Problem with boot from usb drive
When i try to install windows xp professional sp3 from usb driva i get a message INF file txtsetup.sif is corrupt or missing, status 18. Setup cannot continue. Press any key to exit
    New Friend:
  • 48 Answers
Make sure the usb flash not remove or move through installation winxp
if you do
you must reinstall new copy of win xp on usb flah then try agin to setuo windowsw from it
Posted on Dec 04, 2012
5 Suggested Answers
  • 59 Answers
SOURCE: i have a dell dimension4700, trying to replace the hard drive.
ata is a big flat cable whereas sata is a newer thin flat cable. it really depend on your motherboard and if it accepts them. if you could plug it in then it means that it accepts the connection. you can use any harddrive as long as it has the ata or sata connection and also if it can plug in to the mobo (motherboard).the windows insatllation may not be recognising the newer drive or the original one. make sure you have the jumper pins on your original drive set to master and the ones on the new drive set to slave. then as the pc boots up repeatadly tap the delete key and you will eventually go into dos. in dos go to peripherals or boot devices (different with some) , it may be called something else but find the boot sequence and set your cd drive to 1st boot device then your old harddrive to 2nd boot device then 3rd to your new drive. or if you have a floppy drive you can set that to first and then cd to second and master drive to third. if you want to only use the new harddrive then you will have to set it as master on the jumper pins and then 2nd boot device in dos after your cd drive and floppy drive. then you would have to do a fresh install of windows on the new drive and not use the restore disk.then you would have to transfer your files off your old drive which you would have to set as a slave drive on the jumper pins. if you do a fresh install of windows then you could download it. if you still have problems then write back. if you do get it to boot up it may not recognise the new drive, i would recommend checking the jumper pins on the harddrives and then reinstall windows. and format your new drive.
Posted on Apr 05, 2009
  • 4 Answers
SOURCE: My hard disk is detect but i can't install OS .
that means your hard disk is damaged
Posted on Jul 08, 2009
jh5637
  • 49 Answers
SOURCE: INF file txtsetup.sif is corrupt or missing status 14
LOL....I'm in a similar Windows boat that is sinking fast. Also using Ubuntu from a USB drive! Anywhoo....I got extra copy of XP I don't need anymore. Contact me if you're interested jh5637@gmail.com
Posted on Feb 13, 2010
  • 2386 Answers
SOURCE: when I boot up with windows recovery cd in drive
your keyboard is not connected properly, because boot should response when you press any key, check the connections of keyboard or replace with correct one.
as far the massage concern, it shows the windows gone corrupt re-installation is recommended.
Posted on Nov 08, 2010
Inf file txtsetup sif corrupt or missing status 256
64-bit central processing unit is one that can support a higher amount of system resources than a 32-bit counterpart.
It has the ability to both recognize and use more amounts of available system memory to go along with its faster processing speeds.
If you want to install a 32-bit operating system on a computer with a 64-bit processor, you can--but you won't be taking full advantage of what your system has to offer you.
Place the installation disc for your 32-bit operating system in your computer's disc drive.
This can be one that you've purchased, as in the case of Microsoft's Windows operating system, or one that you've downloaded from the Internet, in the case of the Linux operating system.
Shut down your computer. Once completely off, turn it back on again.
Click "Next" to continue through your 32-bit operating system's setup program.
You will be asked to read the "TOS," or terms of service.
This is important legal information that you should read in detail, as it informs you of exactly what you're agreeing to by installing this operating system.
Specify any settings changes you want to make to the way your operating system is installed.
From these screens you can also input personal information into your operating system, such as your name or business information, which will save you the trouble of having to do it later when you install utilities.
Click "Install." The 32-bit operating system's setup program will format your hard drive, erasing all data on it.
It will then place the necessary operating system files on your computer.
This can take an hour or more depending on the operating system being used.
