Question about Electric Jazzy 1115 Power Wheelchair
Missing instructions on how to charge battery for MPV4
I have charged the batteries with the "on" switch in the on position. I am assuming that O is for on and - is for off. I plugged the cord into the wall and into the arm rest of the unit. I had taken it for a short spin to see if my mother could go down the hill to the neighbor's and back. The neighbor lived next door. The hill is steep. I barely made it into the house before I could not move the machine. Is the wheelchair to be charged on or off? The lights were flashing 4 red, 3 yellow, 2 green. I left it charging with a check on it about every three hours. It has charged (maybe) over night.
This machine has been used a total of about an hour since it was purchased. It has been a problem because it is difficult to maneuver in
the house, so we use it as a transfer chair to get to the bathroom orr to put her to bed. Pretty expensive for that. We have switched to a regular transfer chair. Very frustrating. I would not recommend this chair because the parts of it are too heavy for me to lift into the car and it certainly does not have the power or stability to go from place to place in our neighborhood. I think the saleman should have explained that to us when it was purchased. It also needs manual assistance to go out the door.
Thanks for responding.
Elaine Wirth fancymoon@yahoo.com
  • 32 Answers
Bad/old batteries
Posted on Apr 03, 2009
Trying to charge battery for first time. It says connect two red connectors. Do you charge it first then connect the connector afterwards?
1. I assume this is a car battery so the first thing you do is to disconnect the vehicle cables from the battery terminals. The negative first and then the positive. The positive terminal is marked with a plus sign ...+ ... When refitting the cables to the
battery after it is charged you fit the positive cable to the positive battery terminal(+) first and fit the negative(-) last.
2. Now that the battery is unconnected from the vehicle you can fit the charging cables to the battery terminals. The charger you have should have 2 cables leading from it , a positive with a red plastic insulation on the clip and a negative cable probably with black insulation on the clip.The instructions with the charger will tell you in which order the cables are to be attached to the battery and the order you remove them. Each of the 2 cables has to be clipped onto the correct battery terminal. The positive cable(+) from the charger goes to the positive battery terminal (+)and the negative cable(-) from the charger goes to the negative battery terminal(-).
3. Once the cables from the charger are properly connected to the battery, you can plug in the charger and turn on the power.
4. Batteries generate explosive gasses when being charged and it only takes one small spark to ignite them. Don't reconnect the battery after charging for a half hour or so and make sure the area where you are charging is well ventilated.
Dec 18, 2015 | Cars & Trucks
Need charging instructions for Air Hogs Havoc heli. Is remote control switch to be turned on during charging? What position is channel switch in? Is Heli on/off switch set to charge? I have no...
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Feb 19, 2010 | Spinmaster Air Hogs Battling Havoc R/C...
I have plugged the Soneil battery charger into the MPV4 Hoveround for over 24 hours. Although the indicator shows charging in process, the "battery charge indicator" shows it still requires a substantial...
If your Power Wheel Chair has been sitting idle for a while, the batts may need to be completely replaced. There is a gel inside the batts that need to have a current run through them via the charger on a regualr basis otherwise it will solidify. If the charger lights are onm you have connected the charger correctly for over 24 hours and the batteries are still not showing they have been charge, there may be damaged cells which means both batteries need to be totally replaced.
Nov 01, 2009 | NRS Hoveround MPV 5 - Used Power...
Looking for an instruction guide for a ''Challenge'' jump starter for Cars. The red switch on the model has three positions OFF/CHARGE/ON. I need to know which switch is to recharge the car battery and not...
The 'ON' position is for charging OR jumping the car battery. Normally, you just hook the unit to the car battery to jump start it, then remove it and the car alternator will charge the car battery.
Sep 26, 2009 | Black & Decker Simple Start Car to Car...
How do i charge a capacitor for sound system?
Hello gradycusick,
I'm assuming that your cap did not come with a "charging resistor" and instructions, or you bought it from someone used.
The recommended way to charge a capacitor is through a 500-1K ohm resistor, at least 5 watts. Connect a DC voltmeter to the cap leads, connect the positive side through the resistor and to battery positive, and connect the negative side to battery negative (or grounded to the vehicle frame). Do not hold the resistor. It will get HOT. When the voltmeter reads 12V, the capacitor is charged.
If you do not have the resistor or a voltmemter, you can simply use a 12V automotive bulb. Just connect the bulb in series with the battery positive and the capacitor and connect the negative side of the cap to battery negative. When the light goes out, the cap is charged.
You can see an example of both methods here.
Hope this helps.
May 04, 2009 | Car Audio & Video
Charging a MPV4 hoveround chair
The battery charging connector, which may appear as the female connector of a stage-quality microphone, is underneith the Joystick control arm. An external charger should have been provided by the seller, so if you don;t have one, you'llhave to contact the chir manufacturer.
Nov 09, 2008 | Electric Jazzy 1115 Power Wheelchair
Charge the phone battery
nope just the battery charges fast if u charge it when phone is switched off position.
its recommended to charge in off position, but there is no damage in off or on position. if you charge your battery
Apr 22, 2008 | Sony Ericsson K800i Cellular Phone
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Electric Jazzy 1115 Power Wheelchair Logo
152 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
