Question about Photography
Head for fluid solidex tri pod
Remove the head
  • 685 Answers
Solidex is not a tripod for which parts can be gotten. Most of the Solidex tripods do not have removable heads. Try anther brand. You can find a bunch of very good tripods at: itripod.com UI like the Sirui brand
Posted on Dec 15, 2012
Tip
How to Replace the planetary gear in an Odometer of car?
The procedure is follows:--
1) First of all disconnect the negative cable from the battery of car.
2) With flat head screwdriver, pry the gasket around the edge of the face of speedometer gauge away from the dash and remove the gasket.
3) You will have to pull the entire speedometer gauge out of the dash;
NOTE:-- do not to disconnect the connecting electrical wires when you pull speedometer.
4) Then remove the speedometer needle by turning the needle clockwise.
5) Then remove the two screws in the face of the gauge with screwdrivers.
6) Remove the motor casing for the odometer out from the dial after the screws are removed.you will need to pull the motor casing a bit to remove it out.
7) In the motor casing you will see the gear pod at the top of the motor casing. Slightly with bit force remove the gear pod. The gear pod is attached to the "lid" of the casing .
8) You will see the odometer planetary gear in the gear pod which you removed.Remove the planetary gear from the gear pod with the help of mini flat head screwdriver.
9) Insert new gear into position and reassemble the gauge by reversing the procedure.
this will help.Thanks.
on Mar 15, 2010 | Audi A4 Cars & Trucks
I am looking for quick release plate for a Radio Shack RST-84V tripod made in the 90s. I looked all over (local radio shack stores and corp. head quarters) but no one has any info. Finally I came across...
I found this tripod, new, on Ebay. It looks like it would serve your purpose. I'll keep checking for you, but take a look at it- it was posted on the 22nd of May, so you have plenty of time to check it out and buy it, if you choose. Good luck, hope this helped!
May 23, 2010 | Cameras
Ball bearings are gone from one of the four holders inside
Use a flat head screwdriver and slowly work it underneath the pod and work the pod away from the body.
www.cpo2go.com
May 13, 2010 | Hayward Navigator Pool Cleaner
I have a Solidex tripod and I can't find the model number. It's missing the shoe and the piece to secure the shoe in the head. I can find a replacement shoe but I don't know how to find a replacement for...
As far as I know Solidex is out of business and since most of there parts are not standard to the other major manufacturers you should either buy a new tripod or search for the same (exact same) model on ebay or craigs list to find the same model and use it for parts.
Jan 06, 2010 | Photography
My handle broke on my Solidex Model VT-90HQ tripod and I am trying to find part.
As far as I know Solidex is out of business and since most of there parts are not standard to the other major manufacturers you sould either buy a new tripod or search for the same (exact same) model on ebay or craigs list to find the same model and use it for parts.
Nov 27, 2009 | Photography
Tripod
If you have not found the part for your tripod you are looking for, I have the whole assembly complete, still in the original box.$50 and it's yours.
Jan 01, 2008 | Photography
Solidex camcorder tripods
OKAY!! Thanks to the reply of "Baldwink", I was able to locate the product he suggested here in the U.S. from several dealers. This is the plate that mounts to the camera and allows easy removal/attachment to the tripod.
For the Solidex VT-90 tripod (the one I have and may fit others), order the Cullman CU-40470 Quick Release Plate. This is also described as the "Cullman Medium Quick Release 42mm" plate.
If you don't have the VT-90, measure the shoe plate area on top and remember that there will be at least one beveled (angled) area. Mine measured exactly 42mm square, so I am confident that the Cullman plate will fit. Also, the standard thread size for camera mounting is 1/4", but there are some cameras that use 3/8", so you might want to double check your camera for this spec.
I googled "cullman 40470 quick release" and found several U.S. dealers. The best price was from Adorama.com at $14 plus $5 ground shipping. Some dealers want as much as $33.
After nearly 20 years, I can use my Solidex VT-90 again!
Nov 15, 2007 | Photography
Photography Logo
184 people viewed this question
Top Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Photography Expert? Answer questions, earn points and help others