Once this process is finished, allow your computer to automatically restart.
http://zone.ni.com/devzone/cda/tut/p/id/5709
Sep 12, 2013 | Computers & Internet
Hi I have a a310n pavillion 2003 service pack 2. Got an inf file txtsetup.sif is corrupt or missing status 14 message on sytem recovery try's.. Tried many things. Did a f8 safe mode cmd chkdsk /r and...
It sounds like a Hard Drive error. Get to the recovery partition by pressing F8 and selecting Repair. If it is not there contact HP for a recovery disk.
Hope that helps.
Dec 13, 2010 | HP Pavilion a310n PC Desktop
Hi, i have a problem with my computer. When i boot it, something different happens almost every try. Sometimes, nothing happens and there's a black screen. Sometimes, it says that windows cannot run...
Find folder name: i386
and go to file txtsetup.sif
copy txtsetup.sif from I386 and paste in flash , next rename I386 to $WIN_NT$.~BT .Worcked 100%.
Apr 08, 2017 | Gigabyte GA-7N400-L Motherboard
When I boot up with windows recovery cd in drive and press F12, press any key instructions come up. boot does not respond to any key I press. If I let it continue to sign in screen, register windows...
Nov 08, 2010 | IBM NetVista PC Desktop
I have multiboot setup on my system with Windows XP as primary and Windows 7 as other O.S. I mistakenly corrupted Windows XP. Now when I start it, it doesn't start and shows errror about "NTLDR". I tried...
when you dual boot win 7 and xp win 7 has to be the 1st 1 installed then xp or a corruption will accur .they have a fix for this on the microsoft database.it will get your xp install going.
Aug 29, 2010 | Mozilla Firefox
Feb 12, 2010 | Sony VAIO Digital Studio PCV-RS420 PC...
I want to do a clean install of Winodws XP sp3 on a Acer 5515 laptop computer. What are the instructions I need to follow to have this done by me?
The best way is to use the factory reset option this will revert you laptop back to the way it was before you started using it.
I think is ALT + F10 during the bootup process.
If this fails I recommend that you use a Windows XP boot CD with SP3 slipstreamed, you can use nLite to do this, if you use have a USB floppy drive you can use a winnt.sif file on it you can add your OEM licence if you dont have a floppy then you can add this file to your I386 folder and burn a new install CD.
Use Nero Boot CD menu option and make sure that you set the screen as per this screen dump otherwise it wont work. Use Mode 2/XA for maximum CD-drive compatibility.
Download the required boot image file HERE
Minimum Required for Windows XP SP3 copy and paste this into a file named winnt.sif, replace the xxxx-xxxx-xxxx-xxxx with your valid Licence key I suggest that you check it first HERE fill in the rest your self and save it. You can add much more to this SIF file search the internet for more HERE is a great link for you to start with
[Data]
MsDosInitiated=0
UnattendedInstall="Yes"
[Unattended]
UnattendMode=ProvideDefault
[UserData]
ProductKey="XXXXX-XXXXX-XXXXX-XXXXX-XXXXX"
FullName="Your Name Her"
OrgName="Your Company Here"
ComputerName="What ever you want Here"
[Display]
BitsPerPel=32
Xresolution=1024
YResolution=768
Vrefresh=60
Hope this helps please rate.
Nov 11, 2009 | Microsoft Windows XP Home Edition
My hard disk is detect but i can't install OS . It shows the following error: corrupt or missing INF file txtsetup.sif status-8192
You may need to go to the microsoft website, download the recovery files and make discs.
This sucks, but as I found, this may be the only way.
If you are able to boot into safe mode that may help.
If you have the OS disc you can do a recovery.
Jul 08, 2009 | Computers & Internet
Download of new XP windows stuck in 16 bit resolution screen
sorry, but learn how to install xp pro. Skip the internet connection. Plug the plug. Install internet AFTER the xp install. let it ride
Jan 25, 2009 | Intel Motherboard
Computers & Internet Logo
536 people viewed this question
David Payne
David Payne
