Question about Sewing Machines
I have a pr600 brother embroidery machine,it trims the thread too short
It cuts the thread too short that when it restarts it comes off the needle it's frustrating to have to thread the every time
  • Sewing Machines Master
  • 1,564 Answers
Make sure that when your machine stops and cuts that your needle is in the upper most position. Other than that you may need an adjustment from a pro repairman.
Posted on Dec 04, 2012
4 Suggested Answers
SOURCE: Brother PR600 embroidery machine has
Hello .
my PR600's touchscreen has stopped working properly.It is now hard to get it to work .
Posted on Aug 10, 2010
  • 109 Answers
SOURCE: brothers pe150 embroidery machine will not let the needle pick up lower thread
It sounds like the timing is off and needs an authorized repairman.
Posted on Aug 23, 2010
SOURCE: Brother PR600 embroidery machine, the needle
hook out of date
Posted on Jan 21, 2011
Re brother 770 embroidery machine: Needle shudders/shivers and the safety device light comes on. There is no nesting thread, the needle has been changed, with the flat surface facing back.
Check for proper threading of the machine, Making sure the groove of the needle is facing you as you use the machine. Even the way the bobbin is inserted and spinning in the correct direction, can be the issue.
Manual time...
Cheers,
Embroidery Services
San Diego, CA
Aug 05, 2017 | Brother Sewing Machines
My Brother HE 1 will not feed the top thread. When I embroider, the thread never comes off of the spool. I have rethreaded the needle, it is correctly threaded.
I don't have this particular machine, but have you made sure that you are threading correctly? I would completely remove your upper thread and put on a fresh needle. Also, whenever you do make a thread change, be sure and cut the thread at the spool on top and then pull the thread from the bottom (needle area) This will help prevent any fraying in the thread path that you can't get too easily. If this isn't an embroidery only one, try just sewing first so you will know if it feeds. It it does work in sewing mode, some machines are picky about thread. Here is a link for the path: http://support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=hf_he1eus&ftype3=2076&faqid=faqh00000007_000
May 17, 2017 | Brother Sewing Machines
Brother Sewing Embroidery Machine
I agree with sylviaivie about find another repairman, they are suppose
to guarantee the work they do.
when the upper shaft is replaced & then the machine is retimed
the machine should work just fine.
but just don't take it back to that man to be repaired
here is a tip if it happens again,,
always try to cut the top thread first,
& turn the machine up on it's back to access the bottom cover
take the cover off the bottom to get access to the bobbin thread
where you can cut the bobbin thread
then you should be able to get the needle out without breaking it &
damaging the upper shaft, replace the needle & make sure
that the thread is good quality & not knotty, clean out the bobbin area of lint or thread
always change the needle on the embroidery machine every project
make sure the bobbin area is kept clean of lint or thread
clean under the needle plate at least once a week for lint if you
embroidery everyday or just often
Aug 01, 2012 | Brother Sewing Machines
I need a replacement needle to embroidery. need to know the model#. I have a Brother SE-270D Easy Thread Cassette System.
The thread cassette has no bearing on what needle you use. You need a Schmetz embroidery needle with the red band size 75 for light to medium weight fabrics or a size 90 for heavier fabrics such as denim.
Dec 07, 2009 | Brother SE-270D Computerized Sewing...
My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Make sure that your needle is put in the correct way, there is a groove in the front of the needle, check with your finger nail, this is usually to be facing you, and make sure the thread is going through the tension holder correctly do not have the foot down when you are threading the machine,as this stops the thread from going through the needle tension holder.
Sep 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother PR600 embroidery machine has decided it won't thread any longer, had a wiper error which I cleared but the machine now won't thread the needles?
Just got the pr600 machine. Can't get the upper and lower thread to connect. Keep getting the error message to check upper and lower thread.
Jun 11, 2008 | Husqvarna Designer I
Brothers pe150 embroidery machine will not sew
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Mar 30, 2008 | Brother PE-150V Computerized Sewing...
Brother se- 2700 sewing/embroidery machine Comment by Loves2sew, posted on Jan 30, 2008 when pushing the thread cartridge in a piece snapped off the inside and I need a diagram to see where is belongs. It...
Brother se-2700 sewing/embroidery machine. My automatic thread cutter is getting very dull and won't cut any more. Can it be replaced? Where do I get a replacement?
Thanks porschegl
Jan 30, 2008 | Yamata FY101-1A
Sewing Machines Logo
171 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
