Question about Pentax 1.4xL SMC-A Rear Lens (30943) Lens Converter
Can the 1.4X-L converter A be used with an FA* 400mm f/5.6 lens ?
Projecting front element may be an issue ?
  • Kim Houlden Dec 04, 2012
    Please advise dimensions of the projecting front element ie diameter/length
  • Kim Houlden Dec 06, 2012
    Can the Pentax 1.4X-L converter A be used with a Pentax FA* 400mm f/5.6 lens ?
    Top Expert:
  • Pentax Master
  • 6,702 Answers
Consider a few points. Most camera's (The Pentax is no exception here) can only use AF till f/1:5,6. With a tele convertor 1.4 times, your aperture will be twice as small. So it will become 8.
So yes you can use the converter on your Pentax, but the camera can't work with autofocus. If there is enough light, you could be able to manual focus the lens and still make a shot.
Posted on Nov 26, 2013
Can Tamron 2 X converter C-AF 1 BBAR MC-7 mounted with Canon 100-400mm? Tks
As you can read in the Dpreview link the Tamron converter can work perfectly with the Canon cameras. Question is, will AF still work, because you have to multiply the aperture twice. So if your lens has f/1:5,6 that will become f/1:8. Most camera's can't auto focus anymore on F 8
link to Dpreview Tamron 2X converter
Oct 15, 2012 | Tamron F AF TELE-CONVERTER 2X C-AF1 BBAR...
Pentax MZ-60
have you tried cleaning the lens contacts with soft cloth?
ifnot do that.
is there no problem with out the lens in there?
Sep 18, 2008 | Pentax MZ-60 QD 35mm SLR Camera
How do I adjust my Canon EF 100-400mm infinity setting on the lent. 300 to 400mm is out of focus.
I don't know your photography background and skill, so these tips may seem overly basic.
Have you tested this on a tripod? Not using a tripod can add a lot of blur, even while using the IS.
I would also try the lens at f/8 and see if you have the same focus issues. If not, it may just be related to shooting the lens wide open, where it's not the sharpest.
I hope this helps. It's just a few things to try.
Send a comment if you'd like some other possibilities.
Happy shooting with a great lens!
Mar 06, 2011 | Canon EF 100-400mm f/4.5-5.6 IS USM Lens
I have a Sigma 400mm APO HSM Tele macro lens that I am most pleased with. It takes amazingly sharp pics, even wide open, that I am forced to do because I cannot get a re-chip done. My problem is that...
Sorry, but it's not a DIY fix as the lens will need to be collimated. Without this, you'll just be guessing the correct position and alignment for the loose optical element and won't get your image quality back.
Professional repair and re-collimation will not be cheap though and the lens may not fully recover its former sharpness, so it may be time to let your faithful friend go.
I hope my answer has assisted you in choosing a course of action; please take a moment to rate my reply.
Sep 25, 2010 | Sigma Telephoto 400mm f/5.6 APO HSM Macro...
Not getting the usual sharpness on far away objects
make sure all electrical contacts on the back of the lens and on the interface of the camera are clean. if not clean with some spirit. Do not use sand paper. Does the camera work with other lenses ok ? also are the lens elements clean both front and back.
Jul 25, 2010 | Canon EF 100-400mm f/4.5-5.6 IS USM Lens
I have vivatar 100-400mm lens with stripped out
Try Protech, Uckfield, East Sussex for estimate of repair cost
Mar 13, 2010 | Vivitar 100-400mm f/4.5-6.7 Series Lens
Cant seem to fit the converter to a 50-500mm ex sigma lens ?
It all depends upon the lens. Not all lenses can accept teleconverters, usually due to projecting rear elements incorporated into the individual lens design. With such lenses, manufacturers will either advise that a particular lens will not be compatible with a teleconverter or for some models may produce a custom matched model usually for that lens alone.
Which exact lens are you trying to fit to your Sigma 1.4x EX APO DG teleconverter?
Feb 05, 2010 | Sigma 1.4x EX APO DG TELE CONVERTER (CANON...
How do you use it ...in laymans terms....settings etc. thanks
Your question ( in laymans terms) is unclear! But I will make a guess as to what it is you ask.
The 100-400mm is the focal length of the lens, To use it it has to be attached to the camera It it is capable of focusing clearly on an object at its maximum output as well as its minimum. At its maximum focus it can perhaps ( depending on optical quality) bring an object 4-5 Kilometers into clear view. Most lenses have a zoom factor and a focus ring. Experimentation with the lens will be a better way of defining what improvements it has over a standard 50mm lens
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 12, 2009 | Canon Cameras
Auto focus will not work with the 100-400mm 5.6
It's the same 3 as with the 1.4x, but be warned it is likely to be a very unsatisfactory solution in all but the very brightest daylight, and the lens will continually hunt for autofocus - you risk burning out your focussing motor.
If you really want to experiment, hold the converter so the writing on it is the correct way up. Looking at the row of gold pins, rotate the lens so they are at the top, or the 12 o'clock position. It is the 3 leftmost pins you want to cover. Use a piece of sellotape (scotch tape) to cover the three pins, you'll have to cut a thin strip to do it. Be careful as the tape could slip as you attach the converter to the lens adding more risk to the experiment if it gets stuck somewhere it shouldn't!
I tried this with my 2x (version 1) and a 70-200f4/L, it tries to focus but fails with the much reduced light. Might try it outside on a sunny day, but also scared of damaging my lens!
Jan 28, 2009 | Canon Extender EF 2x II Lens Converter
Questions on disassembly for sigma 400mm apo af
Hi
Sigma will not repair this lens as the fungs may be in the lens on the barrels and if thay could clean
or replace optics the fungs may come back so thay cannot give a guarantee I know someone who
cleans lenses let me know if you want to contack him
Apr 08, 2008 | Sigma 400mm f/5.6 APO Macro for Nikon AI
Pentax 1.4xL SMC-A Rear Lens (30943) Lens Converter Logo
152 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
