Question about Beko Genuine Flavel Washing Machine Drain Pump 2880401800 Wm And Wf Models
Washing comes out wet after spin
Filter is clean
All cycles work but clothes come out wet, top loader model# AAV7000AWW is there a lint trap that needs cleaning?
Lint traps are in dryers, not washers If clothes still come out wet then perhaps the water pump is not working properly and/or the drum is not spinning fast enough to allow centrifugal force to remove water from clothes.
Feb 07, 2016 | Washing Machines
Hotpoint aquarius extra 1000 spin washing but when spinning, clothes coming out still soaking wet. Help!
Check the machine filter, clean it and this problem might go away. Use manual for locating the filter.
Feb 28, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Clothes wet....not spinning as fast.
Suggest you check and clean filter, if clear then check brushes in motor.
Please rate my solution.
Thanks.
Mar 23, 2009 | Bosch Nexxt 300 Series WFMC2201UC
After washing clothes are still coming out wet
If its a washing machine there going to be wet arent they lol.
right if you mean that they are soaking wet after spinning it could be that the water is not draining away fully, have you checked the filter and cleaned that out, usually at the front of the machine on the bottom right. try draining that, or there could be a blockage in the waste pipe,
hope that this helps
Feb 28, 2009 | Hotpoint WMA30 Front Load Washer
Indesit WG820 no power in spin
For your model I hope you will find the filter, seen similar models. Disconnect the machine from the mains outlet. Below the door, there's a plastic cover full machine width. Just remove it and on the right you'll see the filter. Unscrew the filter counter clockwise, clean it, check the pump blades and inlet for some foreign objects and screw filter back on.
Jun 01, 2008 | Washing Machines
Clothes wet, doesnt spin fast
Check the drain spigot, where the drain hose attaches to the drain trap under the sink/tub.There may be a blockage in the spigot which is causing the water to drain very slowly and therefor not allowing the machine to spin at normal fast speed.
Oct 22, 2007 | GE Energy Star WCVH6260F Front Load Washer
Troubleshooting after cleaning out filter strainer
Do you hear if pump works or water coming out from the machine ?
Jul 23, 2007 | GE WBVH6240F Front Load Washer
Clothes too wet
Watch the washing machine go through its complete spin cycle.(It could have a filter in the pump,check for water flow coming out of the drain. Make sure the washing machine is fully leveled with a square. make sure you put fairly big loads to keep it balanced. If the washing comes out wet on the final spin ,add some more garments and then put it on spin again as the w/m might be going out of balance. Under the work bench on top some times there is a spring to adjust the tension. about every five or six years the motor brushes need changing.
Jan 04, 2007 | Bosch WFL 2463 Front Load Washer
Beko Genuine Flavel Washing Machine Drain Pump 2880401800 Wm And Wf Models Logo
20 people viewed this question
Top Beko Washing Machines Experts
micky dee
janman
Domenico Grillo
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
