help
I Have problem with DVD play. Panasonic DVD home tHeater system SA-PT550. COMES UP WITH F61
Mar 07, 2010 | Panasonic Home Theater System System
Panasonic sa-ht540 f61 error message
If the model has a fan fitted (may have 2) that be your problem faulty fan
Aug 26, 2009 | Televison & Video
My panasonic SA-AK57 it is displaying error code F61
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
Panasonic SA-HT940
F61 is a problem with the output amplifier pac. It is the equivalent of "protect" mode. The output pac needs to be replaced. I'll look up the part number for you.
Dan
May 14, 2008 | Panasonic sa-ht930 Home Theater Audio...
How do I solve Panasonic SA-HT800V error code F61?
unplugged a Panasonic HDTV plasma for four minutes, plugged back in and Now the DVD does not work.
How to reset?
Aug 28, 2007 | Panasonic sa-ht800V Home Theater Audio...
223 people viewed this question
 Grubhead
Grubhead
