Kenmore elite washer top loader does not drain and spin. If the tub is emptied the cycle will restart and several more loads can be washed. I have hot wired the pump to drain the tub, but it is a hassle. Help?
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 04, 2012
  • 185 Answers
SOURCE: Kenmore stacked washer/dryer - washer problem
check the timer
Posted on Mar 31, 2008
jsrock516
  • 5911 Answers
SOURCE: Spin Cycle on Wash Machine does not work
The problem is your lid switch. This is a common problem with this model washer, and a very simple & inexpensive problem to fix. Click on the following link for advice on how to replace:
http://www.fixya.com/support/r385198-replacing_lid_switch
You can find a replacment switch at searspartsdirect.com. Just type in your model number and look under the "Cabinet Parts" heading on the next page. I believe thats the heading the part is listed under. Sears has excellent part locator drawings to assist you in identifying the part. Once you have the part number identified, you can do some comparative shopping at other online websites too. Use the part number that Sears provides, however. A new switch usually runs about $25 to $35. In addition, make sure you check the lid strike. This is a small plastic piece on the lid that is used to activate the lid switch through a small slot. If the lid strike is broken off, it will give the same symptoms of a defective lid switch. I hope this information helps you. Please post back if you have any questions.
Posted on Aug 04, 2008
jsrock516
  • 5911 Answers
SOURCE: kenmore elite HE4T front load washing machine standing water
This problem can be caused by either a leaking water inlet valve, or a condition known as "siphoning". Since you just recently moved, I would make sure you don't have a siphoning problem, first. The following link explains how:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although siphoning normally refers to a constant drain problem where a washer has problems maintaining the proper water level, it can also lead to problems where the drain line will back up into the washer.
Now, if you follow the advice in the link and determine this is NOT caused by siphoning, I would suspect that you have a water inlet valve that is leaking. A tell-tale sign will be water trickling down the fill tube in the rubber door bellow. The water inlet valves have a diaphragm that is controlled by an electric solenoid. Sometimes the valve becomes clogged with sediment or deposits, causing the diaphragm not to close properly. If you live in an area that has hard water, or use well water, you may have hard water deposits or rust build up in the valve. You may be able to correct the problem by removing the valve and cleaning it with some distilled vinegar. You can remove the valve by following these steps:
1. Unplug the washer and turn off water supply at the taps.
2. Disconnect the water inlet hoses.
3. Remove washer top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel slides back, then off.
4. The inlet valve (this is what your water inlet hoses connect to) will be located in the left rear of the washer (facing from the front). Remove the dispenser hose(s) from the valve and the electric connections. Remember how the electrical connections are removed. They should be color coded. One is for HOT, one is for COLD.
5. Remove the mounting screws that hold the assembly in place.
Once you have the inlet valve removed, you can place it in some distilled vinegar and let it soak. Just don't submerge the electrical connections. If this does not correct your problem, replace the valve. Searspartsdirect.com and repairclinic.com are two notable web sites that I have frequently used. Just type in your complete model number to begin the parts search.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 02, 2008
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
SOURCE: kenmore elite washer leaks water in spin cycle
You need to replace your pump. Make sure you have the washer either on something that will absorb water, or fix it outside/garage. Because these pumps hold extra water and that is why it is not recommended to keep them outside to do laundry in colder climates. The water can freeze in the pump and wreck it. Good luck. They actually are pretty easy to replace.
Posted on Apr 26, 2009
Why does it leak all over floor after last spin cycle?
my washing machine leaks water onto the floor during each spin ...
https://answers.yahoo.com/question/index?qid...
Feb 3, 2010 - During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. ... It happened to us due to over loading. ...something can get betwen the two tubs it this all fails your tub seal is ...
Sep 30, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Clothes still wet after cycle is over
Be sure drain hose is not kinked and no higher than the top of washer to drain pipe. Remove clothes as soon as it stops spinning
Jun 23, 2010 | Kenmore 23822 Top Load Washer
Water pours in on spin cycle
The first thing i would check is your boot around the door for a rip or tear. Also check the drain line for any types of leaks. You can also remove the bottom panel there will be three torx screws and you can look at your drain pump while in spin and drain cycle to see of the leak located in that area.
Hope this helps _MJ_
Jan 29, 2010 | Kenmore Elite 45986 Front Load Washer
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Machine will not switch to drain and spin cycle
If you take the front off in the lower right you will find a pump motor that controls the drain flow. This may defective. Use a shop vac to empty the water in washer if needs be. But remove and test this pump.
Apr 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore washer - water is emptying from tub but clothes are not spinning dry
replace door switch.If the computer thinks the door is open, it will not fast spin as a safety precaution.
Feb 27, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
