Question about Linksys Wireless-G Range Expander (WRE54G)
Can't connect to the internet after range expander set up
After I install and set up the Linksys range expander. I show that the wireless connection is connected at an excellent rate but when I bring up IE it can't find a web page.
  • 54 Answers
Ok, what you need to do is reset your Linksy wireless connector box, hold button for 30sec. After, you need to try to connent it to your phone and or computer. Try to see if you have a connection.
Posted on Jan 11, 2009
Cant find a strong enough connection
You need to buy a Linksys Wireless-G Range Expander to boost the signal
  • Move your wireless router to a central location in your network, keeping in mind that the router should be at waist level at the very least, not on the ground.
  • Plug in the Linksys Wireless-G Range Expander in the room where your wireless router is. You'll move the range expander later, but for setup purposes, it should be in the same location as your wireless router.
  • Press the Linksys Wireless-G Range Expander's "Auto Configuration" button for five seconds, which will allow the range expander to detect your wireless network and configure itself with the appropriate settings.
  • Unplug the Linksys Wireless-G Range Expander and relocate it to a location closer to the Xbox 360.
  • Ensure that the antenna for the Linksys Wireless-G Range Expander is pointing upward, and keep in mind that the higher the range expander is placed, the better performance you will get out of it.
  • Plug the Linksys Wireless-G Range Expander back in, and your wireless network should have a much greater range, ensuring that your Xbox 360 is able to maintain a good connection to the network.
  • Dec 29, 2010 | Microsoft Wireless Network Adapter Xbox...
    Hi, I just got Linksys WRE54G V.3 and was trying to install the CD. But I keep getting "Site Survey fail" message. My house is using a router made by Apple, and does not have extra space to...
    The range expander helps to extend the range of wireless network...
    Anyhow the range expander has to be placed withing the range of your Apple "wireless" router (Make sure your apple router is wireless router, if it is a wired router, then there is no use of range expander...! U need to buy an Access Point instead)...
    your range expander must be connected to the computer(using an ethernet cable) from which you are trying to configure...
    Site survey searches for the available wireless networks in range...
    It should show your existing wireless network...
    You need to select your appropriate network and you need to configure the Range expander wireless settings according to the Apple router's wireless settings...
    exactly the same SSID(Network name), Security type and encryption technique, password PSK (security key) has to be selected on your range expander as in the APPLE wireless router...
    Thats it...
    You are done...
    Your wireless network range would have extended now....
    Dec 09, 2010 | Linksys Wireless-G Range Expander (WRE54G)
    I have a netgear wireless router with WPA security. and i bought a WRE54G . I cannot configure the expander as you know netgear IP is 192.168.0.1 and lynksys expander is 192.168.1.240. when i open...
    Try to reset WRE54G
    Resetting the Range Expander to Factory Default
    The range expander can be set to factory default by pressing the Reset button of the range expander for 20 seconds.
    NOTE: The default IP address of a range expander is 192.168.1.240.
    After resetting the range expander to factory default and you're still unable to access the web-based setup page, make sure that your computer's proxy settings are disabled. For instructions, click here. To disable the proxy settings using a Mac computer, click here.
    NOTE: If all the steps above failed, try to disable any security software on your computer before accessing the range expander's web-based setup page. Click here to learn how to disable your computer's firewall.
    If you are using a Wireless-G Range Expander (WRE54G v2 or v3) and you can't access the web-based setup page, perform the following steps:
    Checking Physical Connections
    Make sure that the computer is connected to the range expander's LAN or Ethernet Port. If the range expander is properly connected, check the LEDs on the network adapter. For instructions, follow the steps below:
    Checking LEDs on the Network Adapter
    Make sure that the LED light of the computer's network adapter is lit or blinking. After checking the LEDs on the network adapter, assign the computer a static IP address.
    NOTE: If the network adapter's LED is not lit, try using a different cable to further isolate the problem..
    Assigning the Computer a Static IP Address
    For instructions on how to assign a static IP address on your computer, click here. After assigning a static IP address, check the computer's connectivity to the range expander.
    Checking the Computer's Connectivity to the Range Expander
    For instructions on how to check the connectivity of your computer to the range expander, click here. If you're still experiencing difficulty accessing the web-based setup page, reset the range expander.
    For instructions on how to restore the range expander to factory default, click here.
    If you're still having difficulty accessing the web-based setup page, make sure that your browser's proxy settings are disabled.
    If you're using a Wireless-G Range Expander (WRE54G v1), you need to do the following:
    For instructions on how to assign a static IP address on the computers' wireless network connection, click here.
    Connecting Wirelessly to your Range Expander
    NOTE: In this example we used WUSB54GS V1.0 (Wireless-G USB Network Adapter).
