Question about Ricoh Aficio SP C820DN Laser Printer
Hello I have a RICOH C820 with an error message that the Magenta Toner is empty. I have replaced the cartridge 2 times and still get the out of toner message. Is there a way to reset it or other known solution?
  • 624 Answers
SOURCE: Ricoh CL3000 Laser Replace Waste toner
Couple of things to try: - If you just emptied the waste cartridge then you have to take the bottle back out and clean the insides as well. The sensor sees the toner on the walls and still thinks it?s full. FYI as typical the manufacturer recommends replacing the bottle with a brand new one. - If not that then you may have toner covering the optical sensor. Try blowing the area where the waste bottle attaches to the printer with canned air. Let us know if you have any other questions and please don?t forget to rate this post.
Posted on Feb 17, 2007
  • 95 Answers
SOURCE: Ricoh CL7100 - Toner Cartridge Error
Not one answer for this problem. It could be the tube going from toner cart to developer unit is clogged or kinked. It could be the dev unit. Get a toner vac and remove toner and black cap and spring and using the round hose end create seal and vac the tube. The part that goes into the toner cart has hole on the very end, it might have broke off (look at another color to verify). The worst case is the toner attraction pump has failed. One fix is shake the toner and reinstall.
Posted on Mar 11, 2009
  • 95 Answers
SOURCE: Ricoh Aficio SP C410DN "set toner cartridge correctly"
It sounds like the part the toner bottle slides under to lock in place is broken. you could try and fold some paper and tape it to the toner to hold it down.
Posted on Apr 23, 2009
  • 95 Answers
SOURCE: Ricoh C410DN set the toner cartridge correctly
If you look at one of the other colors you can see how the toner cart door slides under some plastic to open it. I bet the yellow one is broke. Tape a folded piece of paper to the end of the cartridge. That might hold it down so it will work.
Posted on May 29, 2009
newport74
  • 58 Answers
SOURCE: how to turn off the 'toner empty' message on a Ricoh 1170L
Just looked in the service manual. There is no SP to turn off toner message. The only way to clear it that I can see is to add another toner cartridge.
Posted on Apr 14, 2010
Ricoh CL4000DN. I recharged the magenta toner using the OEM cartridge. I replaced the chip as instructed and all elements snapped together without difficulty. However, now there is a "check toner...
Hi, the chip on those toner bottles stores information about how much toner is left, so once that chip registers an empty toner bottle, it won't work even if you attach it to a new toner bottle. You'll need the chip from a new toner bottle, or one that hasn't registered no toner.
Jan 22, 2011 | Ricoh CL4000DN Laser Printer
Error 9-355 on dc12 xerox
That is a magenta toner empty message, either the magenta cartridge is empty or there is an issue with the magenta toner dispensing.
Nov 14, 2009 | Xerox DocuColor 12 Printer
Error message OKIC3200n printer
I called the OKI help number, in the manual, and they told me that the second line of the error message, was just an additional reminder, to replace the magenta toner.
Sep 29, 2009 | OKI C3200n Led Printer
Toner empty message after replacing the toner Ricoh fax2210L
menu # 1934 menu search for new cartridge and then click yes yes ,turn power off and on.
Jun 18, 2009 | Ricoh FAX2210L Plain Paper Laser
Gestetner DCS424 error message: replace used toner bottle
There are 2 waste toner cartridges, be sure to empty these 2 cartridges . If you remove the waste toner in both cartridge it will automatically clear the error message.
Feb 27, 2009 | Gestetner Copier
DCS424 error message replace used toner bottle
Jan 30, 2009 | Ricoh Aficio CL7100 Printer
Magenta cartridge empty
When you take the toner cartridge off the imaging unit, is there magenta toner in the open slot of the IU? Assuming that there is nothing wrong with the toner cartridge, you are possibly looking at a bad engine control board.
Jun 11, 2008 | Xerox Phaser 7300DN Laser Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Ricoh Aficio SP C820DN Laser Printer Logo
156 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
