I have a Rowe Ami Berkeley and it wont play a whole CD and when the box is not playing a selected track it keeps taking a cd out spins it for a few seconds and then puts it back and goes to the next one and does the same. This continues until you select a cd track. Any ideas on the problem and where can I buy a manual? Thanks, Colin
    Top Expert:
  • Audio Player... Master
  • 34,763 Answers
I don't know why a CD won't play completely, but I seem to remember a jukebox of this type that employed the disc shuffling routine you describe as an "eyecatcher" to get you to play it. It probably can be disabled somehow
Posted on Dec 05, 2012
5 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: TADCAN CD-401
http://pdf.textfiles.com/manuals/ELECTRONICS/AV/CD-450_manual.pdf
heres the manual link print out manual and save
from manual discription the feature your looking for is on the front deck single auto repeat, repeat, single
i hope this is what your looking for
Posted on May 08, 2008
  • 195 Answers
SOURCE: Rowe CD 100 that will not play all Tracks
Are you initalizing the CD's in your jukebox after you install them?
If so it should play all of the tracks.
Regards
Alan Hood
ami-man
UK
Posted on Mar 03, 2009
  • 195 Answers
SOURCE: My cd rowe ami jukebox is stuck in scan/transfer mode
You say you do not have the digital display lite up, have you checked all of the breakers on the power supply?
If not do so. Rowe Ami jukeboxes are very prone to dry joints (cold joints in the USA) this is cracking around the soldered pin on the connections to the boards.
If you can solder correctly then check out the printed circuit board on the power supply. I would retest and see if the display now lights after correcting a fault on the power supply.
If that has not made any difference then proceed to the Mechanism Control Board and the Central Control Computer (CCC) and check again for dry joints.
If you can not solder with any confidence then send in your boards to a Rowe Ami specialist for testing/repair.
Regards
Alan Hood
ami-man
UK
Posted on Mar 11, 2009
SOURCE: jvc xlmv33 three tray karaoke cdg player
I took it to a repair shop, found out it would be very hard to fix due to age. could not get parts for it, so I will just get a new one.
Thanks for the suggestion
Posted on May 24, 2009
Code to initialize ami rowe jukebox
For full initialization, in service mode, press 3 to enter init. sub menu, type 0 for full initialization. Press popular, then put switch in normal position and initialization will begin. You can still select and play discs while initialization is in progress, providing you select from cd's already finished. The machine will continue initialization after selections are finished playing.
Feb 02, 2013 | Wurlitzer Jukebox CD Player
Rowe Nostalgia jukebox will only play a few of the numbers of the 100 cd;s. Is there anyway to reset it so it will play all numbers?
You will need to go into the programming section on the menu.
I suggest that if you do not have a manual that you obtain one from Rowe Ami, Victory Glass or distribution.
Have you initalised all of the CD's on your jukebox? Every time you replace a CD you have to initalise it.
Regards
Alan Hood
ami-man
UK
Jan 31, 2010 | Wurlitzer Jukebox 1015 One More Time...
How do I slow the speed of the 45s on my rowe r-92 jukebox .The records are playing a little too fast
The turntable motor on the jukebox range of R-84 to R-93 is none adjustable.
If you are in the USA then the motor operates on 60hz but in Europe it would have to be on 50hz to do this a different pulley is used.
The Rowe Ami part numbers are as followes:-
30791907 Turntable Motor Assembly 60hz
30791908 Turntable Motor Assembly 50hz
21817801 Motor Pulley 60hz
21817802 Motor Pulley 50hz
These can be ordered from a Rowe Ami dealer or you could try www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Oct 28, 2009 | Wurlitzer Jukebox 1015 One More Time...
Rowe AMI CD100 RAM Error
try this turn the box off , hold down the 0 and the 1 selection button
at the same time turn the box on. that reloads the prom to the ram
Apr 01, 2009 | Audio Players & Recorders
Regards
Alan Hood
ami-man
UK
Feb 01, 2009 | Wurlitzer Jukebox CD Player
Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
Jan 05, 2009 | Wurlitzer Jukebox CD Player
99 people viewed this question
 Grubhead
Grubhead
