Question about Sony 2GB Memory Stick PRO Duo Memory Card
My memory card shows me formatting error - Sony 2GB Memory Stick PRO Duo Memory Card
  • tejpalsingh Feb 08, 2009
    my memory card showing formatting error on computer.
  • 54 Answers
Ok, there may be a very little switch on the side.
Try to switch it up, and then use it!
Posted on Jan 11, 2009
  • Ismail Archible Jan 11, 2009
    ok, there may be a very little switch on the side.
I can not formate my SD memory card it shows windows was unable to formate
You will need special formatting software from the disk maker. Windows XP will not normally format a sd memory card.
Dec 21, 2013 | Electronics - Others
Reset console now r4 card will not work
memory-card-formatting
check above link for memory card formatting and solution of memory card problems like memory card not formatting, memory card showing errors etc
Jul 31, 2013 | Electronics - Others
I am having w580i mobile now if i put memory card means it shows to format memory if gave format option means after that it was showing FORMATTING FAILED. so how to solve that problem
1:friend connect the mobile to the PC and select mass storage option
go to my computer and right click on the memory card Icon click on format select full format option .
the above solution will solve your problem if the error is coming because of bad-sector
2:some times these error comes if there is a code to THE memory card.
3:the memory card is faulty or is infected with virus
Mar 29, 2010 | Sony Ericsson w580i Cellular Phone
"format error" message
Reinsert memory card in camera and try to format it. If that does not help then check with new memory card as old memory card could be defective.
Thanks.
Mar 03, 2010 | Sony Cyber-shot DSC-S750 Digital Camera
When I put the memory card in and turn on the camera, it keeps saying memory card error.
If camera show Memory Card Error, Check whether the card is inserted properly or not. For SD card, check out the card lock switch is in the correct position and not stuck in between.
You can Format the memory card in the camera using the Setup Menu option (Format). Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data.
If after formatting the card do not clear the error, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Rating the solution is highly appriciated...Good Luck
Mar 03, 2010 | Canon Power-shot S1 IS Lens Converter
When i turn the camera on it says memory ard error
Mar 01, 2010 | Optics
Formatting time it shows write protected error
SD cards nad microSD adaptors have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 01, 2010 | PNY 2GB microSD Memory Card
My Sony DSC-S75 camera shows a format error when I insert my 128MB memory stick also blinking is C:13:01. Any idea's how to fix? Thanks!
Format error display shows memory card is unstable and need to be format through format option in Camera menu.
Format memory card, if that does not fix the issue, try another memory card in camera and check this memory card in another camera just to make sure either camera got problem or memory card is bad.
Jan 01, 2010 | Sony Cyber-Shot DSC-S75 Digital Camera
My sony dsc-w100 digital camera says format error and hangs on. what shall i do??
Take out memory card from camera, turn it On and check does it show format error?
If yes, press Home, Memory option and format internal memory.
If camera does not show format error then put back memory card in and press Home, Memory card option and format it.
This will delete all files/ data and will refresh memory card, take some pictures and check.
If after formatting, still format error exist, put new memory card.
Nov 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Sony 2GB Memory Stick PRO Duo Memory Card Logo
52 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
