Question about Sanyo DP37647 37 in. LCD TV
There is no picture and the screen is just flashing blue, green and red
    Master:
  • 879 Answers
Main digital board should be suspected. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by typing in the brand name of the device in the "Search Box", at the top right of the display window.
Posted on Dec 04, 2012
Xenius 37" lcd blue light just keeps flashing
my 37" xenius tv started losing its picture to a stripe screen then started flashing red blue green .know wont come on at all .wht part do i need to fix it please
Aug 07, 2012 | Televison & Video
Bush lcd tv has sound but no picture when switch on tv screen is blue then goes black and you can hear the proggramme that is on
acoustic solutions lcd tv when i switch it on the screen flashes blue, green then red no picture??? it was working ok last night any ideas?
Jan 23, 2010 | Polaroid FLM-2632 Television
Kp-65w500 green flash... led blinks 8 times
I am going to guess that model number is actually KP-65ws500
This is one of group of Sony sets that had bad picture tubes---red, green, blue----the tubes are no longer available and can only be obtained by removing the bad one and sending it out for rebuild (very expensive)
There is one easy thing you may be able to do to correct this problem---It involves no replacement of parts and is just adjusting the Green screen control---usually if this is the case when set comes on background will be somewhat (in your case) green---best way to see this is turn set on and have it on a unused video input---if screen appears somewhat green and has curved retrace lines--you may be able to turn the Green screen control down and continue to use the set---set will shut down if any of the 3 picture tubes pulls too much current--ie--goes to bright green, red or blue.
Let me know if you want to know how to attempt this
SD TECH
Oct 03, 2009 | Sony KP-65WS500 65" Rear Projection...
Green screen
If you are using the component video input change the input setting of the DTV input from RGB to Y, Pb,Pr also make sure the DVR's setting is 1080i output. this set can only except 480i, 480p and 1080i only. also make sure you have the green wire to the green input the red to the red input (some have mistaken the red audio for the red video) and the blue to the blue input.
Mar 19, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Sony kp41s3u - blue screen
Convergence amp ic bad or loose connection on ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Feb 26, 2008 | Televison & Video
Greenish picture, or lack of red.
Not tuner........Did you check RGB screen adjust up front
behind access panel?.....Possible CRT issue.............T.
Nov 27, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Help with kogi F9AH screen
Intermittently displays bright red/green/blue raster then shuts down with led flashing 2, 4 or 5 times
Amazingly this was due to the CRT being faulty !
Blank raster
Replace defective TDA6111Q for Red, Blue and green
Red or Green or Blue screen
Check and replace on crt module : D702, D703, D704 (all 1N4148) replace with type 1N4948T
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Nov 23, 2007 | GVision F9AH-TG Television
Rca d61w20 dominate red & blue screen also very blurry picture
Red and blue present, but no green = bad green CRT is
best guess.Remove lower front panel = adjust screen and focus
controls for best pix..................T.
Oct 30, 2007 | RCA P52926 52" Rear Projection Television
Red Light
convergance ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Sep 03, 2006 | Hitachi 57SWX20B 57" Rear Projection...
Sanyo DP37647 37 in. LCD TV Logo
41 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
