Question about KDS Valiant 6380iPTD-01 Notebook
Got a f.75 on boiler have to put pressure up to 2.0 bar before it starts
  • 13 Answers
I take it this is a Vaillant EcoTec boiler? If your having to pressurise to 2.0 before the F75 goes, there's a strong probability there's a problem with the water pressure sensor. These can sometimes just have dirt/sludge in them, and can be cleaned, however a lot of the time they just need to be replaced. F75 can also mean there's a circulation problem through the boiler, and you will get the same fault code. If you have the old rubber hoses on the flow and return pipes, these can be prone to blocking/restricting and Vaillant have actually modified this part whereby by the pipes are solid copper.
Posted on Oct 16, 2013
Problems whith astoria argenta
Hi just a tip from experience, grind the coffee fine and keep the spout ( where the coffee comes out) very near the cup, while making the coffee.
Kolbrun
Mar 06, 2014 | Astoria Coffee Makers & Espresso Machines
Worcester 35cdi overflow problem
if by overflow pipe you mean pressure relief valve either your expansion tank is full and needs to be drained if that type or replaced if bladder type. but if 1.5 bar is normal pres reading then the pressure relief valve is bad (it is a wear item )
Nov 12, 2013 | Heating & Cooling
Baxi duo-tec boiler - when water comes on flame roars up. When i put the heating on the flames roar for 5 minutes then die down.
is the boiler a combi if so have you checked the pressure. it needs to be at 1.5 bar 2 bar at the most . also check that the heat the boiler is producing is completeing the circuit on the heating if you have access to the pipe work there should be 2 or 3 22mm copper pipes. now turn the heating on and check which one is getting warm. the one that is is your flow and in about 2 to 3 min there should be one more pipe getting hot let me no if this is the case
Oct 27, 2012 | Universal 900MM Super Thermocouple Baxi...
I have a Laars Max Boiler 75, 90K with white smoke out chimney
Hello
Yes,more then likely its moisture from the high effenicey system of the boiler.
I have a laars boiler at work and some mornings when its cold out it looks like there is a fire, which is really only steam.
As long as your not shutting down on low water failure or loosing pressure and holding temp.This is normal.
Hope this helps.
Jan 26, 2010 | Heating & Cooling
How do I re-pressurise the boiler via the temporary filling loop
you may need to hook a hose to the drain and to a spigot depending on your water pressure in your home and back feed the unit to desired pressur,, does t have an auto matic feed valve or just a shut off valve,,
Jun 15, 2009 | Water Heaters
Hot water no steam low psi
Boiler pressure gauge should be showing in the green zone which should get you 195+ degrees.
Nov 17, 2008 | Astoria Argenta SAE-2 Espresso Machine
KDS Valiant 6380iPTD-01 Notebook Logo
330 people viewed this question
Top KDS Computers & Internet Experts
RobertFonner
RobertFonner
daibras
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