    If you're using a Mac computer, click here for instructions on how to connect to a wireless network using the AirPort card.
    Step 1:
    Run the Linksys Wireless Network Monitor by double-clicking this icon 3719-001.jpg at the bottom-right corner of your screen.
    4146-005.pngStep 2:
    Click Site Survey then select the SSID of your wireless range expander and click Connect.
    NOTE: The default SSID of the range expander is in this format linksysRxxxxxx.
    4146-007.pngChecking the Computer's Connectivity to the Range Expander
    NOTE: If you're using Windows 98 or Windows ME, click here.
    If you're using a Mac computer, click here.
    Windows 2000/XP
    Step 1:
    Click Start, then click Run.
    Step 2:
    When the Run window appears, in the Open field type "cmd", then click OK.
    3984-003.pngStep 3:
    When the MS DOS Prompt appears, type "ping 192.168.1.240" then press [Enter].
    Step 4:
    See if you're getting 4 replies, Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
    Nov 08, 2010 | Linksys Wireless-G Range Expander (WRE54G)
    Wife range
    Get a Range Expander in between
    Mar 24, 2010 | Linksys Wireless-G WRT54G Router
    How do use and install the linksys wireless range expander
    just plug it in and press the configure button on the side of it, and wait for both lights to turn solid blue, the eithernet port in the front is for connecting a router, or laptop, youknow something that takes an eithernet connection
    Dec 28, 2009 | Linksys Wireless-G Range Expander (WRE54G)
    Link light on (blue), activity light off (neither blue nor red)
    Press the RESET button on the back of the unit and reconfigure the settings.
    Sep 11, 2009 | Linksys Wireless-G Range Expander (WRE54G)
    How can i configure Linksys Wireless range extender
    hi ,
    i went through the problem ur facing and the only solution that comes into my mind is that u will have to do the wireless settings on the router and copy the same settings on the range expander as well .... no changes.... and do remember that range expander at that time should be connected to the router at that time with the help of an ethrnet cable .....
    ity would be working like a horse then ...
    Oct 23, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Linksys wireless G range expander
    Hi David,
    I need to know that what type of router u r using.
    If it is Linksys router just follow these steps,
    with the help of the Ethernet cable connect the range expander to any one of the 4 ports in the router...
    ur computer shuld be directly hook up to the router..
    open internet explorer in ur computer..in the address bar type in 192.168.1.240(ip address of the range expander)
    it will prompt for a username and password...leave the user name blank and the password will be admin.
    u can see the linksys range expander set up page...
    u can find SSID at the bottom of the page...
    ur router's SSID and the range expander's SSID should be same..and also the password should be same..
    If the ssid or password mismatch between the router and range expander u can find these kind of Error messages...
    Good Luck....try it and revert back
    Jul 03, 2008 | Linksys Wireless-G Broadband Router
    Wireless G ranges expander
    when using the range extender you have to make sure you set the SSID, channel & wireless key in the range extender the exact same as the router also it has to be in the same IP range so if the router IP address is 192.168.0.1 the range extender IP address has to change from 192.168.1.240 to 192.168.0.240. once that is done restart the range extender and disconnect the ethernet cable & it the 2 lights should light up blue.
    Jan 20, 2008 | Linksys Wireless-G Range Expander (WRE54G)
    Linksys Range Expander...
    Initially, it is possible that the WRE54G has not been configured to talk with WiFi AP/Router downstairs and all that is needed is to configure/set it up.
    Setup (to be done in the same room where your WiFi AP/Router is installed and preferably with your daughter's laptop which can already connect to your network when it is near):
    1. Download the LinkSys WRE54G Setup Wizard from the LinkSys site;
    2. Use a LAN cable connection to the WRE54G Ehternet port (located underneath a flip lid in front panel) to one of your daughter's laptop;
    3. Power up the LinkSys Expander;
    4. Press the Range Expander’s Auto Configuration button for about five seconds. Normally this should be sufficient for the Expander to auto-detect and auto-configure itself;
    5. Power off;
    6. Move the Expander to your intended place of installation;
    7. Again using your daughter's laptop, expand/install the downloaded LinkSys Setup Wizard. Soon as the program is running, follow the on screen instructions. Please don't forget to Save before exiting.
    8. Move your daughter's laptop to its intended location and try the system.
    Should you still need a User's Guide, it is available here.
    Another possibility that we cannot discount is that the WRE54G is also not reaching your router downstairs. Perhaps what can be done is installing it not a floor down from your daughter's but halfway between your daughter's floor and your office downstairs.
    Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
    Good luck and kind regards.
    Nov 16, 2007 | Linksys Wireless-G Range Expander (WRE54G)
    Linksys Wireless-G Range Expander (WRE54G) Logo
    664 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    mark
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
