Question about Price Pfister Treviso Single Handle Kitchen Faucet with Side Spray ...
Replace a price pfister treviso cartridge
Cannot remove carthridge
SOURCE: I can't disconnect the quick connect sprayer hose Price Pfister
Squeeze the bottom half of the 2-piece black plastic cylinder that connects the sprayer to the faucet. Gently pull down on the hose. If the connector is not a 2-piece cylinder, you need to push the connector up, as if you were connecting it, and while it is pushed up tight, pry up on the small ring on the top and gently pull down on the hose. I know it sounds like you need 3 hands, but it works (even though it is a pain).
Posted on Apr 22, 2010
SOURCE: Replacement Price Pfister sprayer/hose
I called Price-Pfister and they sent out the parts free under their warranty, plus a few dollars for postage.
Posted on Apr 26, 2010
SOURCE: i have a two handled price pfister kitchen faucet
probably the diverter, order from mfg & replace or you can disassemble diverter and replace internal white part and O ring which is what I did and worked great
Posted on Nov 20, 2010
  • 10865 Answers
SOURCE: I have a Price Pfister
Hi adheinen. In order to remove the side sprayer and hose from the diverter tee you must push the hose connector into the diverter and then push the grey ring in. Then pull out the hose connector. Here is a video showing exactly how this is done. Joe
http://www.pricepfister.com/about/diverter.aspx
Thanks for choosing Fixya!
Posted on Nov 27, 2010
packrat1948
  • 528 Answers
SOURCE: I have a Price Pfister Marielle Kitchen Faucet
That faucet was discontinued some time back for the one you ordered parts for and the only way to get the part if it is still available is to know the part number. Now if you have a plumbing parts house in your area that specializes in faucet parts they may be able to match up the old part if you still have it.
If you can find the part number for the faucet you have then the part may still be available from Price Pfister.
Posted on Mar 03, 2011
How do I fix a leaky Price Pfister Treviso 49D faucet.
Download the instructions from the manufacturer.
Dec 28, 2014 | Price Pfister Plumbing
Pfister tub faucet is blocked
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets and knowledge of how these work.
Rod
US Parts Center
Jan 29, 2013 | Price Pfister Pfister 806-dy11 Treviso...
Remove handles from price pfister treviso double handle faucet
replace rubber seal in tap need to unscrew the nut to get at it
Nov 27, 2011 | Plumbing
Instructions for installation not in box
Hi here is your instruction manual for your faucet. Good Luck
Price Pfister 48-DCOO
Tool Belt Diva
www.toolbelt-diva.com
May 15, 2011 | Price Pfister 48-DC00 Treviso 4''...
The threaded shank for the soap dispenser broke on our Price Phister model KSD-M1YY soap dispenser. Can't find a replacement. The model # of the faucet isT26-4DYY. Can you help?
Most parts can be ordered though Price Pfister Directly 1-800-PFaucet. Here is a link to the parts diagram for your faucet. http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/treviso/tret26-4d/ex-026-02.pdf  If by threaded shank you are talking about the bottle, then you can order just a new bottle (Part # 950-004) if not you may need to order a whole new soap dispenser (Part # 920-054.) If you order a whole new soap dispenser than make sure you order the correct finish to match your faucet.
Oct 09, 2010 | Price Pfister Marielle Kitchen Faucet with...
How do I remove handle of lavatory faucet to replace cartridge? The faucet is dripping and making a noise
There should be a small hole under each lever handle. Inside the hole is a handle setscrew. Use a 2.5mm hex wrench to loosen, not remove, the setscrew. turn the screw counter clockwise to loosen, and then the handel should just pull straight up and off the faucet. Here is a parts breakdown for the PRICE PFISTER Treviso Wide Lavatory Faucet T49-DK00.
Sep 07, 2010 | Price Pfister Treviso Wide Lavatory Faucet...
Dripping faucet price pfister kitchen
Very nice kitchen faucet. I like Price Pfister's products. To repair it you will need a phillips screwdriver to remove the handles and crescent wrench to remove the cartridges. If it is dripping then one of the faucet cartridges need to be replaced. Its best to replace both cartridges as inevitably the other one will start to leak after you've replaced the troublesome one. Your local hardware store or plumbing supply store should have a replacement cartridge for this model. Remove one of the cartridges and take it with you to ensure you get the correct part. There is an exploded diagram of your faucet on the Price Pfister site at that shows the part number for the cartridge. Good luck and let me know how it turns out.http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/savannah/savf8h6-85/ex-036-01.pdf
Jul 25, 2010 | Price Pfister Savannah Two-Handle Kitchen...
I have two Price Pfister Treviso tub/shower faucets in my recently completed home. One drips constantly and one doesn't. I have removed the cartridge and cleaned all parts and surfaces of new plumbing...
I had the same problem on mine...it ended up being how tight I had the screw on the handle. I loosened it and it quit. Also, you might try different tightness on the valve nut.
Hope this helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Nov 29, 2009 | Plumbing
PRICE PFISTER TREVISO SINGLE HANDLE SHOWER - WATER NOT HOT ENOUGH
Check the manual that came with the unit and it should tell you how to adjust the max temp inside the fixture. Hope this helps!
Apr 02, 2009 | Price Pfister 048-DZ00 Oil Rubbed Bronze...
Price Pfister Treviso Single Handle Kitchen Faucet with Side Spray ... Logo
253 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
